POV-Ray : Newsgroups : povray.general : Centring a text object declaring a directive Server Time
15 May 2025 01:29:09 EDT (-0400)
  Centring a text object declaring a directive (Message 1 to 5 of 5)
Subject: Centring a text object declaring a directive
Date: 19 Apr 2023 07:40:00
Message: <web.643fd2662f53e92c65103170d427f3e5@news.povray.org>
I align a text object as
local MyText=text {ttf "timrom.ttf", "Some text",1,0 }
object { MyText
   translate -(min_extent(MyText) + max_extent(MyText)) / 2
`Center_Trans` in transforms.inc is also based on the same approach.
I wonder if there is a way to do so without defining the directive of `MyText`.
I mean something like `min_extent()` of the current object.
Subject: Re: Centring a text object declaring a directive
Date: 19 Apr 2023 08:55:00
Message: <web.643fe36e59e0b6654301edef6cde94f1@news.povray.org>
hi,
> object { MyText
not sure about objects in general, but with a text{} you could "cheat" using a
macro, eg:
#macro textLen(font_,s_)
  #local t_ = text {ttf font_, s_, 1, 0};
  (max_extent(t_).x - min_extent(t_).x)
#declare txt_ = text {
  ttf "timrom.ttf", "some more text", .1, 0
  texture {texture_}
  translate <-(textLen("timrom.ttf","some more text")) / 2,-2,0>
object {txt_}
regards, jr.
Date: 19 Apr 2023 19:15:00
Message: <web.644074f459e0b66565103170d427f3e5@news.povray.org>
> macro, eg:
> #end
>   texture {texture_}
> object {txt_}
> regards, jr.
Your solution works like a charm. My problem was exactly the text. It is easier
to find the middle point for an object as we design them, but for texts, we rely
on font metrics.
Thanks!
Date: 20 Apr 2023 04:55:00
Message: <web.6440fd1159e0b6654301edef6cde94f1@news.povray.org>
hi,
> on font metrics.
> Thanks!
great :-)  pleasure.
regards, jr.
Date: 23 Apr 2023 04:13:04
Message: <6444e890@news.povray.org>
> macro, eg:
> #end
>   texture {texture_}
> object {txt_}
Following jr's good idea and even if you have to use macro, you might as
well make a "complete" one :
#macro MakeCentetText (pText, pFont, pThickness, pOffset, pTexture)
 #local _t = text { ttf pFont pText pThickness, pOffset }
 #local _l = (max_extent(_t).x-min_extent(_t).x)*0.50;
 object { _t translate -_l*x texture { pTexture } }
and using it like this :
object {
 MakeCentetText("some more text", "timrom.ttf", 0.10, 0, myTexture )
Kurtz le pirate
Compagnie de la Banquise
