POV-Ray : Newsgroups : povray.news-submissions : UberPOV v1.37.1.0-beta.9 released Server Time
2 Apr 2026 12:50:08 EDT (-0400)
  UberPOV v1.37.1.0-beta.9 released (Message 1 to 2 of 2)
Subject: UberPOV v1.37.1.0-beta.9 released
Date: 31 Jan 2015 03:47:33
Message: <54cc96a5$1@news.povray.org>
Latest UberPOV version, with all the new official POV-Ray bells &
whistles merged in.
https://github.com/UberPOV/UberPOV/releases/tag/v1.37.1.0-beta.9
Subject: Re: UberPOV v1.37.1.0-beta.9 released
Date: 31 Jan 2015 09:35:00
Message: <web.54cce7fad79e1cec8d15b2010@news.povray.org>
> whistles merged in.
Cool that someone works on this :)
Date: 31 Jan 2015 20:26:58
Message: <54cd80e2$1@news.povray.org>
> whistles merged in.
I'm getting this error during the make portion of the build:
In file included from backend/frame.h:67:0,
                  from lightgrp.cpp:35:
./base/colour.h: In member function
‘pov_base::GenericTrans<COLOUR_T>::Channel
pov_base::GenericTrans<COLOUR_T>::LegacyOpacity(const Colour&) const’:
./base/colour.h:1132:28: error: ‘col’ was not declared in this scope
./base/colour.h: In constructor
‘pov_base::GenericTransColour<CT>::GenericTransColour(const Colour&,
pov_base::GenericTransColour<CT>::Channel,
pov_base::GenericTransColour<CT>::Channel)’:
./base/colour.h:1933:13: error: class ‘pov_base::GenericTransColour<CT>’
does not have any field named ‘mFilter’
./base/colour.h:1934:13: error: class ‘pov_base::GenericTransColour<CT>’
does not have any field named ‘mTransm’
make[2]: *** [lightgrp.o] Error 1
make[2]: Leaving directory
`/home/ash/ScratchPad/uber/UberPOV-1.37.1.0-beta.9/source'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/home/ash/ScratchPad/uber/UberPOV-1.37.1.0-beta.9'
make: *** [all] Error 2
Same error that I'm getting with ANY source AFTER beta6 (which built
just fine)
Date: 31 Jan 2015 20:46:55
Message: <54cd858f$1@news.povray.org>
>> whistles merged in.
> just fine)
thinking it's the configure phase I redirected output to file to compare
results:
diff c-outb6 c-outb9
4c4
< Configure UberPOV version 1.37.0.0-beta.6
 > Configure UberPOV version 1.37.1.0-beta.9
177a178
 > checking whether g++ accepts -Wno-non-template-friend... yes
222c223
< UberPOV 1.37.0.0-beta.6 has been configured.
 > UberPOV 1.37.1.0-beta.9 has been configured.
235c236
<   Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -malign-double
  -march=native -pthread
-fno-enforce-eh-specs -Wno-non-template-friend -s -O3 -
ffast-math -malign-double -march=native -pthread
and noticed the checking whether g++ accepts yada-yada shows up for the
beta9 configure ... is that a clue?
Date: 31 Jan 2015 20:49:01
Message: <54cd860d@news.povray.org>
>>> whistles merged in.
>> just fine)
> results:
> 4c4
> 177a178
> 222c223
> 235c236
Oh ... and the Compiler flags shows -Wno-non-template-friend for b9 as well
Date: 31 Jan 2015 20:50:38
Message: <54cd866e$1@news.povray.org>
>>>> whistles merged in.
>>> just fine)
>> results:
>> 4c4
>> 177a178
>> 222c223
>> 235c236
holy crap i'm rusty (bare with me) haven't even TOUCHED pov/uber for
almost 3 months now: I'm using gcc (SUSE Linux) 4.6.2
Date: 31 Jan 2015 22:10:57
Message: <54cd9941$1@news.povray.org>
Am 01.02.2015 um 02:49 schrieb James Holsenback:
Nope (presuming with "yada-yada" you mean "-Wno-non-template-friend");
this is just the suppression of an unwarranted warning from g++.
Effectively, what this is all about is that there was a quirk in older
g++ versions violating the C++ specs, and now by default they issue a
warning just in case your code was relying on g++'s old behaviour.
I'll have a closer look at it. It's certainly not something affecting
the Windows build.
Date: 31 Jan 2015 22:37:39
Message: <54cd9f83$1@news.povray.org>
Am 01.02.2015 um 02:26 schrieb James Holsenback:
> just fine)
Can you please do me a favor and check again with the following versions:
     ce0aae6b54d434ceb3daf7410582f95ea742ac14 (2014-07-27)
     e1028cd0dbb0918324cf9b898906b54222fc67da (2014-07-29)
I have strong reason to believe that the latter introduced the error.
Which also means that it's probably already present in the
feature/colour_model branch in the official POV-Ray repo.
Date: 31 Jan 2015 23:08:01
Message: <54cda6a1$1@news.povray.org>
>> just fine)
ce0aae6b54d434ceb3daf7410582f95ea742ac14 has the same error so I did NOT
pull e1028cd0dbb0918324cf9b898906b54222fc67da
Date: 1 Feb 2015 00:14:27
Message: <54cdb633@news.povray.org>
Am 01.02.2015 um 05:08 schrieb James Holsenback:
>>> just fine)
Strange - I suspect you must have done something wrong there. Never
mind, I've been able to reproduce the error and trace it back to the
"feature/colour_model" branch in the official repo (which is what
UberPOV is based on). I'm currently in the process of releasing a fix.
