POV-Ray : Newsgroups : povray.newusers : isosurface in mirror Server Time
26 Mar 2026 15:19:04 EDT (-0400)
  isosurface in mirror (Message 1 to 10 of 33)
Subject: isosurface in mirror
Date: 10 Oct 2006 08:21:32
Message: <20061010142058.4e43a12b.not@available.yet>
hello,
currently I render a scene with an isosurface and a mirror showing that isosurface.
isosurface is created like:
difference{
	object { isosurface1_containedby_box }
	object {
		isosurface2_containedby_box
		translate y*-value
	rotate x*90
the result is a nearly planar surface.
the mirror has reflection 0.8.
but now backside of isosurface is invisible in mirror.
I heared about keyword <<hollow>>.
does it come in play here? if yes, where do I have to place it? what else can I do?
thanks in advance
Subject: Re: isosurface in mirror
Date: 10 Oct 2006 08:43:31
Message: <452b9573@news.povray.org>
  I honestly don't understand how it would possibly be related.
  Anyways, 'hollow' is only related to media and fog, nothing else.
Date: 10 Oct 2006 09:14:35
Message: <20061010151403.af26ba37.not@available.yet>
On 10 Oct 2006 08:43:31 -0400
it was a disstressed idea to solve the problem.
any other ideas?
Date: 10 Oct 2006 09:22:07
Message: <6eaN4PA+45KFFwoB@econym.demon.co.uk>
Wasn't it marabou who wrote:
>hello,
>isosurface.
>difference{
>       object {
>               translate y*-value
>       rotate x*90
>do?
No, it's nothing to do with "hollow". That's something completely
different.
It's more likely to be the fact that you need to specify a sensible
max_trace count, or use all_intersections, in any isosurface that's
involved in CSG operations (like your "difference").
It's also possible, but unlikely, that the max_gradient required for
rays travelling in the reflected direction is greater than that required
in the forward view. Check the "messages" for max_gradient warnings.
Mike Williams
Gentleman of Leisure
Date: 10 Oct 2006 09:26:47
Message: <452b9f97$1@news.povray.org>
1- what do you mean by invisible ...
2 - did you use the contained_by or clipped by statement ...if  clipped by
statement then its 'normal'
3 - i think you probleme comes from contained box ..you should look at it if
a mistake doents occurs ..
4 - did the back of you difference exists ?
news:200### [at] availableyet...
> hello,
isosurface.
> difference{
> object {
> translate y*-value
> rotate x*90
can I do?
> thanks in advance
Date: 10 Oct 2006 09:28:28
Message: <452b9ffc$1@news.povray.org>
erratum ..i forget maxtrace level as mike tells you ...
news:452b9f97$1@news.povray.org...
if
> > hello,
> isosurface.
> > difference{
> > object {
> > translate y*-value
> > rotate x*90
else
> can I do?
> > thanks in advance
Subject: Re: isosurface in mirror; enhanced description
Date: 10 Oct 2006 10:18:09
Message: <20061010161737.3c36c97a.not@available.yet>
I send an image to p.b.images that shows my problem.
I do not have any max_gradient messages, because they are fixed, yet.
the only object is rotated in steps of 90 degrees.
one time the object is visible in mirror one time not.
reference:
news.povray.org povray.binaries.images:101834
Date: 10 Oct 2006 10:35:24
Message: <452bafac$1@news.povray.org>
"marabou" <not### [at] availableyet> wrote in message
     Have you tried changing your background colour to see if there's a
difference?
    ~Steve~
> thanks in advance
Date: 10 Oct 2006 10:55:15
Message: <20061010165443.68e69747.not@available.yet>
On Tue, 10 Oct 2006 15:35:01 +0100
> difference?
you mean that colors of background and object are the same? I tried yet, but it makes
not difference.
cool tip!
Date: 10 Oct 2006 11:03:28
Message: <452bb640$1@news.povray.org>
Yep strange ...i'm still convince that your back is not define ..did the
reflection works if you remove your difference ..
i mean if you anly reflect your object A , or object B alone..
> > difference?
but it makes not difference.
> cool tip!
