POV-Ray : Newsgroups : povray.newusers : Confining an object to within an sPatch object Server Time
19 Oct 2026 07:05:56 EDT (-0400)
  Confining an object to within an sPatch object (Message 1 to 27 of 27)
Subject: Confining an object to within an sPatch object
Date: 23 Jan 2000 22:49:13
Message: <388bcbb9@news.povray.org>
Hash: SHA1
I made a fountain with sPatch and now wish to put water in the basin.
However I do not know what type of object would be betst to use
(superellipsoid, extrusion, a primitave, etc.) for the water nor do I
know how to confine that object to with in the basin of the fountain
once I've created it.
- -The Developer
      Chicks dig scrawny, pale guys
-----BEGIN PGP SIGNATURE-----
Version: PGPfreeware 6.5.2 for non-commercial use <http://www.pgp.com>
iQA/AwUBOIvMSuuicZjHwGIQEQLDtACgioDII7s825c0aXw8g9F2T5YwjtMAoPSR
file://E6R80zGSTg9rRpVJfUw1oD
=sm/j
-----END PGP SIGNATURE-----
Subject: Re: Confining an object to within an sPatch object
Date: 24 Jan 2000 00:28:23
Message: <ZeKLOMdA0hT0l24M1=zAfH2kxT6Z@4ax.com>
On Sun, 23 Jan 2000 22:51:53 -0500, "The \"D\""
<the### [at] netzeronet> wrote:
>-----BEGIN PGP SIGNED MESSAGE-----
>Hash: SHA1
Since you are familiar with sPatch, can't you make the water in sPatch
as well? Just an idea anyway. You can try to CSG the union of patches
sPatch exports, it may or may not work -- it shouldn't by POV laws but
there are hacks to it and I don't know how MegaPOV will treat it.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 24 Jan 2000 04:09:43
Message: <388c16d7@news.povray.org>
"The \"D\"" <the### [at] netzeronet> wrote:
: (superellipsoid, extrusion, a primitave, etc.)
  What's a primitave?
Date: 24 Jan 2000 09:44:39
Message: <slrn88oonr.1e6.sjlen@zero-pps.localdomain>
On Sun, 23 Jan 2000 22:51:53 -0500, The \"D\" <the### [at] netzeronet> wrote:
>Hash: SHA1
When you look at the POV output from spatch you'll be able to work out
the size of the object you're working with, alternatively expirement
with a green sphere or something.
For the water, many people seem to get really good results with Chris
Colefax's spray macro, you can find a link to Chris's site via the
links page at http://www.povray.org
  2:20pm  up 22:31,  4 users,  load average: 2.09, 2.06, 2.01
Date: 24 Jan 2000 23:11:29
Message: <388d2271@news.povray.org>
Nieminen Juha <war### [at] punarastascstutfi> wrote in message
news:388c16d7@news.povray.org...
>   What's a primitave?
It's a dislexic's primative ;)
Date: 24 Jan 2000 23:11:46
Message: <388d2282@news.povray.org>
Steve <sjl### [at] zero-ppslocaldomain> wrote in message
news:slr### [at] zero-ppslocaldomain...
I'll keep that in mind.
I was planing on using that for spray any way. Will it also do the water
in the basin?
Date: 24 Jan 2000 23:12:02
Message: <388d2292@news.povray.org>
Peter Popov <pet### [at] usanet> wrote in message
news:ZeKLOMdA0hT0l24M1=zAfH2kxT6Z@4ax.com...
I'm actually not that good with sPatch my fountain was origionally
supposed to be a bowel. That makes sense about not being able to CSG it.
I'll proabably hack it into looking right by changing scale and stuff
like that.
Date: 25 Jan 2000 11:17:22
Message: <388dcc92@news.povray.org>
Possibly I suppose, although I've only used a separate object for water pools
(except for a stream I did once).  I'd think you would need a real long "life"
for the spray to get it to collect.  I haven't had much success in keeping the
fake liquid around very long but with a continual flow I would think so.
"The "D"" <the### [at] netzeronet> wrote in message
news:388d2282@news.povray.org...
I was planing on using that for spray any way. Will it also do the water in the
basin?
Date: 26 Jan 2000 17:25:19
Message: <388f744f@news.povray.org>
Bob Hughes <omn### [at] hotmailcom?subject=PoV-News:> wrote in
message news:388dcc92@news.povray.org...
water pools
long "life"
keeping the
so.
Was this in an animation, because I was planning on doing a still at
least for now. BTW what object do you normally use for water becasue I'm
baffled as to what I should use so far I've come up with a taurus or
cylender with a whole in it modified by the wave or ripple normal.
Date: 26 Jan 2000 17:39:15
Message: <388f7793@news.povray.org>
> water in the basin?
The Liquid Spray include file is really designed for particle sprays, and
although it will create puddles on flat surfaces it doesn't (yet?) allow you
to fill containers with liquid.
Instead, I might back-up Peter's suggestion of modelling the flat surface of
the liquid in sPatch as well, or perhaps a simple disc would be enough.
Either way, unless you want to give the water an interior for fading or
media, it should be enough just to model the surface with a suitable texture
for ripples and such.
Date: 27 Jan 2000 00:43:09
Message: <388fdaed@news.povray.org>
Yes, animated, although that makes little difference if you set it up like an
animation and use a mid range clock value for instance to do the still image.
The stream flow thing was simply a spray directed along the ground plane.  I was
thinking it could also fall from a height onto the ground with little or no
bounce to pool up in a basin.  The main problem being to keep it around long
enough (the lifetime and evaporation parameters) since the particles have a
tendency to shrink away regardless of the settings from what I could tell about
it.
It should be possible for a limited puddling anyhow just using the spray alone
and no separate puddle object.
Not sure I gather your reasoning about the torus or cylinder with a hole for
standing water, unless you meant for the containing object.  That would need
some CSG used on the spray.  I usually go with either plane, clipped plane, box,
blob, disc or cylinder as water surfaces with a wrinkles pattern or highly
turbulent ripples (waves if active water).  Others have used 'height_field' too,
in various ways.
news:388f744f@news.povray.org...
Bob Hughes <omn### [at] hotmailcom?subject=PoV-News:> wrote in message
Was this in an animation, because I was planning on doing a still at least for
now. BTW what object do you normally use for water becasue I'm baffled as to
what I should use so far I've come up with a taurus or cylender with a whole in
Date: 27 Jan 2000 09:08:38
Message: <+lCQOLXrTb+VgPcVZfTibv8qJKaK@4ax.com>
On Wed, 26 Jan 2000 11:07:50 +1000, "Chris Colefax"
I think a disc *might* work with light fading because after the ray
hits it it never leaves and POV may be tricked into thinking it's
inside the disc. Didn't someone have a problem with transparent discs
and media recently?
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 27 Jan 2000 19:57:54
Message: <44q19ss161s8gfv2gfu9rq4ds1pp1cgb2n@4ax.com>
On Sun, 23 Jan 2000 22:51:53 -0500, "The \"D\"" <the### [at] netzeronet> wrote:
If your basin is circular you could use the bottle macro I posted on 21 Dec 99 in
povray.binaries.scene-files.  This has a macro for the liquid that keeps it within the
bottle.
David
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
Date: 30 Jan 2000 00:37:06
Message: <3893ce02@news.povray.org>
news:+lCQOLXrTb+VgPcVZfTibv8qJKaK@4ax.com...
> and media recently?
Ok I'll look into that. Would the light fading need to be a global
setting or for the disc.
Date: 30 Jan 2000 00:37:10
Message: <3893ce06@news.povray.org>
Chris Colefax <cco### [at] geocitiescom> wrote in message
news:388f7793@news.povray.org...
and
allow you
surface of
enough.
or
texture
Well I'm actually not that good with sPatch could I do a primitave using
a bounded or clipped by or is this against the laws of POV? And I was
thinking about using an interior and making the water transparent or
translucent (haven't decided which).
Date: 30 Jan 2000 00:37:14
Message: <3893ce0a@news.povray.org>
message news:388fdaed@news.povray.org...
like an
image.
plane.  I was
or no
around long
have a
tell about
> it.
spray alone
Ok so It doesn't matter for animation or stills the settings would come
out to be about the same then. Gotcha
hole for
would need
plane, box,
highly
'height_field' too,
> in various ways.
The reasoning might not make sense becasue of my lack of indepth
knowledge of the laws of POV. What I was thinking was since the bowlish
part of the fountain (the only part I have finisht at the time) looks
like the bottom half of a shpere with an upside down hollow cone in the
middle I would need some way to get the water around the cone but I'm
now seeing that that doesn't make much sense since the water will be
tranparent (or translucent I haven't decided) anyway.
Date: 30 Jan 2000 00:37:17
Message: <3893ce0d@news.povray.org>
David Wilkinson <dav### [at] cwcomnet> wrote in message
news:44q19ss161s8gfv2gfu9rq4ds1pp1cgb2n@4ax.com...
21 Dec 99 in
keeps it within the
> bottle.
The basin is a union of splines that looks like the bottom half of a
sphere (sorta) with an upside down hollow cone in it. Would the bottle
macro work in that case?
Date: 30 Jan 2000 02:18:22
Message: <3893e5be@news.povray.org>
Oh, hey, don't think I said anything about single frame rendering to get a still
image out of a animation did I?  Since I probably didn't and you might not know,
you'll need a Subset_Start_Frame=123 Subset_End_Frame=123 pair of lines in a Ini
file just like you were doing animation but to get a single frame instead.
+SF and +EF is the same on the command-line.
Fact is that with the spray.inc it has to use the clock directly, you can't
define clock as something else and expect it to be seen.  Same goes for many
such includes.  And the spray needs to get going in order to be fully present in
the scene so you'd want to move ahead into the sequence of frames quite a bit.
example Ini:
Initial_Frame=0
Final_Frame=89
Subset_Start_Frame=29
Subset_End_Frame=29
Initial_Clock=0
Final_Clock=1
Cyclic_Animation=On
Good luck with it, fun and frustration is always the way.  Keep asking
questions.
news:3893ce0a@news.povray.org...
was
about
> it.
Ok so It doesn't matter for animation or stills the settings would come out to
box,
too,
> in various ways.
The reasoning might not make sense becasue of my lack of indepth knowledge of
the laws of POV. What I was thinking was since the bowlish part of the fountain
(the only part I have finisht at the time) looks like the bottom half of a
shpere with an upside down hollow cone in the middle I would need some way to
get the water around the cone but I'm now seeing that that doesn't make much
sense since the water will be tranparent (or translucent I haven't decided)
anyway.
Date: 30 Jan 2000 02:33:48
Message: <3893e95c@news.povray.org>
Clipping on a primitive should be fine, so long as you get inside/outside
correct for the surface you will use for the 'interior'.  I can't recollect
putting media inside of a partial object so I couldn't say it will definitely be
okay; be sure 'hollow' is in the object.
  'interior' for the refraction ('ior') and a 'fade_distance' might be all you'd
need.  Translucence isn't available yet in MegaPOV or Official POV-Ray
(obviously), but 'fade_color' is.
news:3893ce06@news.povray.org...
Well I'm actually not that good with sPatch could I do a primitave using a
bounded or clipped by or is this against the laws of POV? And I was thinking
about using an interior and making the water transparent or translucent (haven't
decided which).
Date: 30 Jan 2000 02:39:12
Message: <3893eaa0@news.povray.org>
macro or no, all you would basically need to be doing is CSG difference the
basin from the water spray (union it as a whole by saying union {#include
"spray.inc}) then add in the basin on it's own.
difference {
 spray here
 basin here
object {basin here again}
But get that bottle macro, it's great.  Just sounds tougher to me to get set up
for this.
news:3893ce0d@news.povray.org...
in
within the
> bottle.
The basin is a union of splines that looks like the bottom half of a sphere
(sorta) with an upside down hollow cone in it. Would the bottle macro work in
that case?
Date: 30 Jan 2000 11:47:54
Message: <7lq89ssa5ac60f3hrvir558mb5uf7p7as0@4ax.com>
On Sat, 29 Jan 2000 12:29:05 -0500, "The \"D\"" <the### [at] netzeronet> wrote:
the
>> bottle.
>The basin is a union of splines that looks like the bottom half of a sphere (sorta)
with an upside down hollow cone in it. Would the bottle macro work in that case?
It would need a bit of work on it to handle the cone. As the macro uses Bezier splines
it
could be modified to handle any shape. Problem is - is it worth the trouble for just
one
special case?
Date: 30 Jan 2000 11:51:20
Message: <38946BEF.BD4E2B85@pacbell.net>
> splines it could be modified to handle any shape. Problem is - is it worth the
> trouble for just one special case?
Question is does it matter. So the basin has a cone in it. So what !
As long as the cone is not transparent you could run a surface right
through it an no one would ever know.
Date: 30 Jan 2000 12:29:58
Message: <d9t89sg6d32131lso6hrik60ch46ntlhdp@4ax.com>
Thats right.
Date: 30 Jan 2000 18:02:16
Message: <2bKUOAzyg8pGs4brFIeHX7l8mRmd@4ax.com>
On Sat, 29 Jan 2000 12:25:31 -0500, "The \"D\""
>> and media recently?
>Ok I'll look into that. Would the light fading need to be a global setting or for the
disc.
The disc. I haven't tested this, it's just an idea.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 31 Jan 2000 12:58:43
Message: <3895CE0C.525543C5@peak.edu.ee>
But YOU would know!
And it would bother you, and you would lay awake at night, hesitant, nervous...
Margus
Date: 31 Jan 2000 13:03:51
Message: <3895CE7F.DC59F150@pacbell.net>
> But YOU would know!
> Margus
Oh NO ! Not ME ! I would sleep better at night knowing that I did not
needlessly waste my time on something that didn't need it.
Date: 7 Feb 2000 21:52:57
Message: <389f8509@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote in message
news:38946BEF.BD4E2B85@pacbell.net...
You know I never thought about that.
