POV-Ray : Newsgroups : povray.newusers : How do you work? Server Time
18 Nov 2026 07:04:39 EST (-0500)
  How do you work? (Message 1 to 18 of 18)
Subject: How do you work?
Date: 20 Aug 2000 13:14:43
Message: <39a01203@news.povray.org>
I am still a little bit confused about how to get going more effective with
povray ...
is the standard/common user (does there exist something like that in the
first place?) using povray stand-alone or does he use modelling software
(i.e. Moray)?
if using Moray: Can you(do you) use it to create the 90% scene and then
taylor the last 10% in your own script ??
do you use a painting/drawing to start out a scene ?
in short: Tell me your best practices how to create a cool scene !!
thx
Wolfgang
Subject: Re: How do you work?
Date: 20 Aug 2000 13:21:58
Message: <39a013b6@news.povray.org>
I think most people using POV-Ray have a collection of software they use.
I use Moray for some modelling, especially for creating new textures.  I
also use AutoCAD (a little pricey for most, I'll admit), NuGraf/PolyTrans
(also pricey, but an excellent 3D file format converter).  Most of my scenes
are 50% hand-coding, 50% software modelled.  Many people also use
SPatch for modelling organic things.  I think 3DWin is used by many for
converting between different 3D file formats.
Doug Eichenberg
http://www.getinfo.net/douge
dou### [at] nlsnet
Date: 20 Aug 2000 14:23:59
Message: <39a0223f$1@news.povray.org>
99.9% script writing in my case.  I have no skill using modeler programs,
other people do.  It's much a matter of abilities, although preference too.
Considering that half the things POV-Ray can do aren't possible via a GUI
interface I'd say scripting is a necessity either way.
Date: 20 Aug 2000 14:38:40
Message: <39a025b0@news.povray.org>
99.9% script writing?  I have new respect for your work!  I come from
an engineering background (lots of drafting), so I tend to model most
everything... I leave the scripting to you guys!
Doug Eichenberg
dou### [at] nlsnet
Date: 20 Aug 2000 15:09:23
Message: <39a02ce3@news.povray.org>
Bob Hughes <per### [at] aolcom?subject=pov-news:> wrote:
: Considering that half the things POV-Ray can do aren't possible via a GUI
: interface I'd say scripting is a necessity either way.
  On the other hand, half of the things a good modeller can do are not
possible with the scripting language.
  (Well, theoretically it is possible, but in practice no-one can do
it by hand; for example a complex head model made with a triangle
mesh).
Date: 20 Aug 2000 15:26:02
Message: <39A031A0.BDB9D9D5@mailbag.com>
> mesh).
IMHO, triangle meshes are best suited to scanned data (Stanford bunny
etc.).  I don't think many people are using modelers to make complicated
triangle meshes.  Editors are highly useful for bezier patches, though.
-Mark Gordon
Date: 20 Aug 2000 15:33:15
Message: <39a0327b$1@news.povray.org>
I make use of traingle meshes quite often.  Anything I model in AutoCAD has
to be converted to a triangle mesh to be rendered in POV.  The same goes
for anything modelled with 3DSMax, 3D Studio, TrueSpace, etc.... pretty
much any file found at 3DCafe.
Doug Eichenberg
dou### [at] nlsnet
Date: 20 Aug 2000 15:36:54
Message: <39A0337E.B65C946F@schunter.etc.tu-bs.de>
Not to forget non-GUI programs like L-system generators and heightfield
programs.
IMO all kinds of work (hand-coding/modelling/...) have their advantages for
certain purposes.
I also often use a scanner and vectorizing programs to gather real world data.
Date: 20 Aug 2000 15:37:54
Message: <39A03386.F26746BA@yahoo.com>
i use moray and spatch mostly, but my final scenes are at least tweaked
by hand.  because the models i've undertaken are so complex, i haven't
done many scenes but i have run tests, most of which i hand coded.  once
i get all my models done, i'll be using quite a bit of hand code for
certain things.
> povray ...
> (i.e. Moray)?
> thx
> Wolfgang
Date: 20 Aug 2000 16:00:03
Message: <39A0394B.EBC6EF7C@erols.com>
> with povray ...
> the first place?) using povray stand-alone or does he use modelling
> software (i.e. Moray)?
> then taylor the last 10% in your own script ??
I use pencil and paper to sketch things out as I design them.  Then I
hand-code scripts.  That's it.  If I'm using an image_map, I'll create
it via the most effective means (POV render or Paint Shop).
For many functions I have developed script macros that greatly simplify
things.  Some of the macros simply toss together primitives in ways that
get done alot, and others do complicated things, like plotting out the
steps taken by a character walking along a path.
John
ICQ: 46085459
Date: 20 Aug 2000 18:08:15
Message: <slrn8q0jph.cka.steve@zero-pps.localdomain>
I hand code, mainly because modellers confuse me.  If it can't be
hand coded then it doesn't get into my scene (except in my early
POV days when I loved image maps).
 10:26pm  up 2 days, 22:02,  2 users,  load average: 1.02, 1.02, 1.00
Date: 20 Aug 2000 19:17:49
Message: <39a0671d$1@news.povray.org>
"Doug Eichenberg" <dou### [at] nlsnet> wrote in message
news:39a025b0@news.povray.org...
I almost left the 0.9% off because I have used a modeler before, and image
map making in paint programs, and triangle meshes I've downloaded, and
whatever else might apply.  However, the amount of all else in comparison to
the hand coding stuff is easily 0.1% (1 external thing out of every 1000
internal(?)), not much of anything ever comes close to being finalized as
you certainly must know.
Date: 20 Aug 2000 19:24:23
Message: <39A0697F.BB9C288E@mailbag.com>
I stand corrected.  Are these objects typically intended to be rendered
as triangle meshes, or is that just the only way to export them to
POV-Ray?
-Mark Gordon
Date: 20 Aug 2000 19:42:18
Message: <chrishuff-5F8533.18433720082000@news.povray.org>
In article <39a01203@news.povray.org>, "Wolf Manos"
> (i.e. Moray)?
I think the average user hand codes and occasionally uses a modeller,
but does not depend on the modeller. I always hand code. There are
people who do everything from within one modeller, Moray for instance.
Others use a combination of different modellers and put it all together
by hand.
Some people use modellers like Moray to do specific objects, and do the
actual scene by hand by assembling the pieces. I find it difficult to
work on a scene using a modeller, simply positioning the objects is more
difficult.
I usually just start from an idea in my head...I have tried graph paper,
but found it easier to code directly.
It really depends on your skills and the scene. I find it easier to
visualize the relevant pieces and type in the values manually than to
navigate through a group of views and moving things with the mouse. This
would probably be different if we had a VR modeller where you could
interact directly with the scene objects and see the whole scene,
instead of goofing around using a 2D pointer device for 3D operations.
It would probably also change for many things if I had a lot of
experience with a good modeller, but I am used to scripting things.
Christopher James Huff
Date: 20 Aug 2000 19:50:33
Message: <39a06ec9$1@news.povray.org>
Spatch, I assume generates bicubic patches, judging by the name. Right??
H²
Date: 21 Aug 2000 00:14:31
Message: <39A0AC20.E842983F@pacbell.net>
> Bob
I'm pretty much like Bob. I too have played with several modelling
programs but have yet to find one that allows me to be as creative
as I am with pure hand coding. Even those times I find a nifty
utility or download an awsome mesh off the internet I play around
with the object for a short time then move on to my own creations
again. I doubt I have posted more than a couple of images to the
the images groups that were not 100% my own creation. But this debate
comes up often enough that I won't discourage others from doing
whatever it takes for them to achieve the results they are looking
for.
Date: 21 Aug 2000 00:18:27
Message: <39A0AD0D.F2C705F9@pacbell.net>
> POV-Ray?
> -Mark Gordon
It's a mixture. For example you can create meshes directly in Acad
but it also has direct support for solid modelling. You cannot
however export the solid modelling data into a format that POV-Ray
can use so you have to convert it to a mesh first. Other programs
live in a mesh only domain while others like Rhino are NURBS based
which often means tesselating the NURBS surfaces into triangles
for export.
Date: 21 Aug 2000 00:25:26
Message: <39A0AF36.56152351@aol.com>
I depended on sPatch when I began because it was a simple way to engage my
sense of drawing which was what I found familiar.  After less than a year my
interests came to be served better with POV scripting.  I had purchased Bryce
but never came to use it.  Because I seem to find learning a modeller/render
interface as frustrating as learning to model with native POV script, I have
never really given them a fair try. Ditto modeller front-ends for POV though I
am sure I may yet discover their worth.  In general you must use the tool which
best answers to your goals and capability.
/jc
