POV-Ray : Newsgroups : povray.newusers : light fading in water Server Time
19 Oct 2026 03:56:47 EDT (-0400)
  light fading in water (Message 1 to 4 of 4)
Subject: light fading in water
Date: 20 Oct 2000 14:57:14
Message: <39f0958a@news.povray.org>
I want to make light fade in water. I've been through all the available
tuorials and tried everything I can find in the manual.
I want to make a figure, viewed from a high angle, fade away as you look
down in the water at him so that his feet are probably not visible.
Has anyone tried this, any tips, code or help gratefully received.
Thanks
Mick
Subject: Re: light fading in water
Date: 20 Oct 2000 15:23:52
Message: <39f09bc8@news.povray.org>
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> wrote in message
news:39f0958a@news.povray.org...
It's been done, and done a few different ways I'd say.
What you would use is either fade_distance and fade_power in the water object
(fade_color esp. useful in MegaPOV) or difference the "figure" away from the
water object having that textured with a gradient y pattern going from clear to
unclear along -y.  Then put the figure, or person, back into the scene at a
slightly reduced scale (can be imperfect if scaled too much or the object is
complex).
Another way is to use media or ground fog (type 2) inside the water object.
Date: 20 Oct 2000 16:11:44
Message: <39F098DC.E09841EA@peak.edu.ee>
Have you looked Christoph Hormann's tutorials?
http://www.schunter.etc.tu-bs.de/~chris/raytracing.html
Some sort of light fading is one thing to add (either with fade_distance &
fade_colour or media). Another is variable reflection, in combination with
conserve_energy, which makes the water more reflective & less transparent at
shallow angles (I am of course assuming you use MegaPOV)
Margus Ramst
Date: 21 Oct 2000 04:37:11
Message: <39f155b7@news.povray.org>
Thanks You've given me the clue I needed.
Mick
> Thanks
> Mick
