POV-Ray : Newsgroups : povray.newusers : rotation vectors ?? Server Time
19 Oct 2026 09:16:26 EDT (-0400)
  rotation vectors ?? (Message 1 to 4 of 4)
Subject: rotation vectors ??
Date: 4 Aug 1999 15:44:36
Message: <37a89824@news.povray.org>
hello,
how does a rotation vector work?  i have no problem with
a simple degree rotation around an axis, such as:
box { <0,0,0>, <1,1,1> rotate y*180}
thats a half-circle rotation around the y axis... but what is
this:
box { <0,0,0>,<1,1,1> rotate <0,1,0> }
i tried various values, and i couldn't get a good feel for what
it does... it doesn't appear to be a simple rotation around
the y axis in radians....  i substituted pi for the 1 and didn't
get a 180 degree rotation.
thanks, miker
Subject: Re: rotation vectors ??
Date: 4 Aug 1999 15:58:20
Message: <37A89A9D.D23576B2@pacbell.net>
MR wrote:
> hello,
> this:
> thanks, miker
Rotate y*180 is simply short hand for rotate <0,180,0>. The rotations are taken
by order of xyz so if you specified rotate < 90, -45, 0> then pov would evaluate
this as rotate first +90 degrees around x-axis then -45 degrees around the y-axis.
You can also multiply rotation vectors like: rotate <0,90,0>*2 is equivelant to
rotate y*180. If you rotate by PI by the way you are simply rotating 3.1415
degrees and it would be hardly visible :)
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 5 Aug 1999 05:40:56
Message: <37a95c28@news.povray.org>
Note also that if you want to _first_ rotate about the y axis and _then_
about the x axis, you can do it this way:
  rotate <0,45,0> rotate <30,0,0>
Date: 10 Aug 1999 08:21:47
Message: <37B01968.CE971942@giwersworld.org>
	The rotation vector is in degrees. They rotate in the order of
appearance, first X then Y then Z. You can have multiple vectors
if you want to rotate them in a different order such as <0,Y,0>
<0,0,Z> <X,0,0> That will rotate in Y Z X order.
> this:
	That is a one degree rotation around Y that you most likely can
not see on the rendering.
	Since a box is 90 degree symetric, play with 30 and 45 degrees
to see the results.
<blink>-------please--don't-----------------</blink>
http://www.giwersworld.org/artii/
http://www.giwersworld.org/artiii/
Finally up on 99/06/22 updated 07/13
Download 'us-ascii' (1 KB)
