POV-Ray : Newsgroups : povray.newusers : Using PNG's alpha for transparency... Server Time
6 May 2026 20:18:02 EDT (-0400)
  Using PNG's alpha for transparency... (Message 1 to 4 of 4)
Subject: Using PNG's alpha for transparency...
Date: 18 Nov 2000 01:16:13
Message: <3A162CD8.C98A884E@yahoo.com>
	I'm pretty new with textures...
I have a PNG image that is composed of white shapes on transparent background...
and the white fades to transparent...
Now, can I put this PNG and use its alpha channel in povray for transparency?
I tried "transmit all 1" and "filter all 1", didn't work... maybe I'm not using
it correctly?...
Please help!
Thanks,
	Simon
| Simon Lemieux           | Website : http://www.666Mhz.net  |
| Email : Sin### [at] 666Mhznet | POV-Ray, OpenGL, C++ and more... |
Subject: Re: Using PNG's alpha for transparency...
Date: 18 Nov 2000 03:26:47
Message: <3A163D49.6E3CAA45@mac.com>
> it correctly?...
Simon, if I understand correctly, you can only use transparency with a
paleted color graphic.  Filter all and transmit all make /all/ of the
colors in your graphic transparent or translucent.
You need to use a graphics program such as draw or paintshop to convert
the image coloring scheme to paletted, determine which palette number
the color you want not to appear is, and set /that/ to transmit.
Dawn McKnight      | "Who cares what the hipbone's connected to? I'm in Neurology!"
McK### [at] maccom   |					-- Justine Devlin, M.D.
Date: 18 Nov 2000 08:52:36
Message: <3a1689a4@news.povray.org>
> transparent background... and the white fades to transparent...
> for transparency? I tried "transmit all 1" and "filter all 1",
> didn't work... maybe I'm not using it correctly?...
If I recall correctly, POV-Ray always use the alpha channel if present. You
shouldn't use transmit all 1 or filter all 1, since those keywords are
related to images with palettes only.
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated October 9)
/ Also visit http://www.povrayusers.org
Date: 18 Nov 2000 17:17:45
Message: <3A170E28.AEA9369@yahoo.com>
Yes it's true... it wasn't working but then I got the keywords out and there it
worked!
Thanks,
	Simon
