POV-Ray : Newsgroups : povray.general : File handles for output streams Server Time
30 Apr 2026 00:56:42 EDT (-0400)
  File handles for output streams (Message 1 to 9 of 9)
Subject: File handles for output streams
Date: 19 Jun 2025 08:50:00
Message: <web.685406abf832fee04d6accde5cc1b6e@news.povray.org>
I am working on some macros to generate .inc files based on some long-running
calculations to avoid having to do those calculations on every render.  I'd like
to make them generic enough so I can write to the console as well as to a file,
but it doesn't look like there are built-in file handles that can be used with
#write for the debug or any other output streams.
Am I missing something, or do I need to do some kludgy things to allow for both
options?
-- Chris R
Subject: Re: File handles for output streams
Date: 19 Jun 2025 08:55:00
Message: <web.6854089d964d40ce44e64d2825979125@news.povray.org>
> options?
> -- Chris R
All I'm aware of are
#debug
#warning
#error
-BW
Date: 19 Jun 2025 09:40:00
Message: <web.685412f5964d40ce4d6accde5cc1b6e@news.povray.org>
> > options?
> > -- Chris R
> #debug
> #warning
> #error
> -BW
Thanks.  I'll work around it.
Follow-up question: it appears you can't pass file handles as parameters to
macros.  No tricks for that either?
-- Chris R
Date: 19 Jun 2025 09:55:00
Message: <web.685415c9964d40ce3ecaab5e6cde94f1@news.povray.org>
hi,
> "Bald Eagle" <cre### [at] netscapenet> wrote:
> > -BW
no, alas.  (there was a fairly recent thread on this issue, sorry, no ref)
regards, jr.
Date: 19 Jun 2025 10:10:52
Message: <68541a6c@news.povray.org>
On 19/06/2025 15:51, jr wrote:
> hi,
>>> -BW
> regards, jr.
I was the one who asked about this problem.
I've tried several things (even with Parse_String()) without success :(
kurtz le pirate
compagnie de la banquise
Date: 19 Jun 2025 12:24:06
Message: <685439a6$1@news.povray.org>
Here's my workaround:
---%<-----%<-----%<---[BEGIN CODE]---%<-----%<-----%<---
#macro Write_something (Filename, N)
   #fopen F Filename append
   #write (F, N)
   #fclose F
#declare FILE1 = "test.txt"
#fopen F FILE1 write #fclose F //zero the output file
Write_something (FILE1, "Hello,\n")
Write_something (FILE1, "world.\n")
--->%----->%----->%----[END CODE]---->%----->%----->%---
Date: 19 Jun 2025 16:15:27
Message: <68546fdf$1@news.povray.org>
> options?
For the record, and though it is in the "kludgy things" category, one
can use some variation of the following example code on Unix/Linux:
// this.pov
// Unix/Linux ways to write text to stdout stderr more directly.
// Method uses post_scene_command, so set [Shellout Security] to
// allowed in your povray.conf file.
#fopen FH_stdout "My_stdout_file" write
#fopen FH_stderr "My_stderr_file" write
#fclose FH_stdout
#fclose FH_stderr
#if (1)  // Set to 0 to empty the My_std* files
#else
     #fopen FH_stdout "/dev/null" append
     #fopen FH_stderr "/dev/null" append
// Normal scene SDL work starts here
#version 3.8;
background {rgb <1,1,0>}
#write(FH_stdout,"===> Hello stdout\n")
#write(FH_stderr,"===> Hello stderr\n")
// Normal scene SDL work ends here
#fclose FH_stdout
#fclose FH_stderr
// With yuqk and official povray the supporting ini command lines
// can be:
// post_scene_command="cat My_stdout_file >/dev/stdout;cat
My_stderr_file >/dev/stderr"
// Run with:
//   yuqk this.pov include_ini=this.ini
// or
//  povray this.pov include_ini=this.ini
// With yuqk you can do it all on the command line too with the
// same ini style quoting here and usual Unix/Linux quoting otherwise.
// (Official POV-Ray cli quoting works too, but its form is strange)
// Run with, say:
// yuqk this.pov post_scene_command="cat My_stderr_file" >/dev/stderr
// To write meta data at the end of .ppm image output, for example -
// as the .ppm format allows appending text, you can then do
// something like:
// yuqk this.pov +fp post_scene_command="cat My_stderr_file" >>hmm.ppm
// given you've used FH_stderr for your image's user, meta data.
Aside: This method a reason the yuqk fork has kept the +-hi /
include_header= option and is considering an include_trailer= option.
Also under consideration, are new user_ 'file handle' cli / ini options
which would set up  some number of explicit user file handles for use
with #write(). We'll see.
Bill P.
Date: 19 Jun 2025 19:00:50
Message: <685496a2$1@news.povray.org>
Though it worked in my hacking environment, the referenced line above -
for the posted example code - should read:
// yuqk this.pov +fp post_scene_command="cat My_stderr_file" >>this.ppm
Bill P.
Date: 20 Jun 2025 11:03:10
Message: <6855782e$1@news.povray.org>
>     #write (F, N)
>     #fclose F
> #end
Ingenious approach. I had started with the logic of opening all my files
and choosing to write in this one or that one. I closed all my files at
the end.
With your clever solution, when you write to a file, you open and close
it each time.
Below is a stupid code that illustrates your concept and works really
well with multiple files.
#declare odd  = function(x) {select(mod(x, 2), 1, 0, 1)} // no include
    #write (F, concat(str(N,0,0),"\n"))
    #fclose F
#macro Create_file(Filename)
   #fopen F Filename write
   #fclose F
#declare N = 5;
#declare Files = array[N]
#declare i = 0;
#while ( i < N )
   #declare Files[i] = concat("file",str(i,0,0),".txt");
   Create_file(Files[i])
   #declare i = i +1;
#declare i = 0;
#while ( i < 25 )
   Write_something(Files[mod(i,N)],i)
   #declare i = i + 1;
#error "Nothing to draw"
Thanks for your tip ;)
kurtz le pirate
