![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Bald Eagle" <cre### [at] netscape net> wrote:
> SO, maybe I'm missing something here, but wouldn't just find/replace material
> with texture yield a layered texture rather than a material?
> I'm at work atm, so I don't have POV-Ray to test this with.
> But if that works, then you can also just have the macro declare a global
> texture name in the process of making the material, and use that after you
> invoke the macro.
> - BE
That makes my developer heart hurt... global side effects in a "function" call
:-). Of course, macros aren't really functions in POV, but I treat them that
way when I write code.
However, I could avoid the parsing problems if I had kept the transformations in
the macro that creates the material wrapper instead of trying to force them into
the texture. That way I don't need a wrapping texture, and maybe just declaring
a local assignment to the layered texture and returning it would not have caused
the parsing errors with CRand(0.25).
I will play with that. The less I muck up the original code the better.
-- Chris -R
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > invoke the macro.
> > - BE
> -- Chris -R
#declare _t = material {
texture {T1}
CRand(0.25)
works fine
#declare _t = texture {
texture {T1}
CRand(0.25)
is a syntax error; you can't put a texture{} declaration inside of another
texture declaration, so just replacing material with texture doesn't work. I
also checked that the declaration of the layered texture using CRand(0.25) that
returns a texture{} block rather than a texture identifier works when enclosed
inside of a material wrapper, but if you just declare a texture idenfier as
#declare _t =
texture {T1}
CRand(0.25)
you get the syntax error I mentioned earlier about missing braces.
So, somewhere, the parsing for layered textures inside of a material is
different than the parsing of layered textures when declaring a texture
identifier.
-- Chris -R
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> identifier.
remove the texture {} wrapper
https://wiki.povray.org/content/Reference:Layered_Textures
You make a copy of the macro, and have a parallel macro with a slightly
different name to make a texture rather than a material. Then your developer
heart will avoid any mRNA induced myocarditis. :)
Once you declare the texture, then I think you can use that in a final texture
definition with any other modifiers. It seems to be just a matter of
hierarchies and syntax at this point.
And I can tell you from experience that that "just" can drive you crazy.
- BE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 3-4-2024 om 23:25 schreef Bald Eagle:
>> identifier.
> - BE
Hmmm... doesn't seem to be as /simple/ as that... Have you tried this? I
am getting nowhere [drives me crazy indeed]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> >> identifier.
> > - BE
> Thomas
A few posts back in this thread I posted my solution as an attachment.
Essentially I did the following:
1. Modify the CRand macro:
#macro CRand(Intensity)
#local _t = texture { ... }
_t
2. Rename the DakotaRedGranite(...) macro to DakotaRedGranite_texture(...)
3. At the end of the macro I did the following:
#local _t_crand = texture { CRand(0.25) }
#local _t_result =
#if (Pol)
#else
#if (Type=1)
texture {T1_DakotaRedFro}
texture {_t_crand}
#else
texture {T2_DakotaRedFro}
texture {_t_crand}
_t_result
4. Create a new macro named DakotaRedGranite(...)
#macro DakotaRedGranite(...)
#local _m = material {
texture { DakotaRedGranite_texture(...) }
interior { ior 1.6 }
scale M_scale
rotate M_rotate
translate M_trans
_m
That all seems to parse correctly and works.
-- Chris R
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 4-4-2024 om 14:59 schreef Chris R:
>>>> identifier.
>>> - BE
>> Thomas
> _t
> #end
> #local _t_result =
> #if (Pol)
> #else
> #if (Type=1)
> texture {_t_crand}
> #else
> texture {_t_crand}
> #end
> #end
> _t_result
> scale M_scale
> rotate M_rotate
> translate M_trans
> _m
> #end
> -- Chris R
Indeed. And I gave a few ideas for slight improvements on that, a couple
of days ago. Did you see those?
I am probably wrong, but I thought BE was referring to something else...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> invoke the macro.
> - BE
Essentially, a material is just a wrapper for a texture plus an
interior. So, if there is no interior, a material is effectively another
name for a texture.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 04/04/2024 om 18:12 schreef Alain Martel:
> name for a texture.
Yes, that is what I have always assumed. So, if something (a simple
macro) did work fine inside the original - material-based - granite
macro, and it does not when the material wrap is taken away, this could
mean that the original code worked fine... for the wrong reasons!
I have to think about this a bit more and explore deeper. I am not
satisfied yet...
Anyway, if the code generated by Chris R works fine, there is no reason
to avoid its use indeed, but it revealed something imho.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
OK, I think you misunderstood what needed to be done.
Change the outside material {} wrapper to texture {}
REMOVE all of the texture {} statements inside, leaving only the texture names.
That all works - the only thing I couldn't get to work is the Crand, because the
#local/#declare thing in macros is still messed up.
#version 3.8;
global_settings {assumed_gamma 1}
location <0, 0, -5>
up y
look_at <0, 0, 0>
rotate y*clock*360
sky_sphere {pigment {rgb 1}}
light_source {<100, 100, -500> rgb 1}
#include "Granite_Texture.mcr"
#declare Tex = Granite_21 ()
sphere {0, 1 texture {Tex}}
Download 'granite_texture.mcr.txt' (22 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 5-4-2024 om 13:02 schreef Bald Eagle:
Yes, I probably did ;-)
OK
Yes, that is the problem I am also (still) unable to solve in a
satisfying way, and in fact I referred to that in my post. Still
wondering about what I assumed in my answer to Alain Martel. Is this
Crand() macro construction defective in the texture macro compared to
the material macro, or is something else happening...?
> #version 3.8;
> camera {
> location <0, 0, -5>
> up y
> look_at <0, 0, 0>
> rotate y*clock*360
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
