POV-Ray : Newsgroups : povray.general : Smooth level for smooth_triangle. Server Time
22 Sep 2025 23:30:33 EDT (-0400)
  Smooth level for smooth_triangle. (Message 27 to 36 of 56)
Subject: Re: Smooth level for smooth_triangle.
Date: 21 Nov 2023 19:55:00
Message: <web.655d510384c692a3276109cb59126100@news.povray.org>
"GioSeregni" <gms### [at] hotmailcom> wrote:
> There was an interesting comment with a utility to download, but now I don't see
> it anymore. Has it been cancelled? I took the obj and converted it to STL then
> applied my code to it, but without refinements in the environment. I tested his
> example with my program, because I had downloaded it, my render is poor.. it has
> no texture, it has no lights... I put the linked example but rendered with my
> version 3.7 (the file was 3.8 ) Strange, I can no longer find who posted and the
> content, thanks anyway!
NOW I understand! it hasn't disappeared, it's on another topic. Obj to POV...
Now I understand why I had artifacts. By transforming the obj into STL I already
had the normals with smooth, on which I intervened with a new smooth, mine, that
is, sorry, I made a mess :)
Date: 22 Nov 2023 07:05:00
Message: <web.655dee4084c692a31f9dae3025979125@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> Hi Bill
> Here's two relevant articles:
Hi Tor,
Thank you as always for sharing some of (what I'm sure is a very extensive)
reference library.
Luckily, I had written a fully chamfered box macro not too long ago, so I could
just piggyback off of that and get right to trying to calculate the normals and
replicate the work in that first paper.
I normalize all of my cross-product vectors before summing to get the "wrong
way" and then just use the direct cross-product result to try to get the
right/improved way - but it still doesn't look very smooth.  So I must have some
aspect of this that I didn't code right in that second macro.
(and even seeing the flaws is very lighting and camera angle dependent...)
However, aside from that, what I did find disturbing is that I have an
interior_texture defined for my smooth_triangles, and that's showing up, even
though my normals are facing the proper way.
So it seems like we're back to having some triangle mesh rendering errors in the
source, even after clipka hunted down and fixed the faux-mesh union-of-triangles
problem that I uncovered when making subdivided spheres.
See attached.
Maybe someone else can confirm.
- BW
Download 'weightedvertexnormals.png' (68 KB)
Preview of image 'weightedvertexnormals.png'
Date: 22 Nov 2023 13:45:00
Message: <web.655e4b5084c692a31f9dae3025979125@news.povray.org>
"- And then there's this paper, which delves deep into the topic:
"A comparison of algorithms for vertex normal computation"
Shuangshuang Jin, Robert R. Lewis, David West
The Visual Computer, 2005 - Springer"
Can't seem to find that one, even though my tax dollars probably funded the
research.  ;)
Is that a journal article, or part of _3D Imaging, Analysis and Applications
(Pears, Liu, Bunting) ?
- BW
Date: 22 Nov 2023 14:45:00
Message: <web.655e594d84c692a3176af99c89db30a9@news.povray.org>
> research.  ;)
It's here:
https://link.springer.com/article/10.1007/s00371-004-0271-1
Springer seems to have some kind of sharing feature for this.
So let's see of you can read it if you follow this link:
https://rdcu.be/drMhc
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 22 Nov 2023 15:35:00
Message: <web.655e650584c692a3f473065789db30a9@news.povray.org>
> > Hi Bill
> Hi Tor,
> reference library.
Yes, I have saved a lot of articles related to computer graphics (and
mathematics, photography, electronics and much more) on a lot of hard
drives during the years, but unfortunately I'm not able to keep track
of them.
So this time I googled a bit and then posted the ones that looked most
relevant and informative. (But I did remember that I had read somewhere
that there are more than one way of weighting the normal vectors of
triangles surrounding a vertex in a mesh, before summing them. And that
there's no single way to choose those weights so that one gets good
results in all cases.)
> See attached.
As you know:
It will be easier for us look at your problems if you show your code.
Tor Olav
http://subcube.com
Date: 22 Nov 2023 16:20:00
Message: <web.655e6d9984c692a39b4924336e066e29@news.povray.org>
> "Kenneth" <kdw### [at] gmailcom> wrote:
> I also thought that the normals of triangles are direction vectors of 'unit
> length' by default, not smaller or larger, but I could be wrong.
[and...]
> *If* the triangle normals are all unit length, perhaps your summing
> operation could be made to... [clip]
[Bald Eagle:]
> Triangles typically have a single normal - a vector that is perpendicular to
> its face (in either direction).
> The normal can be of any length.
> Typically, for lighting purposes, since the normal vector is used to calculate
> how light interacts with the surface, you want them of unit length.
Sorry for the confusion, I was actually thinking-- in a muddled way-- of the
original 'source' triangles from Giovanni's STL file.
Honestly, I did not know *what* length such normals there could be-- so I took
one of my 'slice-created' STL binary files made by the 3D SLICER app (mentioned
elsewhere), brought that into MESHMIXER, and converted it to an asci-text STL
file. The triangles-- or each vertex?-- are of this typical form (not
'smooth triangles', as far as I know)...
facet normal -0.107895597816 -0.696702897549 0.709199249744
    outer loop
      vertex 21.3610057831 0.39481022954 -0.11346334219
      vertex 22.4441795349 0.273843616247 -0.158073753119
      vertex 22.0666675568 -0.210549205542 0.393470913172
    endloop
In POV-ray, I took the 'facet normal' data/vector and ran it with vlength(...)
and #debug. It turns out that ALL of the triangles have a unit-length normal:
<1.000,0.000,0.000>, as vlength reports it.
[off-topic here but interesting}: The MESHMIXER app (also my CURA 3-D-printing
app) shows the STL object to have smooth edges-- even though the triangle
data appears to be 'un-smooth'. I have no idea why. Perhaps those apps are
automatically creating smooth triangles from the data. (Or maybe interpolating
the data from the individual vertices?)
Date: 22 Nov 2023 17:40:00
Message: <web.655e82b984c692a31f9dae3025979125@news.povray.org>
> As you know:
Yes, yes yes - I was on my way out the door to shovel snow and get out to The
Circus.
Link to shared article worked great.  Thank you.
Download 'weightedvertexnormals.pov.txt' (19 KB)
Date: 22 Nov 2023 17:50:00
Message: <web.655e854984c692a31f9dae3025979125@news.povray.org>
>     outer loop
>     endloop
And as you can see, that's about as close to SDL's triangle {} statement as
anything.
Well yes.  Those are going to be the final surface normals, and ought to all be
1.0.   The intermediate computations for calculating what the vertex normals of
smooth_triangles are can be anything.  The final normals, however, are almost
always going to get normalized, and so end up as length 1.0.   It's really the
direction of those normals that's going to influence how the light bounces off
of the surface from the light_source to the camera, and show up as either a flat
facet, a smoothly curving surface, or a normal {} pattern.
Yeah, I think that's just the way they get rendered.  There's likely a setting
that you can turn off, so you can see the raw stl mesh.
- BW
Date: 22 Nov 2023 18:05:00
Message: <web.655e85aa84c692a39b4924336e066e29@news.povray.org>
> ..and converted it to an asci-text STL file. The triangles-- or each
> vertex?-- are of this typical form (not 'smooth triangles', as far as I know)...
>     outer loop
>     endloop
Just to follow up, after a little more research:
FACET means the entire triangle, not an individual vertex. STL files are
composed of flat triangles, not smooth ones. Giovanni's STL image show this too.
I am not very happy that MESHMIXER (and CURA) show 'smooth triangle' versions of
the file; I would rather see the raw-triangle representation there. And it seems
that CURA also *outputs* its .stl-to-.gcode 3-D-printing file as a
smooth-triangle version, according to tests that I have made. I have mixed
feelings about that...
Date: 23 Nov 2023 03:55:00
Message: <web.655f119c84c692a39b4924336e066e29@news.povray.org>
> > data appears to be 'un-smooth'. I have no idea why...
Finally found it in MESHMIXER-- it takes two steps. Apps that have lots of
features have lots of menus to learn :-/
     PREFERENCES:  choose 'face normals'
     VIEW: choose 'wireframe'
BTW, I was wrong about the CURA app automatically smoothing an STL model prior
to 3-D-printing it; the fault is in the STL output of that complicated 3D SLICER
app that I've been testing. I have to find where to turn that off (as an
option.)
[more on-topic, hopefully...]
I downloaded a few STL files made by others, to take a look at their triangle
meshes in MESHMIXER. There can be some complicated triangle arrangements in such
files! Even on what look to be completely flat surfaces. I guess the many
vertices have meet up *somewhere*.
Download 'example_stl_mesh.jpg' (97 KB)
Preview of image 'example_stl_mesh.jpg'
