POV-Ray : Newsgroups : povray.newusers : ambient Server Time
7 May 2026 05:48:28 EDT (-0400)
  ambient (Message 1 to 5 of 5)
Subject: ambient
Date: 25 Feb 1999 06:18:46
Message: <36d53196.0@news.povray.org>
Is it a simple way to increase or scale all the ambient values i put in my
finish statements (for all my objects) ?
Laurent Bassompierre
Subject: Re: ambient
Date: 25 Feb 1999 07:10:56
Message: <36D53CB8.C345FBB5@aol.com>
global_settings {ambient_light float )
Date: 25 Feb 1999 07:11:25
Message: <36d53ded.0@news.povray.org>
bassompierre laurent <lba### [at] ubifr> wrote:
: Is it a simple way to increase or scale all the ambient values i put in my
: finish statements (for all my objects) ?
  Actually yes. For example, if you want to double the ambient values, you
can type:
global_settings { ambient 2 }
  If you want to halve the ambient values, you can type respectively:
global_settings { ambient .5 }
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp -*/
Date: 26 Feb 1999 20:09:57
Message: <36D745B8.1D07A740@aol.com>
And don't forget, the color vector can be adjusted as well:
 global_settings {
  ambient_light <1.2,1.45,1.6> //skylight
From the DOC:
Ambient = Finish_Ambient * Global_Ambient_Light_Source
The global ambient values are multiplied with every individual ambient
in each finish.
> can type:
 mailto:inv### [at] aolcom?PoV
Date: 27 Feb 1999 21:08:08
Message: <36D8CFB5.79A88237@ij.net>
	You have two answers on global settings but I have not found
that satisfactory as yet. Get your assumed_gamma to match your
monitor first.
	Then any vector can have a global change by x.y*<a,b,c> that
works for ambient, camera location and so forth.
	Also if you find colors odd with light changes try ambient
<a,b,c> where <a,b,c> is the same as the color of the object.
