![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ok, say I set up a scene, and place the camera at <0, 0, -30> and look_at is set
to <0,0,0>
How many units are across the "screen" (so to speak)?
If I put something at <-30,0,0>, will it be on the far left of the screen?
Thanks,
Igor
Hinki's Place
http://hinki.8m.com/
Wild Planet
http://wildplanet.8m.com/
Fractalography
http://fractalography.8m.com/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Another question on co-ordinates and space
Date: 30 Mar 1999 09:19:21
Message: <3700DD4C.9F5028A8@aol.com>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What I know of it (which isn't much) is, if you have a camera at -10*z
looking at the origin (<0,0,0>) using 'angle' 22.6 you get 4 POV units
wide by 3 POV units high approximately.
And if using 'direction' instead of angle for the "lens zoom" setting
you would need 'direction' 10/3 (ten divided by 3) to approximate a
'angle' 22.6 (the old POV-Ray camera default).
So 'direction' 10/3 is about the same area as angle 22.6.
In your example to get that -30*x object to show at the far left when
the camera is located at -30*z would require 'angle 90' or so. A very
wide lens setting. Keep in mind this is the default 'perspective'
camera.
Anyhow, dividing 30 by 10 (distance) you get 3 times the area. These
aren't exact numbers at all remember, only close.
Hope this is a start of help about this.
> to <0,0,0>
> Thanks,
> Igor
> Hinki's Place
> Wild Planet
> Fractalography
mailto:inv### [at] aol com?Subject=PoV-News
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If your camera angle is at 90, then yes, an object at <-30,0,0> will be at the very
left edge of the window.
If you use an angle of 60, then the left edge will be at
tan(angle/2)*distancefromlocationtolook_at or -17.3205in this case.
Josh English
eng### [at] spiritone com
> to <0,0,0>
> Thanks,
> Igor
> Hinki's Place
> Wild Planet
> Fractalography
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
