POV-Ray : Newsgroups : povray.general : Smooth level for smooth_triangle. Server Time
23 Sep 2025 01:49:21 EDT (-0400)
  Smooth level for smooth_triangle. (Message 41 to 50 of 56)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Smooth level for smooth_triangle.
Date: 24 Nov 2023 16:20:00
Message: <web.6561137284c692a3276109cb59126100@news.povray.org>
well, I have a little question because I have often read about "artifact" on
sooth_triangle but I don't understand. It is very difficult for me to translate
technical language and figurative sayings. Now I have started translating the
include files of my PovRay library that I interface with CAD, triangle to
smooth_triangle.
This wheel has black corners (two), on the right. Are these common artifacts, or
can I fix them?
Thanx in advanced!
G.
Download 'clipboard01.png' (168 KB)
Preview of image 'clipboard01.png'
Date: 24 Nov 2023 18:25:00
Message: <web.6561305284c692a31f9dae3025979125@news.povray.org>
> smooth_triangle.
> can I fix them?
> Thanx in advanced!
> G.
I think you might be seeing the same bug that I've been seeing.
instead of pigment, try using (_BOTH_)
texture {pigment {rgb 0.1} finish {specular 0.4}}
interior_texture {pigment {rgb x*0.2} finish {emission 1}}
And see if those "corners" turn red.
If so, we're seeing the underside of those triangles, when we shouldn't.
- BW
Date: 24 Nov 2023 18:55:00
Message: <web.6561377784c692a3276109cb59126100@news.povray.org>
> > smooth_triangle.
> > can I fix them?
> > Thanx in advanced!
> > G.
> - BW
THANKS! You are right, the red is here (elevated to see it better).
This knowledge is very useful! Many thanks again!
G.
Download 'clipboard01.png' (75 KB)
Date: 24 Nov 2023 19:10:00
Message: <web.65613abb84c692a31f9dae3025979125@news.povray.org>
> G.
Well, you're _supposed to_ see _that_ red - those are the undersides of the open
mesh - the inside of the tire.
You were talking about the "corners" on the upper right of the tire, which
should be smooth, and the same color as the rest of the tire.
And if you DO see red there, then try moving the camera around, and viewing it
from different angles - because it may just disappear and pop up in different
areas.
- BW
Date: 25 Nov 2023 03:45:00
Message: <web.6561b27884c692a3276109cb59126100@news.povray.org>
> > G.
> areas.
> - BW
I think you are just looking at preview image. If you open it you will also see
the triangles of the right we are talking about. I kept about the same point of
view just to check on my first image. It seems that they always arise on the
perimeter of the volumes (in positions tangential to the cone of vision)...
However, the internal color makeup is useful, it can help mask a bit the bug.
I think you could mask it a bit with a generic "finish" using the outer color of
the face
Thanks!
G.
Date: 25 Nov 2023 05:00:00
Message: <web.6561c4c584c692a39b4924336e066e29@news.povray.org>
> > areas.
Yes, that is where those artifacts sometimes appear on a smooth-triangle object.
I think it also depends on the lighting angle, and maybe even the size of the
triangles.
What you are seeing is a known effect of raytracing the smooth normals when they
are viewed at that raking angle. (I thought that there was a short technical
explanation of this in the documentation, but I cannot find it.) The camera is
picking up the unlighted (black) interior of the object.
If I make a low-rez height_field and add the 'smooth' keyword, the same thing
happens. The interior_texture trick is one way to try and make these artifacts
less noticable. Or try adding the 'double_illuminate' keyword to the object. If
I recall, this was a recommended 'fix' for the problem. It seems to work most of
the time, but not in every situation.
Download 'smooth_triangle artifacts_kw.jpg' (87 KB)
Preview of image 'smooth_triangle artifacts_kw.jpg'
Date: 25 Nov 2023 05:45:00
Message: <web.6561cfc684c692a3276109cb59126100@news.povray.org>
> > > areas.
> triangles.
Ok, thank! I am working on .. it does not seems by light position, but by the
angle between WP and smooth_triangle (s) ...
Many thanks again!
G.
Date: 25 Nov 2023 12:45:00
Message: <web.656231a884c692a3276109cb59126100@news.povray.org>
> > > > areas.
> > triangles.
> Many thanks again!
> G.
Bug hacked?
old sprites concept? I'm under no illusions, I'll do more tests, but in this way
I don't see the bug anymore
Download 'clipboard01.jpg' (122 KB)
Preview of image 'clipboard01.jpg'
Date: 25 Nov 2023 13:11:51
Message: <656238e7$1@news.povray.org>
> smooth_triangle.
> can I fix them?
> Thanx in advanced!
> G.
That can happen when you can see the triangle but it's normal is
pointing away from the camera.
Try rotating the tire along it's axis.
Date: 25 Nov 2023 13:15:00
Message: <web.6562387884c692a3276109cb59126100@news.povray.org>
it
different
> > > > > areas.
> > > triangles.
> > Many thanks again!
> > G.
> Bug hacked?
WOW!
right no trick
left the concept ... SHAPE-in-out XOR SWAPSHAPE-out-in
Download 'clipboard01.png' (198 KB)
