POV-Ray : Newsgroups : povray.general : Area Light Setup Server Time
2 May 2024 16:19:26 EDT (-0400)
  Area Light Setup (Message 11 to 16 of 16)
Subject: Re: Area Light Setup
Date: 28 Jan 2023 11:00:00
Message: <web.63d545f610df5b0e1f9dae3025979125@news.povray.org>
> On 2023-01-25 12:22 (-4), Alain Martel wrote:
> > Any sampling array size between those values will be silently increased
> > to the following size of the list. A 4 x 4 adaptive is really 5 x 5, 6 x
> > 6 is promoted to 9 x 9 and 10 x 10 become 17 x 17.
> Not according to my tests.  The attached images were rendered with
> area_illumination to reveal the internal array of lights.
That's a cool render - you always come up with some of the most interesting
ideas, techniques, and methods.
Did you just make an area light that's parallel to the checkered plane and then
point the camera down to look through it and so see the reflection of the light?
Date: 28 Jan 2023 11:59:34
Message: <63d55476$1@news.povray.org>
> So, shining an area_light with adaptive AND area_illumination thru a
> small opening changes how adaptive work. Interesting.
There is no change in behavior.  The documentation reads:
  "For example area_light x,y,4,4 specifies a 4 by 4 array of lights. If
  you specify adaptive 3 it would mean that you should start with a 9 by
  9 array. In this case no adaptive sampling is done. The 4 by 4 array
  is used."
There is no mention of any increase in the array size, with or without
area_illumination.  Plus, I examined the source code, and I cannot find
anyplace where the array size is changed after being parsed.
> Did you try without area_illumination ?
The experiment does not work without area_illumination.  The scene file
uses an area light very close to the surface, and no shadows are involved.
Date: 28 Jan 2023 12:01:24
Message: <63d554e4$1@news.povray.org>
Yes.
Date: 28 Jan 2023 12:21:26
Message: <63d55996$1@news.povray.org>
>    is used."
I've done a similar test. In that test, I did not use adaptive nor
aera_illumination.
In my test, all the spots are sharp, not fuzzy as in your test.
Date: 28 Jan 2023 12:40:00
Message: <web.63d55d7b10df5b0e1f9dae3025979125@news.povray.org>
> Yes.
Wow.  Much laconic.  Such taciturn.  So not verbose.  Very wow!
+ 1000 POV points
Date: 29 Jan 2023 09:08:55
Message: <63d67df7$1@news.povray.org>
>>>>> increased
>>>>> 5, 6 x
>>    is used."
>> involved.
> aera_illumination.
Cousin Ricky's set up doesn't cast shadows.
I believe the amount of fuzziness likely comes from the angle of the
light relative to the plane in Cousin Ricky's set up where the area
light is very close to the surface of the plane. You get the same sort
of fuzzy / fading result with a single point source very close to a surface.
How sharp the result depends on stuff... Stuff like the light's fade
power / distance and the brilliance setting of the finish. An
interesting experiment would be to add a finish { brilliance 0.1 } to
the plane and see what happens in a set up like CR's.
As for the sampling array sizes... The current actual behavior is
complicated. Results look to get mapped back to a fixed 'lightGrid'
based upon the original size specification, but, the way the testing is
done when deciding whether to recursively call in
traceAreaLightSubsetShadowRay and whether sub-area positions are already
calculated will often enough lead to extra work(a). So counts depend on
what you are counting and the particulars of the scene.
Bill P.
(a) - Our current adaptive set up is used even when we might want to use
all the area (size1 x size2) sub positions(b). In other words, when not
using an 'adaptive n' specification(c) or using a relatively high
minimum adaptive depth, the recursive calls 'could' be avoided
altogether for better performance. Further, the on the fly adaptive
calculations for the recursive set up involve floor() and ceil() which
are expensive. I suspect there's room for some optimization...
(b) - Like any adaptive algorithm, there will be situations where the
adaptive test and exit stops too early. This the reason we can force a
minimum number of area sub-positions be used before any adaptive
consideration. Where we must force a high minimum to avoid artefacts, I
suspect there is not much (any?) visual value left in the 'adaptive'
part of the area light feature; A purely 'flat' code approach would
likely be faster in such cases... ;-)
(c) Internally the adaptive / depth value is set to 100 when no area
light, adaptive value is used. In such case we are still using the
recursive, adaptive algorithm to get a 'flat' area light result.
