POV-Ray : Newsgroups : povray.newusers : #fopen and #read troubles Server Time
7 May 2026 05:48:01 EDT (-0400)
  #fopen and #read troubles (Message 1 to 4 of 4)
Subject: #fopen and #read troubles
Date: 22 Feb 1999 13:08:00
Message: <36D19BA3.7A40@interport.net>
I am having a hard time getting
#fopen/#read in version 3.1a, MS-DOS,
to work like I expect.
Can anybody take the time to tell me
what is wrong with the following?
My scene file looks like this:
#declare R0=4;
#declare n=0;
#fopen PathFile "8_2_11a.dat" read
union{
  #while (defined(PathFile))
    #read (PathFile, xx, yy, zz)
    sphere{<xx,yy,zz>,R0}
    #declare n=n+1;
  texture{Path0_tex}
#fclose(PathFile)
the file 8_2_11.dat looks like this:
33.233795,-89.718941,32.003906,
69.594879,7.195656,-8.293076,
-50.495758,101.845917,-35.317207,
-80.023605,68.077423,-19.941116,
-5.417503,16.675690,-6.008537,
8.868011,30.237213,-12.376640,
2.900688,23.989487,-88.818932,
60.252716,79.018677,-35.281281,
24.128769,107.299164,-43.336853,
6.070969,89.397400,-34.994446,
12.038376,95.645020,41.448578,
-20.985031,62.907074,56.705780,
-32.920090,50.411514,-96.181236,
-86.662827,-2.535072,7.846359
I am consistently getting this error message
from POVRay (3.1a, MSDOS):
  #while
(defined(PathFile))
    #read
(PathFile,xx20
 33.233795,yy,
<----ERROR
 8_2_11a.dat:2: error: float, vector, or string literal expected
 but ,  found instead.
Subject: Re: #fopen and #read troubles
Date: 22 Feb 1999 18:36:46
Message: <36d1ea0e.0@news.povray.org>
david sharp schrieb in Nachricht <36D### [at] interportnet>...
[...snip...]
><----ERROR
 POV-Ray is propably right. It propably expects to see values which are not
separated by commas in your .dat file. I haven't tried this, but could this
be the matter?
Rudy Velthuis
Date: 22 Feb 1999 20:31:54
Message: <36D203B4.808@interport.net>
Rudy Velthuis wrote:
> [...snip...]
> ><----ERROR
> not separated by commas in your .dat file. I haven't tried this, but
> could this be the matter?
i have tried replacing the commas with spaces and, amazingly
(ironically?) getting the same error message. Anyway, the way
i read the docs, they specifically say fields in the data
should be separated by commas.
Date: 22 Feb 1999 23:17:02
Message: <36D22A67.668@interport.net>
heh. The code I posted worked after changing the filename for the
data. I think this is because the file I thought I was playing with
(putting in commas, removing them, etc) was a different file from the
one #read was reading.
Kind of humiliating, I must say
