POV-Ray : Newsgroups : povray.newusers : Infinite primitives? Server Time
18 Nov 2026 06:48:31 EST (-0500)
  Infinite primitives? (Message 1 to 13 of 13)
Subject: Infinite primitives?
Date: 12 Nov 2000 01:59:25
Message: <3A0E4DFE.F0C6A88B@yahoo.com>
	I was wondering if it was possible to simply have an infinite cylinder?
Without any tricks... this should normally be trivial for the renderer... but
was this coded?
Thanks,
	Simon
| Simon Lemieux           | Website : http://www.666Mhz.net  |
| Email : Sin### [at] 666Mhznet | POV-Ray, OpenGL, C++ and more... |
Subject: Re: Infinite primitives?
Date: 12 Nov 2000 10:05:25
Message: <3A0EB1DE.C830462B@peak.edu.ee>
Simon Lemieux wrote:
> Hi,
> was this coded?
What do you need it for? Scaling the cylinder up along its axis can make it seem
infinite for any purpose I can think of.
You can make an isosurface with an infinite cylindrical function, but this too
will have to be contained by an infinite object.
Margus Ramst
Date: 12 Nov 2000 10:19:35
Message: <chrishuff-76AD89.10194412112000@news.povray.org>
In article <3A0EB1DE.C830462B@peak.edu.ee>, Margus Ramst
> make it seem infinite for any purpose I can think of.
> this too will have to be contained by an infinite object.
As I recall, the list of possible contained_by objects is very
short...box and sphere last I heard.
However, a quadric should do the job, if an infinite cylinder really is
necessary. Maybe a "infinite" keyword could be added to cones and
cylinders...all it would have to do is remove bounding and not clip the
ends and render disks there.
Christopher James Huff
Date: 12 Nov 2000 12:03:04
Message: <3A0EDB77.6BCAE4BC@yahoo.com>
Thanks, the quadrics work pretty fine!
Date: 12 Nov 2000 15:30:45
Message: <3A0EFE20.83A2EFE2@peak.edu.ee>
*ack* I meant to say "finite object"
Margus Ramst
Date: 12 Nov 2000 21:17:03
Message: <3A0F50A5.1C648BDF@erols.com>
> cylinder?
> renderer... but was this coded?
I think this ought to work.  It uses the Reorient() macro from my
Thoroughly Useful Macros file:
#macro InfiniteCylinder(PointA,PointB,Radius)
quadric { <1,0,1>,<0,0,0>,<0,0,0>,-Radius*Radius
  Reorient(y,vnormalize(PointB-PointA))
  translate PointA
Hope this helps,
John
ICQ: 46085459
Date: 13 Nov 2000 03:34:13
Message: <3n2u0t0i36buqceccj661fi3tpg2fdo9ad@4ax.com>
On Sun, 12 Nov 2000 02:59:58 -0500, Simon Lemieux
<lem### [at] yahoocom> wrote:
>Hi,
>was this coded?
A quadric (anyone remember these?) should do it. Look at shapes.inc
and shapesq.inc in the standard POV-Ray package.
Peter Popov ICQ : 15002700
Date: 13 Nov 2000 09:27:03
Message: <3a0ffa37@news.povray.org>
Peter Popov <pet### [at] usanet> wrote:
: A quadric (anyone remember these?) should do it.
  Isosurfaces killed quartics and other poly objects... RIP.
  ... Or perhaps not. You can create infinite surfaces with polys but not
with isosurfaces. Polys also are more accurate (but usually slower).
  Btw, see http://iki.fi/warp/polytutorial/
Date: 15 Nov 2000 03:53:57
Message: <a5j41tgi5rsed4s8tckd61gdn4a68otpcb@4ax.com>
That's exactly what I had in mind. With all the iso frenzy, people
seem to have forgotten about the good ole infinite primitives. They
still have their uses.
Date: 15 Nov 2000 20:43:46
Message: <3A133C08.BDF71683@peak.edu.ee>
Out of curiosity, what uses?
I.e. how is a "truly infinite" quadric cylinder better than a regular cylinder
scaled so long that POV considers it infinite?
Margus Ramst
Date: 16 Nov 2000 06:35:12
Message: <3a13c66f@news.povray.org>
Margus Ramst <mar### [at] peakeduee> wrote:
: I.e. how is a "truly infinite" quadric cylinder better than a regular cylinder
: scaled so long that POV considers it infinite?
  There might be some accuracy problems if you scale an object too much
in one direction (remember that it's actually the ray that is
inverse-transformed; scaling the cylinder extremely long in one direction
means actually that you are scaling the rays inside an extremely narrow
area; might be so narrow that you get accuracy problems).
  Also specifying too big endpoints for the cylinder might cause accuracy
problems.
  These accuracy problems can be specially true if you are using an
isosurface. The bigger the contained_by object, the less accurate the
isosurface.
Date: 16 Nov 2000 13:02:26
Message: <3A142F9B.DF8312A3@yahoo.com>
> isosurface.
Really, this should probably be relative to the camera... ie if the camera is at
2 nanounits of the isosurface that has size of (1000, 1000, 1000)...  that
should also give the problems you mentionned, I think!...  This is probably
because povray uses a maximum of 32 bits or 64 to determine a number and if you
zoom too much you will overload that 32-64 bits number and then will have a few
precision bugs...
Is this true, I never worked with isosurfaces...
Date: 16 Nov 2000 15:04:41
Message: <ru371tsma115ge12fdf31chm62iptsb5lh@4ax.com>
On Thu, 16 Nov 2000 03:44:40 +0200, Margus Ramst <mar### [at] peakeduee>
Attitude :) *I* will know that I've cheated with the latter.
