POV-Ray : Newsgroups : povray.newusers : PoV World Map update Server Time
19 Oct 2026 10:27:35 EDT (-0400)
  PoV World Map update (Message 1 to 5 of 5)
Subject: PoV World Map update
Date: 24 Jun 1999 22:22:48
Message: <3772E7F6.10E9B047@aol.com>
http://members.aol.com/wrld0rigin/povwrldjpg.htm
Please try to click on either, or both, North America and/or Europe for closeup views.
If you click elsewhere on one of the faces of the world you will go to the coordinate
submission page. Clicking on the title will take you to a current list of people.
Keep in mind there has been no new additions, if you haven't sent your location in,
please think about doing so.
Thankyou.
 mailto://inversez@aol.com?Subject=PoV-News
Subject: Re: PoV World Map update
Date: 25 Jun 1999 22:02:33
Message: <B39A7204-5FE38@147.109.83.2>
>closeup views.
Bloody Northern Hemisphere bias :-)
>coordinate
people.
>location in,
I tried:
Latitude choices: Northern Hemisphere, No Value
(Southern Hemisphere is on the page rather than in the menu, other menus
suffer the same problem.)
I'm at:
42deg 40min S, 147deg 20min E
I use POV Ray:
Not Enough
(Not enough time)
I'm not an IMP team member.
So, anyone further south?
Have Fun
Martin
Owner/Operator - Tesseract Computing
<hyp### [at] tesseractcomau> or just reply.
Computer Systems Officer - Tourism Tasmania
<Mar### [at] tourismtasgovau>
I speak for me.
Date: 25 Jun 1999 23:49:14
Message: <B39A8B05-BDF6A@147.109.83.2>
On Sat, 26 Jun 1999 12:03 PM, Martin Crisp
>>closeup views.
[snip]
>I tried:
Browser error...
Cyberdog choked, Netscrape fine....
Have Fun
Martin
<hypercube 'at' tesseract.com.au> or just reply.
<Martin.Crisp 'at' tourism.tas.gov.au>
I speak for me.
Date: 26 Jun 1999 04:31:46
Message: <37748FEB.71DAA10B@aol.com>
Yes, I knew I should have mentioned that the image map I made for the browsers is
supposed to be for Netscape 2.* or higher and I'm guessing about IE 3.* and higher
also.
It's just that I went on the typical naive assumption that most people would be using
one which is compatible enough to do the linking. I wouldn't dare use Java Script but
I
might possibly do the more usual "links" method instead, especially if several people
can't use the image map as is. Aw heck, I'll try links to those zoomed in views
elsewhere anyway. I don't want frustration to occur if I can help it.
Btw, there's going to be a magnified look at Australia later. Main reason is because
of
the Melbourne folks. So don't get discouraged you upsidedowners (just kidding), it's
just that there will always be the likelyhood of such close markers that won't always
be
separable so don't expect zooms of zooms please.
> >>closeup views.
> [snip]
> >I tried:
> Browser error...
> Have Fun
> Martin
> I speak for me.
Date: 29 Jun 1999 23:26:35
Message: <37798e6b@news.povray.org>
Bob wrote in message <37748FEB.71DAA10B@aol.com>...
Hi again Bob, sorry to be taking so much of your attention ...
browsers is
and higher also.
The weird thing is most of that stuff works fine in Cyberdog (it doesn't
like progressive JPEGs, nested tables or JavaScript, and animated GIFs
need to be done 'right' as far as refresh options or they look awful)
would be using
Java Script but I
Image map worked fine.
several people
in views
Methinks you've grabbed the wrong end of the stick - My problem was that
once on the location submission page, the pop-up menus were only getting
the first list entry, the rest were being dumped onto the page.
Again I dunno why Cyberdog would behave this way and Netscrape properly
(first time I've seen CD do it, so I assumed that it was the page...),
might have a look at the source...
Ah-ha - Each of your menus has items that look like this:
<Option>value<BR>
Lose the <BR> and Cyberdog (and possibly other finicky browsers) should
be fine - least that's the major difference between your menus and, say,
altavista's.
reason is because of
Excellent :-)
kidding), it's
Dunno that I'd do it for them :-)
(parochialism alive and well down under)
that won't always be
Not good enough! :-)
Have Fun
Martin
<Spa### [at] tesseractcomau> is a valid address
If you prefer mnemonic addresses you can use:
<Martin 'at' tesseract.com.au> or <Martin.Crisp 'at' Tourism.tas.gov.au>
My opinions should not be taken as indicative of Tourism Tasmania's
opinions
