Probably I'm missing something, but where is it possible to change the
default file output directory ? I had to reinstall pov recently
(Windows), clicked too fast on a button and now all the image files are
stored directly under the root, instead of being kept in the original
scene directory... I can't find the info in the docs, or in
pvengine.ini...
G.
Hi Gilles,
I believe you can add a line in the master povray.ini file (accessible from
the Tools menu) that specifies the output directory. Mine reads:
Output_File_Name=D:\images\
- How
Gilles Tran <tra### [at] inapg inra fr> wrote in message
news:396A0535.60C205E3@inapg.inra.fr...
> pvengine.ini...
> G.
How Camp wrote:
> Hi Gilles,
Wow, that was fast ! Actually I had to remove the line so that the output is in
the current scene directory, as I like it to be.
Thanks
G.
How Camp wrote:
> Hi Gilles,
& change that to "Output_File_Name=D:\images\out" so that you don't use up
heaps of space - doesn't quite work for anims
Pabs
