POV-Ray : Newsgroups : povray.newusers : newbie question Server Time
19 Oct 2026 18:19:11 EDT (-0400)
  newbie question (Message 1 to 5 of 5)
Subject: newbie question
Date: 1 Feb 1998 12:31:34
Message: <34d4be8e.0@news.povray.org>
is there a way to make an object and call it when u need it.  like if you
are making a room full of chairs.  instead of making 100 chairs, you could
make one chair and just call it 100 times(about 100 times easier).  this is
called a pre-fab (prefabricated design)
please reply via email thanks
                                    joe conklin
http://www.geocities.com/siliconvalley/horizon/7128
visit and sign the book
remove "spam" to reply
        Joe
Subject: Re: newbie question
Date: 2 Feb 1998 00:38:52
Message: <34d56945.0@news.povray.org>
Joe Conklin wrote in message <34d4be8e.0@news.povray.org>...
>                                    joe conklin
>        Joe
    I'm new myself, but I believe I can help a little.
    I'm pretty darn sure there is a way to create an object and then use it as a
pre-fab.  I think it has something to do with the
define statement. . .
                                            Good luck,
                                            Ian
Date: 2 Feb 1998 00:56:17
Message: <34d56d59.0@news.povray.org>
>I think it has something to do with the #define statement. . .
>                                            Good luck,
>                                            Ian
    Uh, did I say #define?  I meant #declare!  Sheesh!  C++ is rubbing off on me!!!
                                                I feel stupid,
                                                Ian
Date: 2 Feb 1998 18:46:54
Message: <34d667e8.0@news.povray.org>
Hello Ian
As you have guessed, the solution uses #declare. You can define an abject as
follows :
#declare Object_Foo = object {
... a lot of statements to create you object here ...
then use it by writing :
// a yellow foo object located at  <0, 100, 0>
object {
  Object_Foo
    color Yellow
  translate <0, 100, 0>
// now a red one located at <100, 0, 0> and rotated a bit
object {
  Object_Foo
    color Red
  rotate z*30
  translate <100, 0, 0>
To replicate a lot of objects on a regular basis, you can use the loop
statements, so that creating a theater with all its seats will not require
10,000 lines of POV source code but just a small amount of looping code :-)
I have not validated this snippet but I have written stuff similar to it,
and it works.
Hope this will help
Eric
Date: 8 Feb 1970 13:49:13
Message: <34ddfe29.0@news.povray.org>
Ian (JBu### [at] sceinetcom) wrote:
:     Uh, did I say #define?  I meant #declare!  Sheesh!  C++ is rubbing off on me!!!
  Every time I code in C and I want to type a #define -line, I instead
type a #declare line... I think I have used too much povray... ;)
                                                              - Warp. -
