POV-Ray : Newsgroups : povray.newusers : Distant Mountain Ranges Server Time
18 Nov 2026 07:36:55 EST (-0500)
  Distant Mountain Ranges (Message 1 to 17 of 17)
Subject: Distant Mountain Ranges
Date: 1 Jan 2000 17:05:28
Message: <386e7a28@news.povray.org>
Hello,
	I'm extremely new to using povray (on BeOS no less), and was messing about here and
there.  Now my experiments have led to something that seems kind of interesting but I
really could use a mountain range way off in the distance.  I'm curious as to what
would be the best way to accomplish this.  Would a height field be the trick, or
building one by hand (erg...)?  Any tips or anything that could be shot my way?
	Thanks in advance-
Subject: Re: Distant Mountain Ranges
Date: 1 Jan 2000 20:55:40
Message: <386EAE77.5A6375C5@tapestry.tucson.az.us>
Building a really good looking mountain range can actually be quite difficult, but
since you want your mountains way off in the distance, it should be significantly
easier.  I would recommend using a height field, or several height fields.  There are
some excellent programs to help you design a height field, check out Ken's excellent
links for a pretty extensive list.  I have heard that Leveller (
http://www.daylongraphics.com/ ) is especially good.  I have also had some success
using HLA, although it is a bit more difficult.  I would also suggest making your
mountains a bit obscured by haze (as is probably realistic) so you don't have to worry
as much about texturing them, as that can be a bit tricky.  However, texturing them
could also be very help you quite a bit in better learning Pov, so don't let me talk
you
out of it.
Jerry C wrote:
> Hello,
here and there.  Now my experiments have led to something that seems kind of
interesting but I really could use a mountain range way off in the distance.  I'm
curious as to what would be the best way to accomplish this.  Would a height field be
the trick, or building one by hand (erg...)?  Any tips or anything that could be shot
my way?
>         Thanks in advance-
Date: 1 Jan 2000 20:59:33
Message: <386EAF59.F1EF492@tapestry.tucson.az.us>
By the way, your post appears as long line (no line breaks) to me, and Netscape
appears to have formatted my reply to match (sorry about that), making both somewhat
more difficult to read than they need be.  It's not a big deal, just so you know.
Date: 1 Jan 2000 23:00:19
Message: <97jt6s44qruveos8oddichr4k3k7crkmsn@4ax.com>
On Sat, 01 Jan 2000 18:52:25 -0700, in message
<386### [at] tapestrytucsonazus>, Kevin Wampler
<kev### [at] tapestrytucsonazus> wrote:
>By the way, your post appears as long line (no line breaks) to me...
  Same here, Kevin. I think Jerry can probably fix this by specifying a
reasonable line wrap at 70 to 76 characters per line.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 1 Jan 2000 23:27:17
Message: <386ED305.D8F5DD70@pacbell.net>
> but since you want your mountains way off in the distance, it should be
> significantly easier.  I would recommend using a height field, or several
> height fields.  There are some excellent programs to help you design a height
> field, check out Ken's excellent links for a pretty extensive list.  I have
> heard that Leveller ( http://www.daylongraphics.com/ ) is especially good.
> I have also had some success using HLA, although it is a bit more difficult.
> I would also suggest making your mountains a bit obscured by haze (as is
> probably realistic) so you don't have to worry as much about texturing them,
> as that can be a bit tricky.  However, texturing them could also be very help
> you quite a bit in better learning Pov, so don't let me talk you out of it.
Here is my complete list of HF utilities -
http://www.povray.org/links/3D_Programs/Height_Field_Modelling_Programs_and_Utilities/
While I too strongly recommend Leveller as the HF modeller of choice is is
also a Windows app and not likely to run on BeoS. Jerry migh want to head
over to John Beales HF utilities pages and see what he can find. I am pretty
sure the he has both PC and UNIX variants available that might be usable on
that platform with a little work.
Making HF's with a grayscale fractal pattern is not the difficult either
and produces some interesting results. Many people like to use Fracint for
this purpose which is available on all platforms.
Wishing you Seasons Greetings and A Happy New Millennium !
Date: 2 Jan 2000 16:32:35
Message: <VrpvOFfaTafftpvz2P2Qn48aJ2y=@4ax.com>
Jerry,
some users have reported problems with your post. I believe it is in
the encoding which is set to 8-bit. I'd recommend you switched to
7-bit text/plain encoding so as to make the life of those users
easier.
As of your quest, I think the others have headed you in the right
direction. Try the links section on povray.org for links to more HF
related utils if you haven't already done so.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 2 Jan 2000 17:47:27
Message: <slrn86uvt2.1t8.sjlen@zero-pps.localdomain>
After reading your post last night I thought about this for quite
a while, and may do some experiments with a Y gradiant pigment on
an X plane.  This has probably been tryed before, but I'm going
to give it a go soem time soon.
Date: 2 Jan 2000 18:06:28
Message: <386fd9f4@news.povray.org>
Hello Kevin,
The funny thing is that your post also appears as one long line here in
Outlook Express 5! What about my post? I'll just add some gibberish so you
can judge its length....
Sander
Kevin Wampler <kev### [at] tapestrytucsonazus> schreef in berichtnieuws
386### [at] tapestrytucsonazus...
Netscape appears to have formatted my reply to match (sorry about that),
making both somewhat more difficult to read than they need be.  It's not a
Date: 2 Jan 2000 18:59:17
Message: <386FE66E.7C0CD832@mailbag.com>
If no tools designed as HF modelers exist, paint programs work in a
pinch, and POV-Ray works surprisingly well.  OK, maybe not surprisingly.
-Mark Gordon
Date: 2 Jan 2000 19:51:15
Message: <386FF284.FAF55C96@tapestry.tucson.az.us>
Sander wrote:
> Hello Kevin,
Nope, your post looks just fine.  I guess I'll just have to fiddle around
with Netscape and find a way to have it give line breaks every so often
regardless of the post I was replying to.
Date: 3 Jan 2000 11:26:24
Message: <3870CDA1.9D665178@gci.net>
If you use NS 4.7: under the View menu, third section down, Wrap Long
Lines.
> Sander wrote:
> > Hello Kevin,
We are the POVRay of Borg.
Your data has been assimilated into the POVRay
users List of Ages
Resistance is in Ohms.
Date: 3 Jan 2000 11:33:05
Message: <3870CF44.68002D85@tapestry.tucson.az.us>
Thanks! That was exactly what I was looking for.
Date: 3 Jan 2000 11:39:15
Message: <3870D1A6.85759565@geocities.com>
No. Wrong one. Sorry.
What that option really means is "Go ahead and do the incorrect thing when
displaying messages, in direct violation of the RFC's, just because some
programmers out there are too lazy to read the standards, or are trying to force
everyone to switch to proprietary software", but that wouldn't fit on the menu.
Seriously, that's just a display option to correct for broken posts from other
people. (i.e. it treats a symptom upon reciept, not fixes the cause upon sending)
> Lines.
> > Sander wrote:
> > > Hello Kevin,
Date: 3 Jan 2000 12:14:57
Message: <3870D902.568A5133@gci.net>
Sometimes, all we can do is treat the symptoms.
Date: 4 Jan 2000 00:18:35
Message: <3871839B.63E99731@geocities.com>
Yes, but I choose not to hide the symptoms from myself. That way I can
help inform and enlighten others when they become infected.   :-)
How can an addict improve his situation if he does not first realize and
admit that he has a problem?
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 4 Jan 2000 03:06:48
Message: <3871A770.6CA54E8A@pacbell.net>
"Send me lots and lots of money and I will make your problems go away"
said the spider to the fly.
Date: 4 Jan 2000 13:25:09
Message: <VHuiuiAAhcc4EwbP@econym.demon.co.uk>
Wasn't it Jerry C who wrote:
>Hello,
>about here and there.  Now my experiments have led to something that seems kind
>of interesting but I really could use a mountain range way off in the distance.
>I'm curious as to what would be the best way to accomplish this.  Would a height
>field be the trick, or building one by hand (erg...)?  Any tips or anything that
I notice that one recent IRTC winner used Terragen to generate the
background mountains, then simply imagemapped the resulting mountains
onto the back wall.
Terragen is very easy to use produces brilliant mountains, and, at this
stage of its development, is free for non-commercial use.
It's at http://www.planetside.co.uk/terragen/
When you glue the results into your POV scene you just need to be a bit
careful to ensure that the lighting directions and atmospheric effects
are reasonably similar.
Mike Williams + #
Gentleman of Leisure
