POV-Ray : Newsgroups : povray.newusers : Help Please!:Camera inside solid object and media Server Time
18 Nov 2026 08:52:48 EST (-0500)
  Help Please!:Camera inside solid object and media (Message 1 to 5 of 5)
Subject: Help Please!:Camera inside solid object and media
Date: 26 Jan 1999 06:22:21
Message: <36ADA58B.78D7@jet.es>
Hi, Iīm new to POV-ray and raytracing in general (downloaded the
program 10 days ago), and I have a relative lack of knowledge even of
the basic foundations of raytracing and optics in general.
  I have a question that arised from reading the 3.1a Main
Documentation. It is about putting a camera inside a solid (non-hollow)
object, and not being able to render media effects. Does this mean that
if I put a camera inside a solid, transparent object (Like a crystal
block), and I have some media defined outside of this object my camera
will not see it? The documents talk about this in EMPTY AND SOLID
OBJECTS, and it alludes to a "pitfall in the empty/solid object
implementation", but I am confused with the explanations that are
offered. For example, it is said that "In order to be able to put solid
objects inside a media or fog, a test has to be made for every ray that
passes through the media. If this ray travels through a solid object the
media will not be calculated". But that means that the media wonīt be
calculated in the part that the ray travels inside the object, but in
that point the ray can have information already about media outside the
object, am I wrong?
  Also, I did a test scene in which I placed a crystal block with ground
fog, and a camera inside of the block, and I could see the fog! Isnīt
this the opposite to what is said in the Main Documentation in the
section FOG AND HOLLOW OBJECTS?
  Please, help me in this. It is really frustrating not to be able to
find an answer to this (apparently) easy questions.
  Thanks!
Subject: Re: CAN ANYBODY HELP, PLEASE?
Date: 26 Jan 1999 16:37:01
Message: <36AE3597.3EFB@jet.es>
> object, am I wrong?
>   Thanks!
Date: 27 Jan 1999 01:15:12
Message: <36AEAEF1.FAB70792@virginia.edu>
Check the VFAQ
http://www.students.tut.fi/~warp/povVFAQ.html#hollowobjects
Steve
> > object, am I wrong?
> >   Thanks!
Date: 27 Jan 1999 06:24:03
Message: <36AEF76F.63A5@jet.es>
Stephen Lavedas wrote:
> Check the VFAQ
> Steve
> > > object, am I wrong?
> > >   Thanks!
  Thanks for your help, Steve. The link that you sent me too has taught
me a couple things that I didnīt know about solid and hollow objects
(Like the fact that POV doesnīt handle solid objects as anything else
than closed surfaces that donīt allow media and fog to get inside)
  However, there is still a couple doubts that come from the SOLID AND
EMPTY OBJECTS section in the POV documentation. In fact, it is
emphasized about the need to be careful when we have a camera inside a
non-hollow (solid) object. What difference does it make if the camera is
inside or outside? For example, if the object was solid but transparent,
and we had the camera outside, the media wouldnīt work either as
expected. Am I wrong?
  Once more, thanks for your help!
  Ruben
Subject: Re: THANKS!
Date: 27 Jan 1999 06:24:23
Message: <36AEF77F.2EE7@jet.es>
> Check the VFAQ
> Steve
> > > object, am I wrong?
> > >   Thanks!
  Ruben
