POV-Ray : Newsgroups : povray.newusers : file management? Server Time
2 Aug 2025 07:56:12 EDT (-0400)
  file management? (Message 1 to 3 of 3)
Subject: file management?
Date: 14 Mar 2000 01:50:43
Message: <38CDFC13.4C6CA7B2@janics.com>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML>
<BR>I had POV for a while and created and downloaded many a file. I was
wondering
<BR>what the best way to organize them?
<BR> When I first got POV I wrote a little program to read,edit and
view the (.pov)
<BR>files that came with it. Since then I wrote a few more programs to
do other
<BR>things like make height_fields, polygons,  prisms , and other
objects. Now I'm
<BR>starting to tackle textures,finishes,normals and other stuff applied
to these
<BR>objects.  If I'm not careful I could have a real mess.
<BR>  Any suggestion would be helpful.
<BR>
<BR> </HTML>
Subject: Re: file management?
Date: 14 Mar 2000 07:11:38
Message: <38ce2c7a@news.povray.org>
My "mess" is simply sorted into a includes folder and utilities folder on the
root of C: (not as sub-folders of the Pov-Ray folder so as not to confuse into
the installation).  I'm not perfect about keeping things in order but that was
my solution to try and organize things.
This way I have all downloaded scene files (pov, inc, and associated maps) in
one area along with the other things I do in a separate sub-folder, but all in
one parent folder.
The various programs, utilities such in another root folder having subfolders of
things like the Colefax and Kopp lens flare files.
Main thing to keep in mind is the Library_Path= lines in the Povray.ini file.
At a limit of 20 paths (last I checked) I still find myself commenting some out
and uncommenting or adding others there.  I don't want to mix all the files into
a heap and later try to find them by filename alone, it's much easier to know
what and where they are by the folder names.
"Leroy Whetstone" <lrw### [at] janicscom> wrote in message
news:38CDFC13.4C6CA7B2@janics.com...
| I had POV for a while and created and downloaded many a file. I was wondering
|  When I first got POV I wrote a little program to read,edit and view the
(.pov)
| files that came with it. Since then I wrote a few more programs to do other
| things like make height_fields, polygons,  prisms , and other objects. Now I'm
| starting to tackle textures,finishes,normals and other stuff applied to these
Date: 15 Mar 2000 13:38:35
Message: <38CFF376.B9541C81@janics.com>
Thank for the advice. I'll spend some time reorganizing what I have. And reread your
advice if I it gets to complicated.
