Is it possible to apply a transformation to a single vector? (for instance
if my vector is <1,0,0> and my transformation is transformation is
transform{translate <2,0,0> rotate 90*z}, I want to get <0,3,0>)
Daniel Pirch
dpi### [at] gmx net
Yes.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
> Yes.
Now, to start guessing what you need, instead of just what you asked. :-)
RT_M ( http://wombat.doc.ic.ac.uk/foldoc/foldoc.cgi?query=RTM )
Check the docs (be sure to check the language help, not the Windows help) for
vector functions.
instance
for
> vector functions.
Of course I've checked the docs before I posted my Question. I would never
ask before doing that :-)
But as vector functions, there are only vaxis_rotate, vcross, vnormalize and
vrotate. I asked if it's possible (and HOW) to transform a vector by an
already declared transformation. I can do this with an object:
#declare MyTrans = transform{translate ... rotate ... scale ... ...}
sphere{0,1 transform MyTrans}
But how can I do this with vector coordinates?
Thanks
Daniel Pirch
dpi### [at] gmx net
Daniel Pirch <dpi### [at] gmx net> wrote:
: I asked if it's possible (and HOW) to transform a vector by an
: already declared transformation.
It's not possible.
Check out http://users.erols.com/vansickl/macs.htm on that page there is a
vmatrix macro that applies matrix tranformations to vectors, which will
accomplish what you want to do. His explanaion of how the Matrix command works
will help out, too.
> instance
> for
> > vector functions.
> Thanks
> Daniel Pirch
> dpi### [at] gmx net
Josh English
eng### [at] spiritone com
icq 1946299
"Stress is when you wake up screaming and realize you haven't fallen asleep
yet."
It is not possible directly. You can facilitate the process by predeclarin
transformation vectors. Keep in mind the following:
object vector
scale <x,y,z> vector * <x,y,z>
rotate <x,y,z> vrotate(vector, <x,y,z>)
translate <x,y,z> vector + <x,y,z>
Now declare, for example, a rotation vector, and use it both after the 'rotate'
keyword and in the 'vrotate' function.
Margus
> Thanks
> Daniel Pirch
> dpi### [at] gmx net
This is why I made a patch which added a vtransform() function. :-)
vtransform(TRANSFORM, VECTOR)
Returns a vector which is the result of applying transformation
TRANSFORM to the vector VECTOR.
Forgot to add this:
I will be posting the source for this in povray.programming sometime
soon, and I have sent it to Ron Parker. The disadvantage is that you
will either have to use an unofficial version, or wait until it gets
into the official POV-Ray(if it ever does...maybe POV-Ray 3.5?).
Chris Huff wrote:
> Forgot to add this:
It almost seems to be a race now if there will be an updated version
of the SuperPatch before the official Pov v3.5 will become available.
Any comments Ron ?
Ken Tyler - 1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
This is inconsistent with the other vector functions:
vrotate(VECTOR, ROTATION)
vaxis_rotate(VECTOR, AXIS, ANGLE)
but:
: vtransform(TRANSFORM, VECTOR)
True, and I have been intending to change the order. To do that would be
very easy, and would only involve rearranging the code a little, I just
haven't done it yet.
On Wed, 20 Oct 1999 18:06:14 -0700, Ken wrote:
>Chris Huff wrote:
>> Forgot to add this:
> Any comments Ron ?
Sorry, went to Minneapolis for a few days there so this is the first I've
seen this message. :)
I have a semi-finished version of the Superpatch ready to go, but I've been
slacking off on the documentation. It doesn't have any of Chris's stuff in
it, though.
Ron Parker wrote:
> > Any comments Ron ?
Is that somewhere near Minnesota ?
> it, though.
Well glad to hear that you ain't slackin completely :~)
Semi-finished ?
It's the suburbs of the Mall of America.
>Semi-finished ?
All the code is there, but I haven't done the splash screen yet. Tiny little
things like that.
