POV-Ray : Newsgroups : povray.news-submissions : Spectral Rendering with POV-Ray : Re: Spectral Rendering with POV-Ray: comments on the tutorial Server Time
2 Apr 2026 23:55:11 EDT (-0400)
Date: 28 Sep 2012 10:03:05
Message: <5065ae19$1@news.povray.org>
On 28-9-2012 14:33, Ive wrote:
> Am 28.09.2012 10:05, schrieb Thomas de Groot:
>> I patched in an updated gold nugget bowl with M_Gold(0.9). I first tried
>> a reflectance of 0.5 to see the difference.
> Looks better, methinks ;)
Yes, it does indeed.
> The problem with most of these "old" texture definitions is not only the
> rgb vs. srgb problem. They are simply designed at a time when nobody was
> using radiosity or HDR-lighting (i.e. not necessarily HDRI but
> light_sources with emitting values higher than 1.0). For example
> golds.inc uses an ambient term for the color *calculation* but ambient
> (as part of the finish) gets meanwhile switched off as soon radiosity is
> used.
I fully agree. Normally, I rarely use the "out of the box" textures and
prefer to brew my own. Only for those special cases like gold I am
rather unsure and tend to use something available, forgetting that they
are often far from up-to-date.
> I'm always did find it easier to use textures that come close to real
> world physics (within the limitations of raytracing) and as such do work
> under all lighting conditions (conventional with/without radiosity and
> radiosity only) instead of tweaking a texture every time I use it.
You are privileged to know what you are talking about :-)
> To me this is not so much about photorealism, it is more about laziness ;)
An acceptable way of life ;-)
