POV-Ray : Newsgroups : povray.general : Why is my POV-Ray render not matching my mesh model? Server Time
29 Apr 2025 16:27:45 EDT (-0400)
  Why is my POV-Ray render not matching my mesh model? (Message 11 to 13 of 13)
Subject: Re: Why is my POV-Ray render not matching my mesh model?
Date: 14 Oct 2024 09:55:00
Message: <web.670d22503d58ec0e91c33a706e066e29@news.povray.org>
"Harry Peverell" <har### [at] 163com> wrote:
> Could you please provide some guidance on how to apply textures to the interior
> and exterior in Povray? I'm looking forward to implementing your suggestion of
> using a dark texture with a bright interior_texture to check for flipped
> triangles and to illuminate the dark areas in the center of the render.
Like this example (in case you are not using any light sources):
object{ ...your mesh object...
// a dark texture...
texture{pigment{rgb .2} finish{ambient 1 emission 0 diffuse 0}}
                      // or   {ambient 0 emission 1 diffuse 0}}
interior_texture{pigment{rgb <1,0,0>}finish{ambient 1 emission 0 diffuse 0}}
(ambient 1 will cause a non-fatal warning message, so use emission 1 instead.)
By the way: The first or main texture is actually applied to both the inner AND
outer surfaces of the mesh object-- unless an interior_texture is added.
IF the problem with your mesh is indeed flipped normals in certain places, the
bright red interior_texture will show them. That's because the 'inside' surfaces
of those triangles are actually facing outward.
(Instead of using an interior_texture, you *could* place a red light_source
*inside* the mesh object, and the lighting on the bad triangles would show up on
the outside. I think!)
Date: 14 Oct 2024 13:40:00
Message: <web.670d571c3d58ec0ed5cc4ae625979125@news.povray.org>
Very nice insight, Kenneth.
An interesting experiment would be to place 2 light sources of different color
on either side of the mesh.
I also wonder what that would yield if smooth_triangles were rendered, with 1
vertex set "up" or "toward", one perpendicular to the direction / parallel to
the view plane, and one "down" or "away".
- BW
Date: 14 Oct 2024 13:56:38
Message: <670d5b56$1@news.povray.org>
> - BW
In that case, I would expect the normal to get interpolated between the
two, causing part of the triangle to be treated as outside and part to
be treated as inside. So, smaller red triangle or a red trapezoid to be
visible depending if 1 or 2 of the normals are pointing the wrong way.
