POV-Ray : Newsgroups : povray.newusers : Povray Bug? Server Time
18 Nov 2026 07:36:49 EST (-0500)
  Povray Bug? (Message 1 to 16 of 16)
Subject: Povray Bug?
Date: 26 Dec 1999 15:29:40
Message: <38667B19.7425D2FD@cybercable.fr>
I have just started to use megapov from Nathan Kopp.
It works once well. After that povray stops totally the computer even
allowing Norton anti-crach program to intercept the problem.
I removed megapov and reinstalled completely Povray. It did the same
meaning that it works well once and suddenly stops the computer.
I used a register editor to remove all the old ressources of Povray and
Megapov but it did the same.
As anybody heard about this bug ?
Thanks to help me.
Charles
Subject: Re: Povray Bug?
Date: 26 Dec 1999 17:02:01
Message: <0p3d6sgtaika1654l4dckr04f0i886jgva@4ax.com>
On Sun, 26 Dec 1999 21:31:21 +0100, Charles & Paula
  I've successfully installed and run WinMegaPOV and the official
POV-Ray v3.1g for Windows (as well as the Linux versions of both) and
haven't had any problems of lockup or crashes.
  What happens if you disable all of the Norton utilities you are using?
  Does your system lock up with every scene you attempt to render,
including the official demo scenes?
  Please also read, "How to post bug reports", in
povray.announce.frequently-asked-questions and include system info in
your reply to this thread, thanks.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 26 Dec 1999 17:06:33
Message: <chrishuff_99-DF11BF.17072226121999@news.povray.org>
In article <38667B19.7425D2FD@cybercable.fr>, Charles & Paula
You mean Norton CrashGuard? I don't know about the Windows version, but
the Mac version had a reputation for causing more trouble than it
prevented. Of course, the two operating systems are so different that it
is probably impossible to judge one by the other.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 27 Dec 1999 14:27:59
Message: <3867BE25.D70F810C@cybercable.fr>
You all of you advise me to reinstall povray without Norton CrashGuard.
That's what I did (I restart the computer without NCG).
I didn't change what is happening:
4 seconds after clicking on povray icon to start it the computer stops
without a blue screen, simply stops. I have to reset the computer.
Thanks to give me tips.
Charles
Date: 28 Dec 1999 02:18:20
Message: <3868643c@news.povray.org>
Not sure I would have edited the Windows registry like you did since nothing
should have changed there upon using MegaPOV anyway.  It doesn't install,
just uses the POV-Ray setup already there.  Could be something else
entirely, like Windows itself going bad somehow but maybe it's video
related.  Did you try reducing Hardware Acceleration in System Properties
(Performance tab/Graphics button...)?
Wish I knew the answer.
"Charles & Paula" <pcd### [at] cybercablefr> wrote in message
news:3867BE25.D70F810C@cybercable.fr...
> Charles
Date: 28 Dec 1999 12:42:01
Message: <3868F441.28A1172@faricy.net>
I have had similar Windows problems, I can't play AVIs, Quake 2 freezes
when you exit... that reinstalling stuff and whatnot didn't fix. I think it
must be a problem with Windows itself somewhere, like a corrupt file or
something.
Date: 28 Dec 1999 15:05:41
Message: <38691815@news.povray.org>
Ontrack Systemsweep 2000 has a very good crash prevention program.  We use
Norton up at school, but for some reason, the CrashGuard seems to cause
crashes.  Usually, upon starting Netscape with CrashGuard on, it crashes,
but when CG is off, it doesn't crash.  Weird.
Go Ontrack!
This message brought to you by:
-=< Ian (the### [at] hotmailcom >=-
Please visit my site at http://spectere2000.cjb.net! :)
Chris Huff <chr### [at] yahoocom> wrote in message
news:chrishuff_99-DF11BF.17072226121999@news.povray.org...
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 28 Dec 1999 15:06:19
Message: <3869183b@news.povray.org>
Try ScanDisk as well.
omniVERSE <inv### [at] aolcom> wrote in message
news:3868643c@news.povray.org...
nothing
> Bob
> > Charles
Date: 28 Dec 1999 16:11:58
Message: <386927FE.8CB7BD7D@cybercable.fr>
As I have explained PovRAY is working well the first time after installation.
Then after some time it stops windows. It doesn't seem to be linked to video.
This happens just after the first time I use Megapov
Charles
> Bob
> > Charles
Date: 28 Dec 1999 23:23:53
Message: <38698cd9@news.povray.org>
Charles & Paula <pcd### [at] cybercablefr> wrote ...
installation.
video.
If you don't ever run MegaPov, will POV-Ray crash?
-Nathan
Date: 30 Dec 1999 15:02:10
Message: <386BBAB4.9B0D1CB2@cybercable.fr>
Yes
POVRAY alone (without megapov) is crashing (It works well one time after
povray installation and then for each use, it is crashing).
I have done all what people said but unfortunaltly no change in the system
crash.
-disabled Norton CrashGuard
Charles
> installation.
> video.
> -Nathan
Date: 31 Dec 1999 18:48:02
Message: <slrn86o3aj.7l0.sjlen@zero-pps.localdomain>
Sadly it sounds asthough your only option is to
reinstall windows.
I heard of someone having this problem a while ago
and his solution was a windows reinstall, after trying
many other things, (think it was Bill Dewit).
Good luck.
On Thu, 30 Dec 1999 21:04:04 +0100, Charles & Paula
>Yes
>crash.
>Charles
>> installation.
>> video.
>> -Nathan
 10:38pm  up 5 days, 10:57,  7 users,  load average: 1.06, 1.09, 1.04
Subject: quality settings
Date: 18 Jan 2000 03:50:18
Message: <3884294a@news.povray.org>
Hello there,
I just started using povray and was playing with some simple scenes and the quality
settings. And I was wondering, is there a way to put the quality setting in the pov
file and not on the command line.
Thanks in advance
koos
Subject: Re: quality settings
Date: 18 Jan 2000 04:01:19
Message: <388429C6.6B931D11@pacbell.net>
koos wrote:
> Hello there,
> Thanks in advance
> koos
I have never tried this but you might want to check out the docs on the
use of .ini file options. I am pretty sure that you can specify quality
settings in a .ini file for your scene so you do not have to specify them
on the command line each time you run the program. This of course would
be a POV-Ray for Windows only solution. If you are using a different
platform I am not sure what the proceedures would be.
Date: 18 Jan 2000 04:01:36
Message: <38842bf0@news.povray.org>
koos <koo### [at] ibb1102ibbuunl> wrote:
: I just started using povray and was playing with some simple scenes and the quality
  Not in the official povray, but it's possible with megapov.
http://nathan.kopp.com/patched.htm
Date: 18 Jan 2000 06:05:54
Message: <38844912@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:388429C6.6B931D11@pacbell.net...
quality settings. And I was wondering, is there a way to put the quality setting
in the pov file and not on the command line.
The Ini files can also be called upon at a command line, in DOS for instance,
basic idea is that a non-pov or non-inc file is read for input (I'm going by
memory here).  However for doing so within the scene file (*.pov) you need to
use MegaPOV patch like Nieminen J. has suggested.  Then you simply place a
ini_option "Quality=9" , for example, into 'global_settings'.
