POV-Ray : Newsgroups : povray.general : I need a color recommendation please Server Time
29 Jun 2025 15:52:18 EDT (-0400)
  I need a color recommendation please (Message 1 to 4 of 4)
Subject: I need a color recommendation please
Date: 26 Feb 2024 17:30:00
Message: <web.65dd104543f58c5487b92d44a57e0@news.povray.org>
Hello folks. I am working on a new building render. I decided to do a project of
rendering the tallest building of each state. I am currently working on a
building in Alaska. The building is simple, for the most part. Now the deal is
it has structures that appear to be black. But since I use black for windows, I
need another color that works and still gives the idea that they are black. I
included a pic with some of the structures circled. I am asking for suggestions
please. (I use gray20 for a quick and dirty asphalt, and gray10 looks like it is
black so as not to notice a difference.) But they also kinda give a hint of
brown. I dunno. I can't quite place the color. what do you think?
Download 'isitgrey.jpg' (91 KB)
Preview of image 'isitgrey.jpg'
Subject: Re: I need a color recommendation please
Date: 26 Feb 2024 20:05:00
Message: <web.65dd351f647a4ddc1f9dae3025979125@news.povray.org>
You can use a color picker, or load the image into POV-Ray and scan all the
pixels with eval_pigment.
Having seen those institutional buildings up close many times, those are some
sort of powder-coated aluminum, and they are brown.
"koko brown"
Seach:  brown metal trim institutional buildings
- BW
Download 'koko_brown-400x400.jpg' (2 KB)
Preview of image 'koko_brown-400x400.jpg'
Date: 27 Feb 2024 10:23:57
Message: <65ddfe8d$1@news.povray.org>
The colours can be the same, but have different finish.
I'd go for Gray10 for both as you proposed. May also use something
slightly off, like :
rgb<0.11, 0.09, 0.08>
It may also be something like :
rgb 0.15* Brown
The generic brown from color.inc, but made much darker.
The window's frame is somewhat shiny and have subtle reflection, while
the vestibule have a rougher, non-reflective, surface.
So, same pigment for both.
For the window frame, add some fresnel reflection and an interior.
Starting suggestion :
texture{...
	finish{... reflection{1 fresnel}}
interior{ior 1.4} // adjust to your taste
//between 1.3(water) and 1.6 to stay realistic.
Then, give some normal perturbation to the vestibule :
finish{... normal granite 0.3}//may go up to about 0.7
Date: 15 Mar 2024 16:35:00
Message: <web.65f4b09a647a4ddc87b92d44a57e0@news.povray.org>
Thanks for the suggestions.  I think the koko brown was dead on target, and went
with that.
