POV-Ray : Newsgroups : povray.newusers : default scene open and save dirs Server Time
18 Nov 2026 08:10:59 EST (-0500)
  default scene open and save dirs (Message 1 to 15 of 15)
Subject: default scene open and save dirs
Date: 9 Aug 1999 09:47:03
Message: <37AEDC0B.43CB9058@accn.org>
I have POV 3.1g for Win 95. How do I make an INI setting to set the
default scene file open and save directories?
Is there an INI setting for default height field directories?
Subject: Re: default scene open and save dirs
Date: 9 Aug 1999 11:44:29
Message: <37AEF77C.7AE71050@compuserve.com>
When looking for a height field, it looks in the include directories,
which usually are the directory with the scene file and the "Include"
directory with the standard include files. About the .ini settings, look
in pov.doc section 3.1.2 for a detailed explanation.
Date: 9 Aug 1999 12:29:29
Message: <37AF01B8.BD485AF@gci.net>
I have included the "images" directory in the povray.ini file. so that any
image rendered is is easily available.
Date: 9 Aug 1999 22:20:02
Message: <37AF8AB2.9DE70A7E@ndirect.co.uk>
Chuch
You can actually specify up to 10 different directory locations
in the ini file if I remember correctly.
Steve
%HAV-A-NICEDAY Error reading file mailto:sjl### [at] ndirectcouk
Date: 10 Aug 1999 09:20:30
Message: <37b0271e@news.povray.org>
Steve, this is unrelated entirely to the issue at hand, but since
I'm already in the mood...
Did you know your MIME charset is set to UTF-7?  You might find it
better to switch to something more commonly accepted, such as us-ascii,
for postings in English-speaking newsgroups.  Just a suggestion.  If
you need assistance locating the place where this is set, just let me
know.
Date: 10 Aug 1999 19:10:55
Message: <37B0B01E.AAC648AC@ndirect.co.uk>
Ron
is this better?
> know.
Steve
Date: 10 Aug 1999 20:38:25
Message: <slrn7r1hib.mo.parkerr@linux.parkerr.fwi.com>
On Wed, 11 Aug 1999 00:05:02 +0100, Steve <sjl### [at] ndirectcouk> wrote:
>Ron
>is this better?
Not really.  UTF-8 is a Unicode encoding, so unless you'll be doing a lot of
posting in weird languages, I'd suggest us-ascii or whatever the ISO Roman
standard is.  A quick survey of posters here suggests us-ascii is the local
preference.
Date: 10 Aug 1999 20:44:06
Message: <37B0C711.7B46EC23@pacbell.net>
> >Ron
> >is this better?
> preference.
  I have mine set to Western (ISO-8859-1) and have never heard anyone complain.
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 10 Aug 1999 20:51:14
Message: <slrn7r1iac.mo.parkerr@linux.parkerr.fwi.com>
On Tue, 10 Aug 1999 17:42:57 -0700, Ken <tyl### [at] pacbellnet> wrote:
>> >Ron
>> >is this better?
>> preference.
That's the one I was thinking of.  Actually, yours comes through as us-ascii,
but that must be a modification they're making behind the scenes.
Date: 10 Aug 1999 23:55:05
Message: <37B0F398.144E3375@ndirect.co.uk>
Cheers guys.
That should be it now.  In preferences in netscape under fonts,
encoding, I had Western selected which you would think is right.
But in the View menu I had utf-8 selected, (due to exchanging
emails with people in mexico who's special characters I couldn't
read).  Now I've set view to Western.
You would think that view would change the view and not the
outgoing message preferences.
Oh and before that works I've had to delete stuff from my
outgoing mail folder otherwise it just hangs. But I think I've
solved it now.
Steve
> >> >Ron
> >> >is this better?
> >> preference.
Steve
Date: 11 Aug 1999 07:00:13
Message: <37B157DF.E800AA2D@compuserve.com>
How did you solve it? I get the same problem when trying to send large
messages or attachments. The machine appears to hang, but if you let it
sit for a LONG time, it will eventually pop up an error message.
Date: 11 Aug 1999 09:48:26
Message: <37B16E48.FBBBD9BF@ndirect.co.uk>
If your problem is the same one as mine, the encoding.  I changed
the encoding in the view menu, and then pressed set default
character set from the same sub menu as the encoding list.  This
changes it properly.
Next to the encoding in your message it just says 7-bit,  set the
charater set to Western (ISO 8859-1)
Hope this helps.
Steve
Date: 11 Aug 1999 20:17:14
Message: <37B212AB.1179ED34@compuserve.com>
Ok, can you tell if it is working right? I had Western (ISO-8859-1), I
chose Set Default Character Set.
Date: 11 Aug 1999 20:23:39
Message: <37B213F2.A95C54C5@pacbell.net>
You are represened as having:
Content-Type:  text/plain; charset=us-ascii; x-mac-type="54455854";
               x-mac-creator="4D4F5353"
I don't know what all of the "x-mac" stuff is but the text/plain;
charset=us-ascii; part is correct for posting here so I think
you have it.
Ken Tyler
Date: 12 Aug 1999 04:15:17
Message: <37b28295@news.povray.org>
In article <37B213F2.A95C54C5@pacbell.net> , Ken <tyl### [at] pacbellnet>
> you have it.
It is Mac specific information (usually useful for attached files only, but
most newsreaders post it with everything for some reason) about the file
type and application that created it. The numbers are hexadecimal ASCII
codes (actually they are MacRoman character codes, not differences in the
lower 128 chars are minimal). If you translate it back you get: type =
"TEXT" = a plain text file, and creator = "MOSS" = Netscape Navigator.
    Thorsten
e-mail: tho### [at] trfde
