POV-Ray : Newsgroups : povray.general : How to draw a curve on a surface? Server Time
30 Apr 2026 02:30:50 EDT (-0400)
  How to draw a curve on a surface? (Message 1 to 6 of 6)
Subject: How to draw a curve on a surface?
Date: 28 Sep 2024 15:40:00
Message: <web.66f85a9d9afc2c8b9aee7de5fd8c677b@news.povray.org>
How does one draw a parametric curve on a surface, for example the helyx:
    f(t) - (cos t, sin t, t)
on the surface of a cone x^2 + y^2 = 1?
I can't seem to find anything about plotting cusrves on the manual.
Subject: Re: How to draw a curve on a surface?
Date: 28 Sep 2024 19:25:00
Message: <web.66f88fb1bd22d553737cc36e89db30a9@news.povray.org>
Hi Alfred
The code below might give you a hint of one way to achieve this.
Tor Olav
http://subcube.com
https://github.com/t-o-k
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
Cylinders with spiral pigment
By Tor Olav Kristensen, 2024-09-29
https://www.povray.org/documentation/view/3.7.1/395/
https://www.povray.org/documentation/view/3.7.1/448/
#version 3.7;
global_settings { assumed_gamma 1.0 }
#include "functions.inc"
#declare Tau = 2*pi;
#declare Cylinder_R = 1.0;
#declare Spiral_R = 0.08;
#declare NoOfHelixes = 1;
#declare NoOfTurns = 1.0; // Per y unit
#declare Shape = 1.0;
#declare CrossSectionType = 1.0; // Circle
#declare CrossSectionRotationAngle = 0.0;
#declare HelixFn =
    function {
        f_helix1(
            x, y, z,
            NoOfHelixes,
            NoOfTurns*Tau,
            Spiral_R,
            Cylinder_R,
            Shape,
            CrossSectionType,
#declare HelixIsosurface =
    isosurface {
        function { HelixFn(x, y, z) }
        threshold 0.0
        max_gradient 4.0
        accuracy 0.0001
        contained_by {
            box {
                -2*<1, 1, 1>,
                +2*<1, 1, 1>
        pigment { color rgb <1.0, 1.0, 1.0> }
#declare ColorMap =
    color_map {
        [ 0.5 color rgb <1.0, 0.0, 0.8> ]
        [ 0.5 color rgb <0.0, 0.8, 1.0> ]
#declare CylinderIsosurface =
    isosurface {
        function { f_sphere(x, 0, z, Cylinder_R) }
        threshold 0.0
        max_gradient 4.0
        accuracy 0.0001
        contained_by {
            box {
                -2*<1, 1, 1>,
                +2*<1, 1, 1>
            function { HelixFn(x, y, z) - 0.17 }
            color_map { ColorMap }
#declare Cylinder =
    cylinder {
        -2*y, +2*y, Cylinder_R
            spiral1 1
            rotate +90*x
            scale <1, 1, -1>
            rotate +90*y
union {
    object { CylinderIsosurface }
    object { HelixIsosurface  }
    translate -1.8*x
union {
    object { Cylinder }
    translate +1.8*x
background { color rgb 0.2*<1, 1, 1> }
light_source {
    100*<+1, +3, -1>
    color rgb <1, 1, 1>
    shadowless
    orthographic
    location < 0, +1, -2>*3
    look_at <0, 0, 0>
Date: 28 Sep 2024 20:15:00
Message: <web.66f89b42bd22d553737cc36e89db30a9@news.povray.org>
> Hi Alfred
This may be a better example for you.
You can also replace the cylinder and the spiral objects with isosurfaces.
Tor Olav
http://subcube.com
Cylinder with parametric spiral pigment
#version 3.7;
#declare Radius = 1.5;
// Fn(s): <Radius*cos(s), Radius*sin(s), s>
#declare Helix_FnX = function(s) { Radius*cos(s) };
#declare Helix_FnY = function(s) { Radius*sin(s) };
#declare Helix_FnZ = function(s) { s };
#declare N = 1000;
#declare MinT = -2.5*Tau;
#declare MaxT = +2.5*Tau;
#declare dT = (MaxT - MinT)/N;
#declare R = 0.4;
#declare Spiral =
    union {
        #declare T_Previous = MinT;
        #declare pPrevious =
                Helix_FnX(T_Previous),
                Helix_FnY(T_Previous),
                Helix_FnZ(T_Previous)
        sphere { pPrevious, R }
        #for (I, 0, N - 1)
            #declare T_Next = T_Previous + dT;
            #declare pNext =
                    Helix_FnX(T_Next),
                    Helix_FnY(T_Next),
                    Helix_FnZ(T_Next)
            cylinder { pPrevious, pNext, R }
            sphere { pNext, R }
            #declare T_Previous = T_Next;
            #declare pPrevious = pNext;
        #end // for
cylinder {
    MinT*z, MaxT*z, Radius
        object {
            Spiral
            color rgb <0.0, 0.3, 1.0> // Outside
            color rgb <1.0, 0.7, 0.0> // Inside
object {
    Spiral
light_source {
    100*<+1, +3, -1>
    color rgb <1, 1, 1>
    shadowless
    orthographic
    location < 0, +3, -8>*2
    look_at <0, 0, 0>
Date: 29 Sep 2024 23:35:00
Message: <web.66fa1bc8bd22d5539aee7de5fd8c677b@news.povray.org>
So, it is really true that there is no framework to "draw" on a surface? And one
has to mimic it with pigmentation, sequence of cylindes, ....
Date: 30 Sep 2024 01:25:00
Message: <web.66fa3518bd22d55317bac71e8ffb8ce3@news.povray.org>
There are a few spline based shapes, spheresweep, sor and prism. But with these
you are bound to the spline options they provide.
An alternative is to loft along a spline or curve and thus create a mesh, then
you have full freedom. Look at meshmaker.inc in the distribution for some ideas.
curves.zip at https://ingoogni.nl/download/ has many curves and splines. One
could also loft one parametric along an other parametric, for example to create
a torus.
ingo
Date: 30 Sep 2024 10:30:00
Message: <web.66fab550bd22d5536563700825979125@news.povray.org>
Well, the thing is - POV-Ray is a raytracer, and nearly everything that it deals
with is a 3D object.  There's no inherent way to "draw" infinitely thin 2D
lines.
Plus, there needs to be a way to determine where the surface is.
So, you can create some sort of visible 3D object such as a sphere-sweep, linked
cylinders and spheres, a parametric, and isosurface, etc to position a visible
object that follows the surface according to how you want to draw your line.
If you want the line to be flat and literally ON the surface, you could use the
object {} pattern, and color the surface on way where the line is, and another
way where the line is not.
https://wiki.povray.org/content/Reference:Object_Pattern
There are likely other somewhat functionally equivalent methods - but providing
a link as to exactly what you're looking to do would the most helpful in terms
of finding an answer.
- Bill
