POV-Ray : Newsgroups : povray.newusers : Povray and Blender Server Time
17 Nov 2026 21:33:16 EST (-0500)
  Povray and Blender (Message 1 to 21 of 21)
Subject: Povray and Blender
Date: 15 Jul 2007 07:45:42
Message: <1o3ef1sgdydrm.126fjak6zejxf$.dlg@40tude.net>
I'm going mad!
I want to use blender to model some mesh, and then render it using pov.
Now i've tried to export it using wavefront, using povanim, using a lot of
tools but every time i get awful results, especially with the normals.
For example: consider a cylinder. I've made it in blender, i've smoothed,
and render it. It goes well.
Now, every exports i made, the results is like this:
http://img370.imageshack.us/img370/6343/mainfg4.jpg
Something is a little better, something not, anyway there's always an ugly
black area away from the light source.
Any Idea? How can i use shaded mesh from blender to pov?
Thanks.
Subject: Re: Povray and Blender
Date: 15 Jul 2007 11:15:13
Message: <469a3a01@news.povray.org>
PdG nous apporta ses lumieres en ce 2007/07/15 07:45:
> I'm going mad!
> Thanks.
Maybe some normals are pointing "inside" the object instead of outward.
Any luck if you don't use shaded mesh?
Did you try PoseRay?
Anyway, unless your mesh is very fine, there will be some artefacts near the
terminator, where the incident light comes at a grazing angle.
You can minimize that by carefully placing the light or by using some small
rotation of the mesh.
You know you've been raytracing too long when you've tried rendering hair with
each strand as an object.
Quietly Watching
Date: 15 Jul 2007 11:32:06
Message: <469a3df6@news.povray.org>
  It's difficult to say anything from that image. Could you create a better
image which shows clearly the problem?
Date: 15 Jul 2007 12:21:59
Message: <hclp4o3o0v9x$.1cv0uhno93pe9$.dlg@40tude.net>
Look here
http://img68.imageshack.us/img68/7717/diokvu6.jpg
two renders of the same object: the left made with povray, the right made
with blender... left has a ugly and wrong black area.. i've used only a
spot light, there's noting that drop shadows so why that area is so black?
Date: 15 Jul 2007 13:19:43
Message: <469a572f$1@news.povray.org>
PdG nous apporta ses lumieres en ce 2007/07/15 12:21:
> Look here
The end of the cylinder looks as black in one view as in the other.
It looks like the light source is very close to the object, making the far end
receiving light at a very shalow angle.
Keep your eyes wide open before marriage, half shut afterwards.
Benjamin Franklin
Date: 15 Jul 2007 13:26:24
Message: <469a58c0@news.povray.org>
  I see no relevant difference in the two images.
Date: 15 Jul 2007 14:24:06
Message: <kvn7dy4h6ats$.1fyp2k56a519u$.dlg@40tude.net>
if i use solid mesh it seems to works, but i need shaded mesh..
i've flipped the normals, but...
http://img377.imageshack.us/img377/8940/uglycc7.jpg
Date: 15 Jul 2007 14:26:53
Message: <16itu16pv8aso.v8gz2kl1estk$.dlg@40tude.net>
i've putted the light far.. and the effects looks like a spot light, not a
point light.. the cylinder become black with no smooth.. like if the lights
stops after these pixels.
Anyway, here the source.
// File produced by AccuTrans 3D
#version 3.5;
global_settings { assumed_gamma 2.2 }
  location <1.0, 1.5, -12.0>
  look_at <0, 0, 0>
light_source { <0, 12.0, -30.0> color rgb<1, 1, 1> }
light_source {
  <0, 0, -24.0>
  color rgb<1, 1, 1>
  spotlight
  radius 150
  falloff 20
  tightness 10
  point_at <0, 0, 0>
background { color rgb<0.5765, 0.6863, 0.8549> }
// Layer: _null_
  object {
   union {
mesh2 {
  vertex_vectors {
    66
    <0.707107, -3.0, 0.707107>,
    <0.83147, -3.0, 0.55557>,
    <0.92388, -3.0, 0.382683>,
    <0.980785, -3.0, 0.19509>,
    <1.0, -3.0, 0>,
    <0.980785, -3.0, -0.19509>,
    <0.92388, -3.0, -0.382683>,
    <0.83147, -3.0, -0.55557>,
    <0.707107, -3.0, -0.707107>,
    <0.55557, -3.0, -0.83147>,
    <0.382683, -3.0, -0.92388>,
    <0.19509, -3.0, -0.980785>,
    <0, -3.0, -1.0>,
    <-0.195091, -3.0, -0.980785>,
    <-0.382684, -3.0, -0.923879>,
    <-0.555571, -3.0, -0.831469>,
    <-0.707107, -3.0, -0.707106>,
    <-0.83147, -3.0, -0.55557>,
    <-0.92388, -3.0, -0.382683>,
    <-0.980785, -3.0, -0.19509>,
    <-1.0, -3.0, 0.000001>,
    <-0.980785, -3.0, 0.195091>,
    <-0.923879, -3.0, 0.382684>,
    <-0.831469, -3.0, 0.555571>,
    <-0.707106, -3.0, 0.707108>,
    <-0.555569, -3.0, 0.83147>,
    <-0.382682, -3.0, 0.92388>,
    <-0.195089, -3.0, 0.980785>,
    <0.000002, -3.0, 1.0>,
    <0.195092, -3.0, 0.980785>,
    <0.382685, -3.0, 0.923879>,
    <0.555572, -3.0, 0.831468>,
    <0.707108, 3.0, 0.707106>,
    <0.831471, 3.0, 0.555569>,
    <0.92388, 3.0, 0.382682>,
    <0.980786, 3.0, 0.195088>,
    <1.0, 3.0, -0.000002>,
    <0.980785, 3.0, -0.195092>,
    <0.923879, 3.0, -0.382685>,
    <0.831469, 3.0, -0.555571>,
    <0.707106, 3.0, -0.707107>,
    <0.55557, 3.0, -0.83147>,
    <0.382684, 3.0, -0.923879>,
    <0.195091, 3.0, -0.980785>,
    <0.000001, 3.0, -1.0>,
    <-0.195089, 3.0, -0.980785>,
    <-0.382682, 3.0, -0.92388>,
    <-0.555568, 3.0, -0.831471>,
    <-0.707105, 3.0, -0.707108>,
    <-0.831468, 3.0, -0.555573>,
    <-0.923878, 3.0, -0.382686>,
    <-0.980785, 3.0, -0.195094>,
    <-1.0, 3.0, -0.000004>,
    <-0.980786, 3.0, 0.195086>,
    <-0.923881, 3.0, 0.382679>,
    <-0.831473, 3.0, 0.555566>,
    <-0.707111, 3.0, 0.707103>,
    <-0.555575, 3.0, 0.831466>,
    <-0.382689, 3.0, 0.923877>,
    <-0.195097, 3.0, 0.980784>,
    <-0.000007, 3.0, 1.0>,
    <0.195083, 3.0, 0.980787>,
    <0.382676, 3.0, 0.923883>,
    <0.555563, 3.0, 0.831474>,
    <0, -3.0, 0>,
    <0, 3.0, 0>,
  normal_vectors {
    66
    <-0.744, -0.6682, 0>,
    <-0.744, 0.6682, 0>,
    <-0.7297, -0.6682, -0.1451>,
    <-0.7297, 0.6682, -0.1451>,
    <-0.7297, -0.6682, 0.1451>,
    <-0.7297, 0.6682, 0.1451>,
    <-0.6873, -0.6682, -0.2847>,
    <-0.6873, 0.6682, -0.2847>,
    <-0.6873, -0.6682, 0.2847>,
    <-0.6873, 0.6682, 0.2847>,
    <-0.6186, -0.6682, -0.4133>,
    <-0.6186, 0.6682, -0.4133>,
    <-0.6186, -0.6682, 0.4133>,
    <-0.6186, 0.6682, 0.4133>,
    <-0.526, -0.6682, -0.526>,
    <-0.526, 0.6682, -0.526>,
    <-0.526, -0.6682, 0.526>,
    <-0.526, 0.6682, 0.526>,
    <-0.4133, -0.6682, -0.6186>,
    <-0.4133, 0.6682, -0.6186>,
    <-0.4133, -0.6682, 0.6186>,
    <-0.4133, 0.6682, 0.6186>,
    <-0.2847, -0.6682, 0.6873>,
    <-0.2847, 0.6682, 0.6873>,
    <-0.2847, -0.6682, -0.6873>,
    <-0.2847, 0.6682, -0.6873>,
    <-0.1451, -0.6682, -0.7297>,
    <-0.1451, 0.6682, -0.7297>,
    <-0.1451, -0.6682, 0.7297>,
    <-0.1451, 0.6682, 0.7297>,
    <0, -0.6682, -0.744>,
    <0, 0.6682, -0.744>,
    <0, -1.0, 0>,
    <0, 1.0, 0>,
    <0, -0.6682, 0.744>,
    <0, 0.6682, 0.744>,
    <0.1451, -0.6682, -0.7297>,
    <0.1451, 0.6682, -0.7297>,
    <0.1451, -0.6682, 0.7297>,
    <0.1451, 0.6682, 0.7297>,
    <0.2847, -0.6682, -0.6873>,
    <0.2847, 0.6682, -0.6873>,
    <0.2847, -0.6682, 0.6873>,
    <0.2847, 0.6682, 0.6873>,
    <0.4133, -0.6682, -0.6186>,
    <0.4133, 0.6682, -0.6186>,
    <0.4133, -0.6682, 0.6186>,
    <0.4133, 0.6682, 0.6186>,
    <0.526, -0.6682, -0.526>,
    <0.526, 0.6682, -0.526>,
    <0.526, -0.6682, 0.526>,
    <0.526, 0.6682, 0.526>,
    <0.6186, -0.6682, -0.4133>,
    <0.6186, 0.6682, -0.4133>,
    <0.6186, -0.6682, 0.4133>,
    <0.6186, 0.6682, 0.4133>,
    <0.6873, -0.6682, -0.2847>,
    <0.6873, 0.6682, -0.2847>,
    <0.6873, -0.6682, 0.2847>,
    <0.6873, 0.6682, 0.2847>,
    <0.7297, -0.6682, -0.1451>,
    <0.7297, 0.6682, -0.1451>,
    <0.7297, -0.6682, 0.1451>,
    <0.7297, 0.6682, 0.1451>,
    <0.744, -0.6682, 0>,
    <0.744, 0.6682, 0>,
  face_indices {
    128
    <64, 0, 1>,
    <33, 32, 65>,
    <1, 2, 64>,
    <34, 33, 65>,
    <2, 3, 64>,
    <35, 34, 65>,
    <3, 4, 64>,
    <36, 35, 65>,
    <4, 5, 64>,
    <37, 36, 65>,
    <5, 6, 64>,
    <38, 37, 65>,
    <6, 7, 64>,
    <39, 38, 65>,
    <7, 8, 64>,
    <40, 39, 65>,
    <8, 9, 64>,
    <41, 40, 65>,
    <9, 10, 64>,
    <42, 41, 65>,
    <10, 11, 64>,
    <43, 42, 65>,
    <11, 12, 64>,
    <44, 43, 65>,
    <12, 13, 64>,
    <45, 44, 65>,
    <13, 14, 64>,
    <46, 45, 65>,
    <14, 15, 64>,
    <47, 46, 65>,
    <15, 16, 64>,
    <48, 47, 65>,
    <16, 17, 64>,
    <49, 48, 65>,
    <17, 18, 64>,
    <50, 49, 65>,
    <18, 19, 64>,
    <51, 50, 65>,
    <19, 20, 64>,
    <52, 51, 65>,
    <20, 21, 64>,
    <53, 52, 65>,
    <21, 22, 64>,
    <54, 53, 65>,
    <22, 23, 64>,
    <55, 54, 65>,
    <23, 24, 64>,
    <56, 55, 65>,
    <24, 25, 64>,
    <57, 56, 65>,
    <25, 26, 64>,
    <58, 57, 65>,
    <26, 27, 64>,
    <59, 58, 65>,
    <27, 28, 64>,
    <60, 59, 65>,
    <28, 29, 64>,
    <61, 60, 65>,
    <29, 30, 64>,
    <62, 61, 65>,
    <30, 31, 64>,
    <63, 62, 65>,
    <31, 0, 64>,
    <32, 63, 65>,
    <33, 1, 0>,
    <0, 32, 33>,
    <34, 2, 1>,
    <1, 33, 34>,
    <35, 3, 2>,
    <2, 34, 35>,
    <36, 4, 3>,
    <3, 35, 36>,
    <37, 5, 4>,
    <4, 36, 37>,
    <38, 6, 5>,
    <5, 37, 38>,
    <39, 7, 6>,
    <6, 38, 39>,
    <40, 8, 7>,
    <7, 39, 40>,
    <41, 9, 8>,
    <8, 40, 41>,
    <42, 10, 9>,
    <9, 41, 42>,
    <43, 11, 10>,
    <10, 42, 43>,
    <44, 12, 11>,
    <11, 43, 44>,
    <45, 13, 12>,
    <12, 44, 45>,
    <46, 14, 13>,
    <13, 45, 46>,
    <47, 15, 14>,
    <14, 46, 47>,
    <48, 16, 15>,
    <15, 47, 48>,
    <49, 17, 16>,
    <16, 48, 49>,
    <50, 18, 17>,
    <17, 49, 50>,
    <51, 19, 18>,
    <18, 50, 51>,
    <52, 20, 19>,
    <19, 51, 52>,
    <53, 21, 20>,
    <20, 52, 53>,
    <54, 22, 21>,
    <21, 53, 54>,
    <55, 23, 22>,
    <22, 54, 55>,
    <56, 24, 23>,
    <23, 55, 56>,
    <57, 25, 24>,
    <24, 56, 57>,
    <58, 26, 25>,
    <25, 57, 58>,
    <59, 27, 26>,
    <26, 58, 59>,
    <60, 28, 27>,
    <27, 59, 60>,
    <61, 29, 28>,
    <28, 60, 61>,
    <62, 30, 29>,
    <29, 61, 62>,
    <63, 31, 30>,
    <30, 62, 63>,
    <32, 0, 31>,
    <31, 63, 32>,
  normal_indices {
    128
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <33, 33, 33>,
    <32, 32, 32>,
    <10, 11, 15>,
    <15, 14, 10>,
    <6, 7, 11>,
    <11, 10, 6>,
    <2, 3, 7>,
    <7, 6, 2>,
    <0, 1, 3>,
    <3, 2, 0>,
    <4, 5, 1>,
    <1, 0, 4>,
    <8, 9, 5>,
    <5, 4, 8>,
    <12, 13, 9>,
    <9, 8, 12>,
    <16, 17, 13>,
    <13, 12, 16>,
    <20, 21, 17>,
    <17, 16, 20>,
    <22, 23, 21>,
    <21, 20, 22>,
    <28, 29, 23>,
    <23, 22, 28>,
    <34, 35, 29>,
    <29, 28, 34>,
    <38, 39, 35>,
    <35, 34, 38>,
    <42, 43, 39>,
    <39, 38, 42>,
    <46, 47, 43>,
    <43, 42, 46>,
    <50, 51, 47>,
    <47, 46, 50>,
    <54, 55, 51>,
    <51, 50, 54>,
    <58, 59, 55>,
    <55, 54, 58>,
    <62, 63, 59>,
    <59, 58, 62>,
    <64, 65, 63>,
    <63, 62, 64>,
    <60, 61, 65>,
    <65, 64, 60>,
    <56, 57, 61>,
    <61, 60, 56>,
    <52, 53, 57>,
    <57, 56, 52>,
    <48, 49, 53>,
    <53, 52, 48>,
    <44, 45, 49>,
    <49, 48, 44>,
    <40, 41, 45>,
    <45, 44, 40>,
    <36, 37, 41>,
    <41, 40, 36>,
    <30, 31, 37>,
    <37, 36, 30>,
    <26, 27, 31>,
    <31, 30, 26>,
    <24, 25, 27>,
    <27, 26, 24>,
    <18, 19, 25>,
    <25, 24, 18>,
    <14, 15, 19>,
    <19, 18, 14>,
    pigment { color rgb<1.0, 1.0, 1.0> }
    finish { ambient rgb<0, 0, 0> diffuse 0.5 }
 } rotate <44,0,60>}
Date: 15 Jul 2007 14:28:29
Message: <qjsdc50q7a0s$.1t9hbujqyybwu$.dlg@40tude.net>
the first has an ireealistic black zone, the second has a smoot gradient
from light to dark, and if i use a cylinder statement instead of the mesh,
pov renders it like blender.
Date: 15 Jul 2007 18:14:09
Message: <469a9c31@news.povray.org>
The faces are inverted, normals pointing inward,
they should point outward.
Date: 16 Jul 2007 03:45:01
Message: <web.469b21e3dedc19f1ed639e290@news.povray.org>
hmmm. i've tried to swap the normals, but the black area remains.
Date: 16 Jul 2007 04:00:02
Message: <web.469b248cdedc19f1d79c3b620@news.povray.org>
IMO you hit the shadow line artifact:
http://www.povray.org/documentation/view/3.6.1/193/
If you subdivide your mesh the shadow line artifact should move further out
and occur in a deeper grey area, but you won't get rid of it.
Date: 16 Jul 2007 06:07:43
Message: <469b436f@news.povray.org>
  I still see no difference in the images.
  Anyways, just out of curiosity, what happens if you speficy "no_shadow"
in the mesh when you render it with povray?
Date: 16 Jul 2007 13:33:00
Message: <15x0c9dj6nzxn.a2l0jfxdd7os$.dlg@40tude.net>
i think you've some problem with the contrast on your monitor :)
i'll try, but i think it's the same: there's no other object in the scene,
so there's nothing that could make shadows over the cylinder.
Date: 16 Jul 2007 15:08:08
Message: <469bc217@news.povray.org>
  Yes, there is: The cylinder itself.
Date: 16 Jul 2007 16:59:51
Message: <469bdc47$1@news.povray.org>
Blender isn't my prefered tool...
I think you need to tell it to export
the normals and to calculate them at
high quality in the export dialog.
(Blender ignores normals by default)
Date: 18 Jul 2007 10:05:02
Message: <web.469e1d6adedc19f138a7d1420@news.povray.org>
good thing you've seen the light! :)
really, is there any reason for using a gigantic mesh to represent a
cylinder when the builtin pov cylinder is much more reasonable and better
looking?
Date: 18 Jul 2007 14:26:07
Message: <qzp8qbe7lzdi.8cx4hsuww0w6.dlg@40tude.net>
> looking?
the cylinder is only an example, i wonder if the cylinder makes all these
problems, a more complex mesh could have more?
Date: 18 Jul 2007 15:03:11
Message: <469e63ef@news.povray.org>
> i'll try
  So what happened?
Date: 18 Jul 2007 16:30:02
Message: <web.469e7741dedc19f1c150d4c10@news.povray.org>
> I'm going mad!
> Thanks.
I've had a look at this and deconstructed the mesh.
First of all, the normals all point inward, which isn't such a big deal, as
they all point inward, not just some.
What is causing your problem though is the normals for the sides are not
normal to the cylinder, they are oriented as if there is a smooth
transition from the sides to the cap instead of being a sharp edge.  This
causes POV to treat the mesh as being curved more like a sphere and shades
it as such.  I don't use Blender, so I don't know how exporting works, but
you need to limit the angle at which the normals are smoothed for, so the
side meshes are smoothed around the cylinder, but not up and down the
cylinder.
-tgq
Date: 21 Jul 2007 05:01:43
Message: <46a1cb77$1@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> schreef in bericht
news:web.469e7741dedc19f1c150d4c10@news.povray.org...
> as
> cylinder.
I translated PdG's cylinder (through Poseray) to Silo and come to the same
conclusion concerning the normals' orientation inward. That should be easy
to correct.
However, I think that the important keyword that PdG has used in his initial
message is: "i've smoothed".
Smoothing (or subdividing) is the culprit here. What you can do in Silo for
instance, is to "crease" the edges of the cylinder so that the shape remains
the same. Otherwise, the cylinder will turn into a spherical object the more
you smooth or subdivide. I suppose now that something like edge creasing
should be done in Blender before exporting to POV-Ray.
