POV-Ray : Newsgroups : povray.general : A little help about old vers. Server Time
13 Dec 2025 17:25:06 EST (-0500)
  A little help about old vers. (Message 38 to 47 of 97)
Subject: Re: A little help about old vers.
Date: 3 May 2025 21:10:00
Message: <web.6816bd86ce24a8bbe9997a2230225ff5@news.povray.org>
Preview see Pic
Download 'test_facchinos.jpg' (256 KB)
Preview of image 'test_facchinos.jpg'
Date: 4 May 2025 05:45:00
Message: <web.6817366ace24a8bb721a48e56cde94f1@news.povray.org>
hi,
"GioSeregni" <gms### [at] hotmailcom> wrote:
> > > This is my old version ... I'm improving it, but soon
> > > Of course anyone can do better as a definition of sun sky light reflections
> > > etc.. this is my way
> > > BR
> > > G.
> > How about a bit of worksharing?
> > You look for your code for several cars or even people and make it executable,
> > I clean up the code and make it variable (change colors)?
> > My offer.
> > Ma
> Sure, of course!
> Everything can be improved this is the first version,
> I am also working to lighten with boolean operations and solids, and smooth
> triangles where it is better!
> I will now continue to post first versions because I know for sure that they do
> not have errors...
> thanks!
> BR.
> G.
in an earlier post you (Gio) mentioned your own CAD parser & exporter.  attached
is a per mesh sequence of images, same order as file; I modified the
'FURGONE.inc' to have an array of meshes and rendered "an animation" of the
elements.  looks like we'll need a re-export, one which gives "us" :-) separate
doors etc.  cheers.
regards, jr.
Download 'permesh.zip' (805 KB)
Date: 4 May 2025 07:00:00
Message: <web.68174885ce24a8bbe9997a2230225ff5@news.povray.org>
> doors etc.  cheers.
Poor Gio. Actually, he just wanted to quickly revive his old code maybe in some
free-hours, and now he keeps us (and himself) busy for days :)
A re-export would be a great thing. The person's hair and shoes were in a mesh
that I could easily separate because of the different Y values.
With the car, however, it was much too complicated for me. I would love to
separate the complete wheels or even doors to teach the car (or another) to
drive and steer.
Gio's Exporter combines all triangles in one mesh that have the same color (hair
and shoes). If you could give different parts a slightly different color, they
would be stored in separate meshes.
I'll wait and see what you're up to and won't change anything about my
programming.
Unless new cars or people appear, then I probably can't stop myself ... :(
Ma
Date: 4 May 2025 09:35:00
Message: <web.68176c2bce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> > ... looks like we'll need a re-export, ...
> drive and steer.
> programming.
yes, you're right I think, best to "wait and see" for now.  so much potential
regards, jr.
Date: 4 May 2025 10:10:00
Message: <web.68176e18ce24a8bb7e2ea33059126100@news.povray.org>
> > doors etc.  cheers.
> drive and steer.
> programming.
> Ma
Ok, thank!
well, the 2nd car is incoming soon, I have a bit of work to combine some *.inc
to make management easier.
And I noticed that over time my headlight on/off switch no longer works
perfectly (changed environment...)
About hair and shoes you are right! I will do it, I am updating the file with
smooth triangle. Soon it will be ready.
Tomorrow the second car and a bicycle that was in the same file inc.
Then we immediately arrange the "facchino"
About the parts, a solution should be found. For me it is easy because I have
done and continue an importer export tool working on pov - inc - STL - DXF -
SkUp
but there are two problems.
Sometimes bugs happen (rarely) where I know how to fix it immediately, but for
others it becomes frustrating.
Also I would not like to publish executable files, the web is a bad environment,
and I care about my good name, and I hate false positives.
Impossible also to publish the source code. By now it is very complicated and it
would take a lot of experience in the language I use which is not very
widespread (RapidQ).
I could think of small separated routines that could be easily compiled, but
everything relies on an internal my 3D system that receives the various types of
3D files, and then can return them in the required formats.
And this internal format construction is indispensable and a bit complex. So I
can't make small agile tools... I have to think about it...
BR
G.
oops we are a bit off topic lol
Date: 4 May 2025 10:55:00
Message: <web.68177f13ce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> About the parts, a solution should be found. ...
yesterday !!  </grin>
> the language I use which is not very widespread (RapidQ).
and probably irrelevant anyway :-)  input data (format(s)) and desired output(s)
otoh..
is the 'FURGONE.inc' "typical" output ?  because that was easy enough to
"post-process".  perhaps consider moving to v3.8 to get to use the new 'array
mixed' type (perfect for "data tables") and other nice features.
regards, jr.
Date: 4 May 2025 11:45:00
Message: <web.68178b59ce24a8bbe9997a2230225ff5@news.povray.org>
v3.8 isn't part of the Debian-Rep, manually install is required.
Would make things more difficult for me.
M
Date: 4 May 2025 14:20:00
Message: <web.6817ae0dce24a8bb7e2ea33059126100@news.povray.org>
> hi,
> otoh..
> regards, jr.
I don't know the povray beta...
my exe can read STL and DXF that are very different
In sketchup I use my plugins to write and read DXF or STL
To read pov and inc is always conditioned by files written by itself. The PovRay
syntax is too broad to implement it.
It search triangle (or it split quads in DXF), the can to create the meshes
(smooth or no) using the same colour.
THe colour is in the face, if the face has not colors it search the his layer
color. If not it uses a clear gray.
THere is the arrays sorted by colors, but also (its possible by DXF) the view
point, the target point, the x, y, z origin, the xyz extensions (bounding box).
But thereare also pipes (cylinder) open or closes, in DXF are lines or
polylines, the radius is the declared thickness in dxf.
And many other things.. torus (by circles) ... the dxf blocks are other
include..
light , sunset, storm, subwater are ... etc .. are extracted from keywords by
the layers used only as flags of the dxf
The parser has to be a complex exe. And it must be able to reverse...
Now anyway the car I'm finishing checking the headlights :) it's almost ready
excuse my bad english, i write without a translator to make quicker
BR
G.
Download 'drawing1.png' (188 KB)
Preview of image 'drawing1.png'
Date: 5 May 2025 06:05:00
Message: <web.68188c62ce24a8bb721a48e56cde94f1@news.povray.org>
hi,
> > ... v3.8 ...
ok, provided you're "the owner", the attached script may help (tested on a
Debian 12.5).
to use, visit <https://github.com/POV-Ray/povray/tags/>, from there I used:
<https://github.com/POV-Ray/povray/releases/tag/v3.8.0-beta.2>
put the archive and the script in some directory.
the script will need adjusting in line 14, obvs, and line 25 where you provide
your user:group.
when run, it builds and "installs" the beta in a /tmp directory.  check the
results there and "rinse and repeat" until you're happy.  at that point you can
edit line 44 to remove the DESTDIR bit and install for real.
I tend to use the 'script(1)' utility to "record" what happens, ie:
  $ script -c ./povray.DebBuild build-log
hth and will encourage you to "have a go".
regards, jr.
Download 'povray.debbuild.txt' (1 KB)
Date: 5 May 2025 06:15:00
Message: <web.68188e7fce24a8bb721a48e56cde94f1@news.povray.org>
hi,
I wrote a simple STL to GNU Triangulated Surfaces ("GTS") converter, only to
find better ones existed already :-).
<https://news.povray.org/web.5e75678e7c21754451952ca0%40news.povray.org>
re GTS.  the Wikipedia article on RapidQ mentions loadable libraries.  if you
can get that added to your installation, you should feel "right at home",
everything's done via callbacks </grin>; fwiw, I've a 'gts2pov' util to convert
to mesh[2].
agree.
> include..
the lights are on, a good start.  :-)
way better than my Italian, I now know _two_ words (grazie and furgone :-))
regards, jr.
