POV-Ray : Newsgroups : povray.newusers : rgb-cube and problems with media Server Time
18 Nov 2026 08:11:10 EST (-0500)
  rgb-cube and problems with media (Message 1 to 35 of 35)
Subject: rgb-cube and problems with media
Date: 24 Jul 1999 15:27:23
Message: <379a139b@news.povray.org>
Hi all!
I wanted to create a rgb-cube by putting together 10^3 smaller cubes
filled with an emission media. But there are some strange black
squares between the smaller cubes! Changing density, transmit and/or
filter values didn't help.
Does anyone know where the problem is??
Thanx in advance,
Daniel
Download 'rgb_cube.jpg' (30 KB) Download 'rgb_cube.pov.txt' (1 KB)
Preview of image 'rgb_cube.jpg'
Subject: Re: rgb-cube and problems with media
Date: 24 Jul 1999 15:34:31
Message: <379A14C0.2DC24F31@pacbell.net>
"Daniel Höfer" wrote:
> Hi all!
> Thanx in advance,
> Daniel
  I don't have time to look at your source now but try adding a
nax_trace_level in your global settings. I would start with
something like 30 or more with this many objects in the scene.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 24 Jul 1999 15:41:41
Message: <379A166E.B248C9E@pacbell.net>
> > Hi all!
> > Thanx in advance,
> > Daniel
I didn't see the image either until now. Um there is a problem in
pov called coincident surfaces where if you have transparent objects
whose faces occupy the same space like two boxes abutting each other
the raytracer cannot decide which surface belongs to which object.
The easiest way to avoid this is to seperate them by a tiny amount
or have them overlap by a tiny amount. If you overlap them you can
also use a merge operation to remove all of the inner surfaces.
Read up in the docs about csgs and coincident surfaces.
max_trace_level can still be an issue so don't hesitate adding
that to your scene too.
Ken Tyler
Date: 24 Jul 1999 15:55:36
Message: <379A1A02.D2B51081@aol.com>
Yes. there is a need for a higher max_trace_level. About 15 seems okay,
but 150 was better, somewhere inbetween perhaps then. I was going to say
it probably is coincident surfaces but the effect goes away, or appears
to anyway. The container objects being invisible to start with might not
make it obvious but still cause trouble, not sure. At the default trace
level it didn't show any change when I rescaled the boxes down slightly.
Ken wrote:
> > > Hi all!
> > > Thanx in advance,
> > > Daniel
> Ken Tyler
 mailto://inversez@aol.com?Subject=PoV-News
Date: 25 Jul 1999 09:49:27
Message: <379b15e7@news.povray.org>
I ran into a problem probably similar to yours.  I was trying to render
billowing smoke from something like a gasoline or oil fire.  There spheres I
was using for containers intersected (overlapped) each other without any
coincident surfaces.  The black areas I got were intermittent, but were
always confined to the INTERSECTION of the spheres, not coincident surfaces.
Moving the spheres around slightly got around the problem but it appears to
be a bug in POV.
In my experience, coincident surfaces tend to render a jittered imaged of
both textures, not a black spot.  How about this...  try it out 2 images
using just 2 boxes, side by side, and the texture that your using.  In one
image put one box about half way into the other and render it and in the
other, make the boxes just touch each other (coincident surfaces) and render
it.  Just to see what happens.
I'd try it and show you what I mean right now but I have a 6 day render
running right now with 4 days to go...
Daniel Höfer <Fur### [at] gmxde> wrote in message
news:379a139b@news.povray.org...
> Hi all!
> Thanx in advance,
> Daniel
Date: 25 Jul 1999 10:01:30
Message: <379b18ba@news.povray.org>
yep, a wrong value for max_trace_level was the reason,
but... this is still a mystery to me, because I know I didn't specify
ANY global_settings in the scene file yesterday, and POV-Ray still
produced garbage; today I tried again (I didn't make any changes) and
these black squares were gone! The only explanation I can imagine is
that POV-Ray crashed (which happens under Windoze95 quite often) and
after restarting POV-Ray it got a bit confused and somehow used a
wrong value (6 or 7?) for max_trace_level!?
Anyway, there is left a strange white vertical line in the middle of
the rendered picture. Does anyone know why?
btw I'm using version 3.1a.watcom.win32 [Pentium II optimized]
would it be possible to achieve the same result (without that white
line of course *g*) by using density_map / color_map on a _single_
cube instead?
Daniel
Download 'rgb_cube_2nd_try.jpg' (4 KB)
Preview of image 'rgb_cube_2nd_try.jpg'
Date: 25 Jul 1999 12:48:56
Message: <379B3FC1.A567748D@aol.com>
Fact is there are actually no coincident surfaces anyway in Daniels
script. The individual boxes are reduced to nine tenths their original
size (which if left unscaled would have been a potential problem,
maybe?). Being that much smaller however might be leading to some
trouble though, leaving gaps between each cube.
> be a bug in POV.
> > Hi all!
> > Thanx in advance,
> > Daniel
Date: 25 Jul 1999 12:50:31
Message: <379B4021.E6DCE1D4@aol.com>
I overlooked the scaling down of each individual box before. There is no
possibility of coincident surfaces.
> Ken wrote:
> > > > Hi all!
> > > > Thanx in advance,
> > > > Daniel
> > Ken Tyler
>   http://members.aol.com/inversez/homepage.htm
Date: 25 Jul 1999 12:56:30
Message: <379B4187.11B15F65@aol.com>
Shift your camera or rotate the entire cube itself (using a union) ever
so slightly and the vertical white line will disappear. It's a result of
the opposite front and back edges lining up.
> cube instead?
> Daniel
Date: 25 Jul 1999 13:06:53
Message: <379B439E.3F3A991@pacbell.net>
  The only problems I foresee with that would be the increased number
of intersection tests needed. This of course can be compensated for by
increasing the max trace level to an adequate amount.
Ken Tyler
Date: 25 Jul 1999 13:15:51
Message: <379c44b0.213476334@news.povray.org>
On Sun, 25 Jul 1999 16:00:36 +0200, "Daniel Höfer" <Fur### [at] gmxde> wrote:
  Hi, Daniel. This was a known bug and has been fixed since POV-Ray for
Windows v3.1d (we are now at v3.1g). As per Changes.txt that accompanies
POVWin:
o Fixed MAX_TRACE_LEVEL global not being re-initialized.
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 25 Jul 1999 13:33:07
Message: <379B49C3.82725247@pacbell.net>
> POVWin:
> Alan
Alan,
I was wondering what that bug meant. Now it makes sense - thanks.
Daniel,
There are also other important bug fixes since that version you
are using and you are encouraged to upgrade now to avoid other
similar problems.
Ken Tyler
Date: 25 Jul 1999 15:15:35
Message: <379b6257@news.povray.org>
ever
of
it helped a bit but there was still not much improvement... some dots
disappear, others reappear :-/
Date: 25 Jul 1999 20:30:14
Message: <379bac16@news.povray.org>
Maybe I'll go back and try the MaxTraceLevel on the smoke again to see if it
corrects the problem I was having.  (Didn't do anything with it because it
took too long to try and fix a problem and test!)
Thanks!
Bob Hughes <inv### [at] aolcom> wrote in message
news:379B3FC1.A567748D@aol.com...
spheres I
surfaces.
to
> > be a bug in POV.
of
one
render
> > > Hi all!
> > > Thanx in advance,
> > > Daniel
Date: 25 Jul 1999 21:31:40
Message: <379BBA50.A1DCDD9A@aol.com>
Not sure then, must be the version, I'm using 3.1g now. When I shifted
the camera or cube a bit it went completely away with a max_trace_level
of 30.
> ever
> of
Date: 26 Jul 1999 03:24:09
Message: <379c0b8f.9704779@204.213.191.228>
On Sun, 25 Jul 1999 20:28:46 -0400, "Dave Kreskowiak"
>Thanks!
Replacing the spheres with the equivalent blob (of threshold 0.0001 or
similar) will result in a much faster and smoother render, and you
won't need to set max_trace_level too high. (You might need the
'sturm' keyword if there're a lot of elements, but that's all.) I have
too overlooked this method in the past until Chris Colefax opened my
eyes.
Peter Popov
ICQ: 15002700
Date: 26 Jul 1999 04:57:39
Message: <379C2275.6CFA32C5@pacbell.net>
> >Thanks!
> eyes.
> Peter Popov
> ICQ: 15002700
Why would this be ?
Ken Tyler
Date: 26 Jul 1999 06:30:46
Message: <379c368e.20713716@204.213.191.228>
>> eyes.
>> Peter Popov
>> ICQ: 15002700
>Why would this be ?
I didn't believe it either before I did the tests. First of all,
multiple containers for multiple media proved a lot faster and
smoother than multiple media in a single container. The reason is
that, as the media are better enclosed each in its own container, a)
fewer unnecessary calculations are performed and b) media intervals
are closer together. Or, if we choose a container that's fast and
tightly fitting the media, then it's ok too. With that said, there are
three ways to go:
Union of spheres - fast, but has the problem of the high
max_trace_level needed. Also, if the spheres are closely packed, it
gets really slow. I think the reason is that every time the ray
enters/leaves a sphere and leaves/enters another, that segment of it
gets media sampled. Imagine what happens with 150 closely packed
spheres.
Merge of spheres - the problems typical for the union of spheres are
avoided, but merge is really slow as is.
Blob - the fastest of all three due to the bounding hierarchy and it
also avoids the problems that an union of spheres has. Also, each
element gets its media sampled separately (or so it seems) and this
yields a smoother image.
Peter Popov
ICQ: 15002700
Date: 26 Jul 1999 06:36:59
Message: <379C39BA.1810EE4C@pacbell.net>
> >> eyes.
> >> Peter Popov
> >> ICQ: 15002700
> >Why would this be ?
> three ways to go:
> spheres.
> Peter Popov
> ICQ: 15002700
 Then as I understand it Pov will treat the blob method as a single blob
entity with multiple cells as opposed to sphere which it must treat as
multiple entities. Yes ?
Ken Tyler
Date: 26 Jul 1999 07:03:06
Message: <379d3eff.22874591@204.213.191.228>
I can't tell more without a) peeking into the source code or b)
speculating. I wish to do neither therefore I will leave these musings
to the more qualified and take it as is.
Peter Popov
ICQ: 15002700
Date: 26 Jul 1999 07:48:32
Message: <379c4b10@news.povray.org>
Peter Popov <pet### [at] usanet> wrote:
: Merge of spheres - the problems typical for the union of spheres are
: avoided, but merge is really slow as is.
  Not really true. I wonder why this delusion persists.
  See http://www.students.tut.fi/~warp/povVFAQ.html#csgspeed
  (Everyone keeps saying that merge is (always) a lot slower than union,
but no-one has ever said why. Or even proved it.)
Date: 26 Jul 1999 08:30:11
Message: <379C5440.6E0039D1@pacbell.net>
  I have the following script that shows the merge operation taking 2 times
longer than a union of the same objects. I did recieve similar results as
you did with the example you gave but this example obviously takes longer
though I cannot offer an explaination as to why.
 Rendered at 120x100 no AA
 union time:  min. 3  sec. 9
 merge time:  min. 6  sec. 21
 union {
 // merge {
  #declare A =  0;
  #while ( A < 10)
     #declare B =  0;
     #while ( B < 10)
        #declare C =  0;
        #while ( C < 10)
           box { -.5, .5
       pigment { rgbf .9}
                 translate<-5,-5,-5>
                 translate <0.99*A, 0.99*B, 0.99*C>
        #declare C = C + 1;
     #declare B = B + 1;
  #declare A = A + 1;
global_settings { max_trace_level 85}
         camera { location<2.5,5,-15> look_at 0}
   light_source { <30,100,100> rgb 1}
   light_source { <-0,10,-200> rgb 1}
    background  { rgb 1}
Ken Tyler
Date: 26 Jul 1999 09:41:15
Message: <379c657b@news.povray.org>
I tried this scene in this Sparcstation 4 rendering at 160x120 (it's a
very slow machine...). I got these results:
  Union:
    Total Time:    0 hours 13 minutes  13.0 seconds (793 seconds)
  Merge:
    Total Time:    0 hours 11 minutes  50.0 seconds (710 seconds)
  I also tried with a simplified version of the scene. I scaled the boxes by
2 and added '2' to each index (instead of '1'). Rendering at 320x240 I got:
  Union:
    Total Time:    0 hours 11 minutes  59.0 seconds (719 seconds)
  Merge:
    Total Time:    0 hours  4 minutes  25.0 seconds (265 seconds)
Date: 26 Jul 1999 09:57:23
Message: <379c6943@news.povray.org>
Black spots (actually transparent spots) are fairly common.  They usually
happen when you have an intersection involving coincident surfaces.  POV
will find one or the other surface, then determine that that surface is
"outside" the other surface and ignore that intersection.  It then goes
on to find another intersection, but because it always starts looking at
a distance of EPSILON along the ray from the last intersection, it misses
the second surface at that point entirely, leaving a transparent spot
that could show up as black under the right circumstances.
Date: 26 Jul 1999 10:03:41
Message: <379c6abd@news.povray.org>
If we look only at the time to calculate intersections, merge is slower
than union because it has to check each intersection to see if it's inside
another element.  Thus merge might be slower than union if you use a simple
texture like "texture {pigment {color rgbt .8} finish{ambient .8}}" with no
or maybe only a single light source.
However, in the real world many of us use very complex textures with
reflection and complex lighting.  Calculating the various patterns, and
especially casting all those shadow rays and reflection rays, tends to dwarf
the time it takes to test intersections for insideness.
Date: 26 Jul 1999 11:48:09
Message: <379d81fd.40027921@204.213.191.228>
Yeah, I have the VFAQ, Warp. I was referring to this particular case,
namely 100 or more transparent media-filled spheres. I agree that
merge can be faster in the some cases, particularly when there are a
lot of transparent objects close together (like 100-200 transparent
surfaces) and media. This is, you should agree, a rare occasion.
Peter Popov
ICQ: 15002700
Date: 26 Jul 1999 23:33:36
Message: <379D27DF.3C3C7391@pacbell.net>
  I would be interested in seeing your windows comarison. I ran one more
test using the previous test parmeters with the addition of media and
rendered at 640x480 to increase the render time. The difference between
merge and union was less than 5% for a 3.5 hour render time. The merge was
slightly faster.
Ken Tyler
Date: 27 Jul 1999 02:54:08
Message: <379d5790@news.povray.org>
:   I would be interested in seeing your windows comarison.
  Yes, it probably is system and/or compiler dependant.
  Anyways, with semitransparent objects and lots of inner surfaces (which
are removed when merged), the merge operation is often (although not always)
faster than the union.
  I can easyly believe that with non-transparent objects merge may be a little
slower than union.
Date: 27 Jul 1999 02:56:46
Message: <379D57F8.A4B889E0@aol.com>
I just had to laugh inwardly about all this talk in the newusers group.
It sounds so much like some advanced topic going on, for which there is
the appropriate group.
Date: 27 Jul 1999 03:09:28
Message: <379d5b28@news.povray.org>
Bob Hughes <inv### [at] aolcom> wrote:
: I just had to laugh inwardly about all this talk in the newusers group.
: It sounds so much like some advanced topic going on, for which there is
: the appropriate group.
  Perhaps we should learn how to use the followup-to -field.
Date: 27 Jul 1999 03:21:30
Message: <379D5D40.BC98A484@pacbell.net>
...Or perhaps a few newbies will get the concept being discussed in this
thread so firmly pounded into thier heads they will never have to ask
similar questions again...
Ken Tyler
Subject: Re: Getting there from here via Followup-To:
Date: 27 Jul 1999 21:04:04
Message: <379e5704@news.povray.org>
Hmmm, now this seems right. Original Group:povray.advanced-users (for
example) was left the same. Then the second header position (in Netscape
anyway) was set to Followup-To:povray.newusers and voila! I am now here,
from there. Everyone got that now? Stand back and watch the
mis-postings!
Please note that the intent is cause a redirection of message replies
into a different, possibly more appropriate newsgroup.
Bob Hughes wrote:
> Wups! Well glad you said so, I looked at this and thought "Hey, OK! It
> works."
> What I had done is select Followup To: in a drop-down list where the
> povray.newusers was showing and then added this advanced group in after
> a Group: heading. Think I should have done the opposite. Will do that to
> this posting and send back to the newuser group under an appropriate
> title. Maybe...
> Ron Parker wrote:
> > On Tue, 27 Jul 1999 15:41:48 -0500, Bob Hughes wrote:
> > >Please forgive me if I've totally messed things up here but this is my
> > >first ever attempt at a "follow up" which Nieminen M. had mentioned.
> > >And if it works this might be as good a place as any to place this post.
> > It didn't work.  It might look like it did, but it didn't.  You need to
> > set the Followup-To: header or it will default to sending followups
> > back to newusers.  slrn makes this easy; I don't know how easy it is with
> > Netscape.
Date: 27 Jul 1999 21:10:01
Message: <379e5869@news.povray.org>
Ah ha! Seems my restrained worry was justified. I was expecting this
post to get out into the mainstream of the group for which it was
redirected to. And here I am back at the original thread where I had
begun my investigation of the Followup-To:
Well, to put an end of my feable tamperings I will now stop and simply
watch to see what happens because of this as others reply to the posts I
did here.
May have started a rip in the fabric of space and newsgroups, forgive me
please if I have.
> mis-postings!
> > works."
> > title. Maybe...
> > > Netscape.
> >  omniVERSE: beyond the universe
Date: 28 Jul 1999 01:21:06
Message: <379E9243.CC90D04F@pacbell.net>
> did here.
> please if I have.
 If you had anything to add to this thread I suggest you just add it now, here,
otherwise I think it is pretty much dead :)
Ken Tyler
Date: 30 Jul 1999 06:45:57
Message: <37A18041.D8FFDEB@ndirect.co.uk>
bob this should go to advanced
Bob Hughes wrote:
Steve
%HAV-A-NICEDAY Error reading file mailto:sjl### [at] ndirectcouk
