POV-Ray : Newsgroups : povray.newusers : Logo on object? Server Time
10 Aug 2025 02:42:34 EDT (-0400)
  Logo on object? (Message 1 to 2 of 2)
Subject: Logo on object?
Date: 20 Aug 1998 10:11:16
Message: <35DC2073.847B51AC@fmf.ml.org>
Hello,
This is probably in the manuals, but I haven't finished reading yet. My
question is
this:
I made a barrel in POV-ray using SOR. Then I applied some texture to it.
But how
do I get an image from the biohazard logo on the barrel just only once?
Do I have
to apply 2 textures of some kind with the biohazard logo applied only
'once'?
Thanks in advance.
This message was brought to you by:
 _____          _   _       /--- ,-.-. \
|  __ \        | | (_)     |  |  | | |  |
| |__) |__  ___| |_ _  ___  \ |  | | | /
|  ___/ _ \/ __| __| |/ _ \
| |  | (_) \__ \ |_| |  __/
|_|   \___/|___/\__|_|\___| aka Stefan Postema
 Address: http://fmf.ml.org/~postie
          http://huizen.dds.nl/~nicap
          mailto:csg### [at] wingrugnl
Subject: Re: Logo on object? correction
Date: 21 Aug 1998 01:36:34
Message: <35DCEAE7.38C337C1@pacbell.net>
Postie wrote:
> Hello,
> question is
> this:
> But how
> Do I have
> 'once'?
> Thanks in advance.
> | |  | (_) \__ \ |_| |  __/
  This one is pretty easy.
I'm going to presume your barrel is 10 units tall 3.5 units wide
and is standing on a plane located at y*0.
object{Barrel
  texture{
   pigment{your pigment}
    finish{your finish}
     normal{?}
      pigment{
        image_map{gif "biohazard.gif" interpolate 2 once}
         translate -0.5     // this will center the image
          scale 1.5          // this will give your label a size of 1.5 x 1.5
           translate y*7   // this will put the image at the top end of the
barrel
This should work. Give it a try.
Happy Rendering !
K.Tyler
