POV-Ray : Newsgroups : povray.general : step by step Server Time
21 Mar 2026 03:28:37 EDT (-0400)
  step by step (Message 1 to 9 of 9)
Subject: step by step
Date: 20 Dec 2023 09:30:00
Message: <web.6582f9b0cbd9d54c87b92d44a57e0@news.povray.org>
Ok. bear with me. I know I should know this, and it is really basic, but between
my meds and my state of mind, I can't think of it.
I created this object
#declare floorframe = box{<0.283031,-0.001781,-0.001781>,
<0.283031,0.001781,0.501781>}
and starting at
object{floorframe translate<0,1.570883,0>}
I am placing them downwards in increments of 0.032059
until it stops at 0 or thereabouts (not below).
I actually crunched out 20 numbers until I remembered there is a way to do it
using steps, but God help me I can't remember how. Can you help me out?
Subject: Re: step by step
Date: 20 Dec 2023 10:25:00
Message: <web.658306faa8689bc37f6d9cf76cde94f1@news.povray.org>
hi,
> and starting at
guessing you're thinking of  '#for' loop.
<https://wiki.povray.org/content/Reference:Conditional_Directives#The_for_Directive>
regards, jr.
Date: 20 Dec 2023 10:40:00
Message: <web.65830a85a8689bc387b92d44a57e0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > and starting at
> regards, jr.
Ok I tried with
#for (ff,1.570883,0,-0.032059)
object{floorframe translate<0,ff,0>}
and there is no object. I thought that maybe it just moved one object downward
but it doesn't show at all.
Date: 20 Dec 2023 10:55:00
Message: <web.65830d92a8689bc37f6d9cf76cde94f1@news.povray.org>
hi,
> Ok I tried with
> #end
ah.  please post a "minimal" scene showing /reproducing the problem.  thanks.
regards, jr.
Date: 20 Dec 2023 11:25:00
Message: <web.6583144fa8689bc387b92d44a57e0@news.povray.org>
> hi,
> > Ok I tried with
> > #end
> regards, jr.
ummm
#version 3.5;
#include "colors.inc" // Standard Color definitions
#include "textures.inc" // Standard Texture definitions
#include "shapes.inc"
#declare position= <.375,.7 ,-2.5>; // used for camera and its associated camera
light.                            //2.337965
 background { color<0.0078125,0.51171875,0.8359375>}
camera
  location  position
 // look_at   <0.0 , 0.0 , 0.0>
box{<0.283031,-0.001781,-0.001781>,<0.283031,0.001781,0.501781>}
box{<-.28125,0,0>,<.28125,1.635,.5> pigment{Grey}}
 // upper right light
light_source{<1000, 1000, -5000>color White}
// upper left light
light_source{<-1000, 1000, -5000>color White}
it should show a series of black lines across the grey box like a ladder or
something. Basically, I intend to create a grid. I am making the horizontal
lines before the vertical ones. This loop doesn't give anything, however.
Date: 20 Dec 2023 11:35:00
Message: <web.658316c7a8689bc37f6d9cf76cde94f1@news.povray.org>
hi,
> ummm
> #version 3.5;
unsure but think '#for()' wasn't around then.  try a 3.7 / 3.8 executable ?
thanks for posting.  will have a look tonight.
regards, jr.
Date: 20 Dec 2023 12:05:00
Message: <web.65831d8fa8689bc387b92d44a57e0@news.povray.org>
> hi,
> > ummm
> > #version 3.5;
> regards, jr.
changed to 3.7. no difference.
Date: 20 Dec 2023 12:30:00
Message: <web.6583237da8689bc37f6d9cf76cde94f1@news.povray.org>
hi,
I used a 3.8.0-alpha, but with the '3.7' version directive.
I changed 'floorframe' to a 'box {0,1}' and in the loop gave the object a
different pigment on each iteration (just cycling through r/g/b).  the box does
move :-)  your "grey" box is "in the way", there are coinciding surfaces (I'm
guessing looking at output).  suggest/recommend you write the scene with simple
unit dimensions, and do the exact stepping / locating / sizing when you're happy
with the basic thing.  (if needed can clean up code and post later/tomorrow).
regards, jr.
Date: 20 Dec 2023 12:45:00
Message: <web.65832709a8689bc387b92d44a57e0@news.povray.org>
> hi,
> regards, jr.
Removed the grey box, ran it again and... OMG I'm so stupid. In the definition
of the floorframe box, the first X value is supposed to be negative. Fixed that
and now the code works.
