POV-Ray : Newsgroups : povray.general : SSL error Server Time
29 Jun 2025 18:52:57 EDT (-0400)
  SSL error (Message 1 to 10 of 10)
Subject: SSL error
Date: 11 Nov 2024 12:25:00
Message: <web.67323cf46987cc6fa911b6e125979125@news.povray.org>
I've been getting the following error lately:
Download 'screenshot 2024-11-08 154851.png' (41 KB)
Preview of image 'screenshot 2024-11-08 154851.png'
Subject: Re: SSL error
Date: 11 Nov 2024 14:05:00
Message: <web.67325482dc45172991c33a706e066e29@news.povray.org>
Maybe unrelated, but for several months now, when I try to connect to the
newsgroups here with my usual link...
      https://news.povray.org/groups/
I sometimes get a warning page instead, something like "We're having trouble
connecting to that https site" or "This site does not have an https webpage,
continue to http site instead?" -- along with a tremendous slow-down in
connecting to the 'net in general. But by simply refreshing the page, the proper
https site does comes up. That's strange.
Trying to find some solution or explanation for the slow-down itself, I've
lately been researching Cloudflare (the global DNS provider)-- and the odd
problems it is causing with some websites and servers. It's all too technical
for me to understand, but I wonder: Do the POV-ray newsgroups use the Cloudflare
service?
Or maybe my internet provider does, I don't know. But I have a gut feeling that
something about Cloudflare's workings might be the culprit here.
Date: 11 Nov 2024 14:55:00
Message: <web.67326085dc451729a911b6e125979125@news.povray.org>
> service?
It looks like the IP address of
new.povray.org is
203.29.75.35
( https://www.nslookup.io/domains/news.povray.org/webservers/ )
so maybe try using that directly and see if it works better for you.
Chris Cason will have to provide details about how all the rest of it works.
Date: 21 Nov 2024 16:40:00
Message: <web.673fa681dc45172991c33a706e066e29@news.povray.org>
> new.povray.org is
> 203.29.75.35
[Sorry for the long delay; real-life reared its head again...]
I gave that IP address a try; the results are...interesting:
The first page that comes up (a Firefox page, probably) says:
"Secure sight not available, continue to http instead?" Like what I had seen
before, on occasion.
By simply refreshing the page, this more ominous warning appears:
"Warning: Potential Security Risk Ahead"
I've tried it multiple times on different days; same result.
So I went to the nslookup.io site. Under "all DNS records", the info is:
news.povray.org
hosted by NETPLEX,  in the U.S (New York)
iPv4 (not iPv6)
Hallam Oaks Pty. Ltd
("Some DNS servers may return different IP addresses based on your location.")
Cloudflare is mentioned in this line:
povray.org.  1800  SOA andronicus.ns.cloudflare.com. dns.cloudflare.com
Anyway, it was a curious result, since the hosting site *seems* legitimate(?).
Although, I didn't follow through with connecting to  203.29.75.35  because of
the warning.
But as to my own wifi-signal slowdown, I'm thinking that it might instead be due
to my older wifi USB dongle (which I've been using on my desktop Windows 10
machine for years.) I get my wireless signal from my landlord's modem in his
house next door, and he gets true 'hi-speed' throughput.  My own signal
*strength* seems adequate, but my 'receive' speed tops out at about 500 Mbps
now. On a *good* day. That's *bits*, not bytes. :-(
This is a relatively new development; mine used to be *much* faster. Earlier
this year, the cable company had to install some new (and upgraded) equipment
outside the landlord's house; a lightning strike apparently fried something
important. But maybe the change resulted in my wifi dongle being technically
out-of-date now.
Date: 21 Nov 2024 17:40:00
Message: <web.673fb60fdc45172991c33a706e066e29@news.povray.org>
Oops, that's 500Kbps :-( :-(  Morse-code speed over telegraph lines.
Date: 22 Nov 2024 07:57:26
Message: <67407fb6$1@news.povray.org>
> service?
Yes. And this will generally provide a speedup, not slowdown (it's the entire purpose
of using cloudflare in the first place). Overall I'd be surprised if you are
encountering problems with cloudflare itself as it's pretty solid.
-- Chris
Date: 22 Nov 2024 08:00:51
Message: <67408083@news.povray.org>
You or your internet provider are using a service called "Netskope" to filter access
to websites. It picked up the fact that our SSL config was not providing the full
chain of certificates leading up to the root issuer.
I have reconfigured the server to include the full chain, so this message should go
away.
-- Chris
Date: 22 Nov 2024 08:09:10
Message: <67408276$1@news.povray.org>
This is common when you access an SSL server by something other than the configured
names in the certificate. It is rarely an actual security risk.
In this case you hit the news server SSL directly via IP address rather than name. The
certificate served by the news server is good for povray.org but not for a raw IP
address. Hence the cert does not mention the IP as being valid and your browser notes
this fact and issues the warning. This is as designed; you need to use the DNS name.
-- Chris
Date: 22 Nov 2024 08:50:00
Message: <web.67408ae5dc4517294cc51b5c25979125@news.povray.org>
to websites.
Correct.
> It picked up the fact that our SSL config was not providing the full chain of
uer.
I guessed that it was something like that.
away.
And so it has.
Thanks, Chris - for making all of this fully and smoothly functional.
- BW
Date: 22 Nov 2024 11:45:00
Message: <web.6740b3c6dc45172991c33a706e066e29@news.povray.org>
Thanks for the excellent explanations, Chris. I have learned some new things
today!
