POV-Ray : Newsgroups : povray.news-submissions : povray with moray using win7 : Re: povray with moray using win7 Server Time
8 Nov 2025 12:42:05 EST (-0500)
Date: 8 Apr 2012 05:30:00
Message: <web.4f8159a29ffdc0e547437ba70@news.povray.org>
Stephen <mcavoys_at@aoldotcom> wrote:
> On 07/04/2012 10:03 PM, peter puzzelaar wrote:
> > Hope that this input is of some help
> I have a vague feeling that I have had a similar problem. In Pov3.5 can
> you go into the Tools menu and open Povray.ini and pvengin.ini?
> Otherwise, unless someone else can suggest a more direct method.
> I would uninstall all versions of PovRay and Moray.
> Install Pov 3.5 then install Moray and let Moray do its thing to connect
> to Pov 3.5.
> still does not work you might have to clean up the registry.
> After you get Moray and PovRay talking and rendering you can re-install
> Pov 3.6 and 3.7 if you want.
> Regards
>      Stephen
In Povray 3.5 all tools are available, including povray.ini and
pvengine.ini.
As to your advice about reinstalling: i did the very same thing yesterday.
ridding all povray and moray programs, afterwards cleaning the registry, then
doing a reinstall: first povray 3.5. Result was that still Povray 3.5 could not
render any file. (same applies to other PC in my home with win7. On a third PC
with windows XP, Povray 3.5 and Moray 3.5 work nicely together.
Regards, Peter
