POV-Ray : Newsgroups : povray.news-submissions : povray with moray using win7 : Re: povray with moray using win7 Server Time
24 Mar 2026 20:28:52 EDT (-0400)
Date: 8 Apr 2012 02:56:15
Message: <4f81368f$1@news.povray.org>
On 8-4-2012 1:11, Stephen wrote:
> On 07/04/2012 10:03 PM, peter puzzelaar wrote:
>> Hope that this input is of some help
> I have a vague feeling that I have had a similar problem. In Pov3.5 can
> you go into the Tools menu and open Povray.ini and pvengin.ini?
> Otherwise, unless someone else can suggest a more direct method.
> I would uninstall all versions of PovRay and Moray.
> Install Pov 3.5 then install Moray and let Moray do its thing to connect
> to Pov 3.5.
> still does not work you might have to clean up the registry.
> After you get Moray and PovRay talking and rendering you can re-install
> Pov 3.6 and 3.7 if you want.
Since my switch to Windows 7 I have not reinstalled Moray or POV-Ray
3.5, so I may not be of greathelp here. However, I noted down long ago
something you can do when Moray refuses to render in POV 3.5:
Go to moray.ini and change the line:
Histogram_type=X
into:
Histogram_type=None
Maybe that helps?
