Dear all,
I am planning on upgrading my Pentium II 233MHz(512K cache) to Celeron
433MHz(128K cache). Motherboard, RAM, and all other hardwares will be
the same.
I might not upgrade my motherboard yet. The current motherboard can
accept upto Pentium II 333MHz(512K cache) or the Celeron 433MHz.
Would the Celeron 433 give me performance boost of about 80% or more,
even though the cache size has been reduced, in terms of POV-ray
raytracing?
Any comment would be welcome.
Thanks in advance,
Jong
Going from a PI (not two) 233MMX CPU to a PIII 500MHz CPU was about a 3 times
increase in render speed for me. Maybe that's comparable in some way to your
upgrade idea, so say about 2.5 times? I don't think the cache is going to be
all that important unless you count minutes or seconds or something. Mine went
from 256KB to 512KB; although I haven't seen anything on performance
benchmarking of one amount of cache to another so I really don't know.
Actually the biggest performance hit might be in keeping the old mainboard if
it's got a 66MHz or 75MHz bus instead of 100MHz for example. That and HD too.
You might reconsider and get a 100MHz bus mainboard and matching Celeron
instead(?). I just saw a web page about them but can't locate any. I didn't
see any mention about such a thing at Intel:
http://www.intel.com/design/celeron/index.htm
If you were asking if the Celeron 433 might be better (?, you wouldn't want 80%,
180% yes, 100% is equal) than with the PIII 333 I'd guess it would be close
enough for price to matter a whole lot. But there's that motherboard thing
about it all, memory as well, to sync up all the parts.
"J. Kim" <jjk### [at] mm ewha ac kr> wrote in message
news:38AA10CB.3F3A4540@mm.ewha.ac.kr...
| Dear all,
| the same.
| raytracing?
| Thanks in advance,
| Jong
J. Kim <jjk### [at] mm ewha ac kr> wrote:
: I am planning on upgrading my Pentium II 233MHz(512K cache) to Celeron
: 433MHz(128K cache). Motherboard, RAM, and all other hardwares will be
: the same.
I don't think it's worth (unless you can do it for _very_ cheap).
It will have more MHz's but less cache. The increase in speed may be
only fractions. The amount of cache is quite crucial (just try disabling
the caches in bios and see how the computer slows down; my P-II 350MHz
runs like a 386 with caches disabled).
The speed of the memory bus may also be very important. I think that the
P-II 233 has a mem bus of 66MHz (while in the P-II 350 it's 100MHz). I don't
know how fast it's in the celeron.
I think it _is_ worth.
You can't compare the difference between any amount of cache and no
cache with the difference between 128K and 512K cache.
Markus
Markus Becker <mar### [at] student uni-siegen de> wrote:
:> I don't think it's worth (unless you can do it for _very_ cheap).
: I think it _is_ worth.
Well, if he want to pay a lot of money for a 10% speed increase, then
it's ok.
> it's ok.
How do you get to this number?
I would estimate that he would at least get an increase of ybout 50%
Right, there's a smaller cache, but it is faster.
Markus
In article <38AAC970.E287F46C@student.uni-siegen.de> , Markus Becker
>> it's ok.
I would also estimate 50% or so based on what I have seen on systems of some
of my friends.
Thorsten
"Thorsten Froehlich" <tho### [at] trf de> wrote in message
news:38aae8c6@news.povray.org...
Half the speed huh...? ;-)
But I know you mean double (I think).
In article <38ab116e@news.povray.org> , "Bob Hughes"
>>of my friends.
No, 50% in this context is correct. And 50% is not double, but means 1.5
times the speed of the original system. ;-)
Thorsten
e-mail: tho### [at] trf de
Oh... I thought 150% was equivalent to 1.5 times. Hmm. Any math judges out
there? Just kidding!
news:38ab68a3@news.povray.org...
| >>of my friends.
| Thorsten
In article <38ab7a38@news.povray.org> , "Bob Hughes"
It is, but double implies 200%, or two times, does it not? :-) We
definitely need a judge for this kind of problem, math should be conducted
by vote - if the majority says a solution is correct, then it should be! So
a judge would act as the majority ;-)
Thorsten
In article <38ab813c@news.povray.org> , "Thorsten Froehlich"
Oh damn, isn't it horrifying? I have nothing else to do but to write such
nonsense ;-(
Thorsten
Horrifying maybe, but I think most mathematics were derived by popular opinion
anyway. 1,2,3... (oops---- 0,1,2,3...)
news:38ab817b@news.povray.org...
out
| nonsense ;-(
| Thorsten
"J. Kim" wrote:
> Dear all,
> the same.
> raytracing?
> Thanks in advance,
Don't unless free and you plan to run linux. nearly 1.5 years ago I got
a PII/333 128M that is so far out of date now, mainly due to finally the
buss speed increasing ... There are lots of reasons ... get to your local
flea market with about $800, tell them to take out everything you have in
your present machine like modem and CD-ROM and floppy drives and ask for a
price. If you know what you are doing, tell them to keep their HDs also.
Upgrade the rest in your own time.
Whatever happened to the Kerbs and the Sosovars?
No, no, no, no.
You must understand, there is a huge difference between 128KB cache and no
cache. 128KB is enough for most applications, raytracing included. Large cache
is most important in SMP, and extremely RAM-intensive applications like speech
processing. The bus speed is also far less important than its made out to be, at
least for raytracing.
My Celeron runs POV as fast as an equivalent PII (or as close as no matter).
At 418MHz (overclocked) skyvase.pov takes 1:10 to render.
Margus
Margus Ramst <mar### [at] peak edu ee> wrote:
: You must understand, there is a huge difference between 128KB cache and no
: cache. 128KB is enough for most applications, raytracing included. Large cache
: is most important in SMP, and extremely RAM-intensive applications like speech
: processing. The bus speed is also far less important than its made out to be, at
: least for raytracing.
Raytracing is not memory intensive? What about those 100-Megs povray files?
Yes, it will start to shift towards memory intensive. But raw CPU horsepower is
a much more limiting factor. Besides, 100-meg files usually cause a lot of
swapping and CPU->RAM bandwidth becomes pretty meaningless.
Margus
it is actually english and math...
50% of 100Mhz means 50Mhz
a 50% increase of the 100Mhz would mean 150Mhz...
so it is english+math together!
BR/Saadat
