POV-Ray : Newsgroups : povray.general : eval_pigment? Server Time
22 Sep 2025 21:07:43 EDT (-0400)
  eval_pigment? (Message 1 to 9 of 9)
Subject: eval_pigment?
Date: 20 Nov 2022 17:15:00
Message: <web.637aa501551c4c16fa4e42acf712fc00@news.povray.org>
Related to the post above.. Why was eval_pigment dropped? Why not expand it?
If not kept as a built in function, why not put it in one of the include files?
Have Fun?
Subject: Re: eval_pigment?
Date: 20 Nov 2022 18:10:00
Message: <web.637ab386287863e91f9dae3025979125@news.povray.org>
> Have Fun?
eval_pigment is a macro in the functions.inc file.
It is, as has been pointed out in the past, simply a wrapper for a pigment
function.
#macro eval_pigment(pigm, vec)
    #local fn = function { pigment { pigm } }
    #local result = (fn(vec.x, vec.y, vec.z));
    result
You plug in your <x, y, z> vector, and out pops the <r, g, b> color vector at
that point in the pattern, image_map, etc.
Date: 20 Nov 2022 18:45:00
Message: <web.637abb91287863e9d3631ec089db30a9@news.povray.org>
> > Have Fun?
> function.
>     result
> #end
Hi
Naming functions is often problematic.
So suggest that that macro is rewritten, e.g. like this:
#include "vectors.inc"  // https://github.com/t-o-k/Useful-POV-Ray-macros
#macro EvalPigment(Pigment, v0)
    FunctionValue(
        function {
            pigment { Pigment }
        v0
#end // macro EvalPigment
Tor Olav
http://subcube.com
Date: 20 Nov 2022 19:30:00
Message: <web.637ac592287863e91f9dae3025979125@news.povray.org>
It is.   But masking the true nature of what the macro does, and probably
slowing down the scene seems (to me) to be far worse.
Would not a simple one line
function {pigment { Pigment }}
be perfectly adequate, easily enough understood, and encourage greater education
and understanding about how _so many_ thing in POV-Ray really work?
I learned so much, and understood so much more, when I made all the connections
between functions, pigment patterns, isosurfaces, parametrics, and uv-mapping.
Even the recent question about interpolating color_map values is something I
would have never been able to adequately answer, if at all, only a few years
ago.
Date: 20 Nov 2022 20:05:00
Message: <web.637acddc287863e9d3631ec089db30a9@news.povray.org>
I don't think that what I suggesting is trying to mask anything. It is just an
attempt to make robust macros that doesn't create strange problems for the
users.
And understanding how to pass arguments to macros and functions is something
that I think a lot of POV-Ray users will benefit from understanding. (Sorry,
that was probably not good English language.)
Yes, in user created code, like the code you just posted, I think it is all ok
to name functions. I think your code was relatively easy to understand. But in
include files for use by many others I think we should be careful.
> ago.
Yes it's hard work and takes a lot of reading and experimenting.
Today, after you posted your code in the "colors map interpolation" thread, I
learnt a new thing about splines. I was about to suggest that this code be used
to return color vectors corresponding to the colors in the color map:
#declare VectorSpline =
    spline {
        linear_spline
        0.00, <1.00, 0.00, 0.00>,
        0.50, <1.00, 1.00, 0.00>,
        1.00, <0.00, 0.00, 1.00>
But I found that the interpolation in splines, does not happen in the same way
as in color maps.
This spline:
    spline {
        linear_spline
        0.50, <1.00, 1.00, 1.00>,
- results in different colors than this color map:
color_map {
    [ 0.00 rgb < 1.00, 0.00, 0.00> ]
    [ 0.50 rgb < 1.00, 1.00, 1.00> ]
    [ 0.50 rgb < 1.00, 1.00, 0.00> ]
    [ 1.00 rgb < 0.00, 0.00, 1.00> ]
It seems that splines can only deal with one value or vector for each "knot".
Tor Olav
http://subcube.com
Date: 20 Nov 2022 21:00:00
Message: <web.637adb44287863e91f9dae3025979125@news.povray.org>
> users.
The masking is just something that happens incidentally - people know if
eval_pigment, but have no idea how it works.  It becomes POV-Ray magic by
default.
Indeed.   Bill Pokorny, jr, myself, and others have run into that namespace
problem.
>     spline {
>         linear_spline
> as in color maps.
Try again, but be aware that POV-Ray uses different types of interpolation with
the different blend modes.
https://wiki.povray.org/content/Reference:Color_Map
I'm sure your spline is using linear interpolation, whereas the default might be
 in sRGB space.  It's extremely confusing until you get how all the "color math"
works in context, and even then I tend to run into problems or get it completely
backwards.
Date: 22 Nov 2022 12:45:00
Message: <web.637d08aa287863e9f64179a3f712fc00@news.povray.org>
> Have Fun?
My Bad.. What I thought was 'eval_pigment' was drop. The real problem was
documentation.
 The help file on my POV 3.7 RC7 didn't have 'eval_pigment' in the Index. I
still have 3.6 and 3.5 on my computer, they still have it. But the page they
take you to had nothing about being in 'functions.inc'. That information is
several pages away and I never did find it.
 As soon I found out that 'eval_pigment' was in 'functions.inc". I went to the
POV3.7 and found that the Help Contents lead me to 'eval_pigment' through
'functions.inc" ( the same page that's in POV3.6 & 3.5)
 Now that's taken care of, While I was waiting for replies, I wrote my own
'Eval_pigment' & 'Eval_Cmap' &'Eval_ObjPig' macros.
#macro Eval_Pig(Pig,V)
 #local V=V*<1,1,1>;
 #local Fna=function{pigment{Pig}}
 Fna(V.x,V.y,V.z)
#macro Eval_Cmap(Cmapp,V)
 #local V=V*<1,1,1>;
 #local Pig=pigment{gradient x color_map{Cmapp}}
 Fna(V.x,V.y,V.z)
// Obj - object with pigment
// Pig - pigment seperate from object but translated with object
// N   - trace intersect normal to center of object
#macro Eval_Obj_Pig(Obj,Pig,N)
  #local Mx=max_extent(Obj);
  #local Mn=min_extent(Obj);
  #local Mc=(Mx+Mn)/2;
 #local Norm = <0, 0, 0>;
 #local Start =vlength(Mx-Mn)*N+Mc;
 #local V = trace (Obj,Start,-N,Norm );
 #if (Norm.x != 0 | Norm.y != 0 | Norm.z != 0)
  #local R=Fna(V.x,V.y,V.z);
 #else
  #local R=<0,0,0>;// default color
 R
Thanks for the help!
Have Fun!
Date: 22 Nov 2022 17:55:00
Message: <web.637d52cd287863e9d3631ec089db30a9@news.povray.org>
>  #else
>  #end
>  R
> #end
Hi Leroy
If you want a faster macro then you'll probably find that this statement:
    #if (vlength(Norm) > 0)
executes faster (and is easier to read) than this:
Tor Olav
http://subcube.com
Date: 23 Nov 2022 23:05:00
Message: <web.637eec67287863e9714dcffbf712fc00@news.povray.org>
> >  #else
> >  #end
> >  R
> > #end
> Hi Leroy
> Tor Olav
> http://subcube.com
Yes I know got lazy & use trace from
the insert that came with POV3.7 win
