POV-Ray : Newsgroups : povray.newusers : Depth Queuing in POV Server Time
6 May 2026 20:18:09 EDT (-0400)
  Depth Queuing in POV (Message 1 to 9 of 9)
Subject: Depth Queuing in POV
Date: 16 Nov 2000 13:12:38
Message: <3A142395.98ACE0EF@scripps.edu>
Is there a way to get a depth queuing effect in POV? That is, were
objects that are behind other objects get faded into the background
color, or from a certain plane backward through the image, objects are
faded into the background.
Any advice or help is appreciate.
Mike
Michael DiDonato, PhD
The Scripps Research Institute
Department of Molecular Biology
Maildrop MB4
10550 North Torrey Pines Road
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Subject: Re: Depth Queuing in POV
Date: 16 Nov 2000 13:30:45
Message: <3a1427d5@news.povray.org>
Perhaps try a constant fog in the background colour?
Marc-Hendrik
Date: 16 Nov 2000 13:53:01
Message: <3a142d0c@news.povray.org>
Look at the help about fog in the povray documentation.
Date: 16 Nov 2000 20:19:06
Message: <3A148789.A5DA4ACE@scripps.edu>
The problem with fog is that you can either hav it everywhere or from
the ground up.  I need something  that is like an xy-plane which fades
to the background color along the +ve z-axis.
Mike
> Marc-Hendrik
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Date: 16 Nov 2000 21:17:29
Message: <3a149539@news.povray.org>
Michael DiDonato wrote in message <3A148789.A5DA4ACE@scripps.edu>...
perhaps this sounds hardly but it's really simple - just try rotate
whole world
ABX
Date: 16 Nov 2000 22:38:03
Message: <3A14A84D.B5581FFD@peak.edu.ee>
Change the up vector of the ground fog, or use media (probably of the absorbing
type)
Margus Ramst
Date: 17 Nov 2000 18:46:04
Message: <3A15C2D0.2DED9D47@faricy.net>
> type)
Ie you want distance from the xy plane, not the camera point, right? I'm not sure
you can do that in standard POV.
Date: 18 Nov 2000 01:47:51
Message: <3A162616.5111A4FC@scripps.edu>
Unfortunately, I think you are right.  Maybe a consideration for a feature in a
future version.
Mike
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Date: 21 Nov 2000 10:22:09
Message: <3A1AA469.1B0E840E@free.fr>
I added this feature in my patch that works for normal fog
and ground fog. The new parameter is 'fog_start', which specify an
offset from the camera. Only to mention that a small bug has been
recently discovered; it affects transparent objects using 'clipped_by'
modifiers.
	Direct page:
http://pov4grasp.free.fr/features/fog_start.php3
*** Nicolas Calimet
*** http://pov4grasp.free.fr
