POV-Ray : Newsgroups : povray.general : L-Systems in Povray Server Time
16 Mar 2026 02:07:34 EDT (-0400)
  L-Systems in Povray (Message 21 to 30 of 64)
Subject: Re: L-Systems in Povray
Date: 5 Jun 2023 13:25:00
Message: <web.647e1a39453cebfc17bac71e8ffb8ce3@news.povray.org>
"ingo" <nomail@nomail> wrote:
> Pov-Ray    : 3.8
> Scene File : lsys.pov
> Author     : Ingo Janssen
> Date       : 2023-06-04
> #version 3.8;
> global_settings{ assumed_gamma 1.0 }
> #default{ finish{ ambient 0.1 diffuse 0.9 }}
> //build rules
> #declare BuildRules = dictionary;
A little bit of code to stick to the end of the lsys.pov scene file, render and
have a look in your source directory.
Just for fun and again, a little crude:
#declare Height = 10;
#declare Width = 10;
#declare StrokeWidth = 0.3;
#declare FileName = "SVGfile.svg";
#fopen SVG FileName write
#write (SVG concat("<svg xmlns=\"http://www.w3.org/2000/svg\" height='",
str(Height,0,0), "' width='", str(Width,0,0), "' fill='blue' stroke='blue'
stroke-width='", str(StrokeWidth,0,3),"'>\n"))
#for(i, 0, dimension_size(Vertices,1)-2)
  #declare Line = concat("<line x1='", str(Vertices[i].x,0,1),"'
y1='",str(Vertices[i].y,0,1),"' x2='",str(Vertices[i+1].x,0,1),"'
y2='",str(Vertices[i+1].y,0,1),"'/>\n") ;
  #write(SVG Line)
#fclose SVG
Date: 5 Jun 2023 15:55:00
Message: <web.647e3d46453cebfcb49d80446cde94f1@news.povray.org>
hi,
> > Pov-Ray    : 3.8
> > Date       : 2023-06-04
have copied the code and run once, but not yet investigated.  looking forward to
that, though :-).
missing the closing '</svg>'.  size too is .. suspect, I see only a small part
of the curve.  (sorry, hope to find some time tomorrow)
regards, jr.
Date: 5 Jun 2023 16:20:00
Message: <web.647e4364453cebfc17bac71e8ffb8ce3@news.povray.org>
Ah, good catch on the closing tag.
I didn't scale it. Havingthe origin at the top left point of the screen always
makes my brain hurt.
ingo
Date: 6 Jun 2023 09:20:00
Message: <web.647f3222453cebfcf62c2adc3b2af915@news.povray.org>
> "Droj" <803### [at] drojde> wrote:
> > I would love to see how you implement the third dimension!
> Go ahead Droj,
> grab the code and experiment. I abused the vector to make it work for 2d + angle
> in a single data container. For 3, or more, dimensions, you have to separate
> angle and position. Use two separate vectors or arrays. Or use a dictionary that
> contains the pos and angle and other stuff you want to add in the future. For
> example a LIFO array as a stack for push and pop operations.
> #macro F(Pos, Angle)
> #end
> For me it was a proof of concept and I'll keep it that way. No new rabbit hole
> for me at the moment.
> Cheers,
> ingo
Ingo,
thanks for your advice. It will all take a WHILE. Have to learn coding first.
Droj
Date: 6 Jun 2023 13:25:00
Message: <web.647f6b04453cebfcb49d80446cde94f1@news.povray.org>
hi,
> > grab the code and experiment. ...
heh, don't beat yourself up.  since you've been "using Povray (as a bloody user
of course) for more than 35 years", I'm pretty sure you won't .. faint at the
sight of a '#while' :-).
regards, jr.
Date: 6 Jun 2023 16:20:00
Message: <web.647f90f4453cebfcf62c2adc3b2af915@news.povray.org>
> hi,
> regards, jr.
Hi jr,
not faint at the sight of a #while but of (a) 35 years WHILE I've been missing
crucial things in Povray :-)).
Being a _bloody_user_only (starting with Povray 2.? and Moray 1.5, MS DOS
versions) now 'wasted WHILE time' strikes back.
I feel like Ingo got me by the 'short hair': I am able to use a macro (most of
the times), sometimes adapt something (happy when it works, if not: depressed),
understanding the concept (sometimes - more or less - not 'word by word') but
separating positions and angles for 3D / creating a LIFO array - that's way
beyond me.
I'll try to do my best but to cover that gap is a huge thing. At least I could
add something to Ingo's code to produce the 'Pentaplexity' (still crude using
Ingo's words).
Thanks for cheering me up
Cheers, Droj
Download 'lsys6.png' (771 KB)
Preview of image 'lsys6.png'
Date: 7 Jun 2023 00:55:00
Message: <web.64800d44453cebfc17bac71e8ffb8ce3@news.povray.org>
Pos is an 'abused' vector. <x,y,angle>. Instead I could have used:
#local Pos2D = <x, y>;
#local Angle = 25;
Now angle and location are separated.
So
#macro F(Pos)
  <Pos.x + cos(Pos.z), Pos.y + sin(Pos.z), Pos.z> // <x, y, angle>
#declare BuildRules["F"] = 70; //chr(70) = F
becomes
  <Pos2D.x + cos(Angle), Pos2D.y + sin(Angle)> // <x, y>
  //the angle is fixed
#macro Plus(Pos)
  <Pos.x, Pos.y, Pos.z + (pi/2)>
#declare BuildRules["+"] = 43;
#macro Plus(Angle)
  Angle + (pi/2)
And
    #ifdef (BuildRules[CurrentSymbol])
      #switch (BuildRules[CurrentSymbol])
        #case(70)
          #local Pos = F(Pos);
        #break
        #case(43)
          #local Pos = Plus(Pos);
        #break
becomes
        #case(70)
          #local Pos = F(Pos, Angle);
        #break
        #case(43)
          #local Pos = Plus(Angle);
        #break
now the Pos vector and angle are separated. The next step is to turn them into
3D vectors. You can use a 3D vector for the three angles too.
(untested code)
Date: 7 Jun 2023 15:45:00
Message: <web.6480ddb8453cebfcb49d80446cde94f1@news.povray.org>
hi,
looking at the image posted, methinks thou protest too much.  </grin>  v nice.
> beyond me.
> Ingo's words).
re LIFOs, have a look at 'queues.inc'.  (even though the demos suck)
regards, jr.
Date: 8 Jun 2023 16:30:00
Message: <web.648235b3453cebfc9f5def123b2af915@news.povray.org>
> hi,
> > beyond me.
> > Ingo's words).
> regards, jr.
that was the 'piece-of-cake' part for the 'bloody user'.
I tried Ingo's advice separating location and angle. Whatever I did Povray
complained ("Float expected, but ... found instead" or "Bad operand for dot
expression"). Now I know why he warned me with <untested code>.
Will still investigate where I took the wrong turn.
I had a look at your 'queues.inc'. I'm still goggle-eyed with my mouth agape!
</)):-o>
I wouldn't say the demos suck - maybe a bit too 'academic' or not 'descriptive'.
Still I have to chew on LIFO and maybe can digest it - not sure - that's for
sure.
But I will not give up.
My objective is to get that Lparser thing working with Povray (or die). Forget
the last words.
regards, Droj
Date: 8 Jun 2023 18:55:00
Message: <web.64825c2e453cebfc1f9dae3025979125@news.povray.org>
Quote the line and post the exact error.   We run into these things all the
time, and sometimes they're a bit hard to decipher without help.
> </)):-o>
Yeah - jr's code isn't exactly readable for those not well-versed with
dictionaries, and his unique style of coding.  He does code up some amazing
stuff though.  And document it like a BOSS.
> sure.
WTH is "LIFO" ?
That's the spirit.
- BW
