POV-Ray : Newsgroups : povray.newusers : Glass cylinder: dual Index of Refraction for glass cylinder? Server Time
6 May 2026 22:54:19 EDT (-0400)
  Glass cylinder: dual Index of Refraction for glass cylinder? (Message 1 to 4 of 4)
Subject: Glass cylinder: dual Index of Refraction for glass cylinder?
Date: 1 May 2000 21:27:42
Message: <390E2EDE.A596D603@mm.ewha.ac.kr>
Dear Povers,
 I'd like to build a glass cylinder having dual IOR. For example, a
little bit lower skin IOR(1.45) and normal center IOR(1.55) in the glass
cylinder. Would this be possible?
The other question:
Directionally different IOR's for a glass or semi-transparent plastic
cylinder. For example, higer IOR for cylinder axis direction and lower
IOR for radial direction. Would this also be possible?
Thank you all.
Jong
Subject: Re: Glass cylinder: dual Index of Refraction for glass cylinder?
Date: 2 May 2000 10:30:01
Message: <390ED8A2.1BCCB400@peak.edu.ee>
Variable IOR is not possible in POV, and probably never will be. It's too
computationally expensive.
You can of course split the object into separate parts and give the parts
different IORs, but that's probably not what you're after.
Margus Ramst
Date: 2 May 2000 17:12:30
Message: <slrn8gu0rs.q4t.sjlen@zero-pps.localdomain>
On Tue, 02 May 2000 10:26:54 +0900, J. Kim wrote:
>Dear Povers,
>The other question:
If you want to see the difference durin an animation you can use the
clock value in your ior statement so that it gradually changes as
the object rotates/falls whatever.
  5:29pm  up 5 days, 19:30,  5 users,  load average: 1.00, 1.00, 1.00
Date: 3 May 2000 01:46:24
Message: <390FBCF8.440137DC@mm.ewha.ac.kr>
Dear Margus,
 Thank you for your help.
 If it's not possible in POV, there would be no other way I could simulate
the glass cylinder with two different IOR's.
Jong
> Margus Ramst
> Personal e-mail: mar### [at] peakeduee
> TAG (Team Assistance Group) e-mail: mar### [at] tagpovrayorg
