POV-Ray : Newsgroups : povray.general : Iridescence code Server Time
22 Sep 2025 19:29:35 EDT (-0400)
  Iridescence code (Message 11 to 15 of 15)
Subject: Re: Iridescence code
Date: 24 Dec 2023 15:10:00
Message: <web.65889006f07d5fbb1f9dae3025979125@news.povray.org>
Just posting this here as a reference showing the effect of the 2 major values
for the irid {} finish.
turbulence was held at a constant 0.75, but anything between 0.25-1 works well,
and higher values might be useful for other effects.
Again, it's the environment that really lets you see the characteristic bubble
texture.
- BW
Download 'iridescencetests.png' (623 KB)
Preview of image 'iridescencetests.png'
Date: 24 Dec 2023 17:55:00
Message: <web.6588b5f7f07d5fbb1f9dae3025979125@news.povray.org>
I had the idea to render a similar scene showing the effect of varying the rgb
components of the irid_wavelength global setting.
https://wiki.povray.org/content/Reference:Global_Settings#Irid_Wavelength
Even though "You may have multiple global_settings statements in a scene."
Apparently, "Whatever values were specified in the last global_settings
statement override any previous settings." and this affects all the irid{}
statements, you can't sequentially assign different global settings to objects
in the same scene.
Kinda obvious, but I did it just to check.  Bummer.
I'm voting for irid_wavelength to be moved into the irid {} code of the finish
{} block in future versions.
- BW
Date: 27 Dec 2023 12:55:00
Message: <web.658c64aff07d5fbb4915286f3b2af915@news.povray.org>
> "Robert McGregor" <rob### [at] mcgregorfineartcom> wrote:
> Droj just posted his version, and with just a black background, it looked ---
> like poop.
> - BW
Yes BE, it looks like poop but it wasn't meant to show my artistic capabilities.
It was just a reminder for you that there is a example file for iridescence
coming with Povray.
I simply changed the pigment from white to clear using your data.
So put the blame on the author of the original file for not providing a nice
background.
- Droj
Date: 27 Dec 2023 13:25:00
Message: <web.658c6be8f07d5fbb1f9dae3025979125@news.povray.org>
> coming with Povray.
Yes, yes, I understand completely, and I knew I was flirting with disaster
trying to explain things.
> background.
No blame was being assigned, the point was that your texture is _beautiful_, but
if the user rendering a scene with it doesn't know the behaviour and limitations
of the irid {} feature, then a plain background will completely destroy it, and
beautiful as the texture might be - the end result is unfortunately....
I beg your humble pardon for any unintended offense.
- B "the ineloquent" E
Date: 27 Dec 2023 15:10:00
Message: <web.658c8081f07d5fbb4915286f3b2af915@news.povray.org>
> > coming with Povray.
> > background.
BE,
Honestly, no offense taken.
And it was not 'my texture' - the original is a Povray 3.7 scene file which I
'misused' in my strong belief to put you on the 'right track' when I saw your
first post. So no time for a neat background with tangerine trees and
marshmellow skies and a couple of fairies flying around.
And I am sure that you know what the coder gurus always used to say : RTFM! :))
- Droj
