Bob,
The opening starts with a side view of the text, from the rightmost ( Y/L )
end. The text rotates and as it gets to 90 degrees from its original (well ok,
-90) position it flashes and shimmers becasuse it is really shiny, like polished
metal. I've played around and gotten the text to rotate and look kinda shiny,
but I know it can look much better, its just beyond my patience. If you run the
file below, it looks best at 45 frames, clock values 0 to 1.
#include "textures.inc"
#include "finish.inc"
#include "metals.inc"
location <0,0,-3>
look_at 0
light_source { <0,0,-1000> White
cylinder
radius 20
falloff 20
tightness 0
point_at <0,.2,0> }
text { ttf "papyrus.ttf" "Z A B " .3, 0
texture { Aluminum }
finish {
ambient .1
diffuse .8
reflection .75
metallic
translate -1.375*x
rotate y*90
rotate -y*90*clock
omniVERSE wrote:
> Guess you'll only get some help from others that have seen the movie and
> also remember the title sequence.
> I found this: http://www.spe.sony.com/movies/heavymetal/
> Probably not the same graphic you're looking to do though.
> How about a description of the effect? Unless someone answers here sooner
> or later and can help already.
> Bob
You needed some hilighting mainly, and the all black surroundings doesn't
help reflective objects at all. So if you want to still see them well when
nothing else is around there should be other objects to reflect.
Here's what I did to it:
location <0,0,-3>
look_at 0
cylinder
radius 20
falloff 20
tightness 0
point_at 0 // <0,.2,0>
text { ttf "times.ttf" "Z A B " .3, 0
finish {
ambient .1
diffuse .8
reflection .75
metallic
brilliance 2
specular .9
roughness .009
phong .1
phong_size 10
translate <-1.375,-.3,0>
rotate y*90
rotate -y*90*clock
// environment
sphere {0,1111
pigment {rgb 1}
finish {ambient .5}
clipped_by {plane {z,0}}
zab <zab### [at] mail vt edu> wrote in message news:383F1D8A.29FB0F14@mail.vt.edu...
> Bob,
( Y/L )
(well ok,
polished
shiny,
run the
> camera {
> location <0,0,-3>
> look_at 0
> cylinder
> radius 20
> falloff 20
> tightness 0
> point_at <0,.2,0> }
> finish {
> ambient .1
> diffuse .8
> reflection .75
> metallic
> translate -1.375*x
> rotate y*90
> rotate -y*90*clock
sooner
> > Bob
