POV-Ray : Newsgroups : povray.general : mesh camera for UV-mapping output Server Time
15 May 2025 04:42:05 EDT (-0400)
  mesh camera for UV-mapping output (Message 1 to 10 of 13)
Subject: mesh camera for UV-mapping output
Date: 12 Nov 2022 04:10:00
Message: <web.636f61b78f6664eb8f2c9d9baa81652d@news.povray.org>
May I ask an important question?
When I using mesh_camera, (for texture baking), its coverage is not sufficient
at the edge(seams). Just like the document said:
If used for texture baking, the generated image may have visible seams when
applied back to the mesh, this can be mitigated. Also, depending on the way the
original UV map was set up, using AA may produce incorrect pixels on the outside
edge of the generated maps.
Has this problem been solved?
Here is the output image from UberPOV version 1.37.1.1-alpha.8756754
Download 'uv_test_pov_scene ver6.png' (128 KB)
Preview of image 'uv_test_pov_scene ver6.png'
Subject: Re: mesh camera for UV-mapping output
Date: 12 Nov 2022 04:25:00
Message: <web.636f65eba8b89d338f2c9d9baa81652d@news.povray.org>
Then applied the image to the mesh(for texture):
It has a visible seam.
Download 'finish.png' (846 KB)
Preview of image 'finish.png'
Date: 12 Nov 2022 04:50:00
Message: <web.636f6b18a8b89d338f2c9d9baa81652d@news.povray.org>
No matter I use AA or not, this seam exist.
If it cannot be eliminated with POV-Ray, I will write a small program for my
self to extend the color(maybe 2~ 3 pixel). But It is more like what POV-Ray can
finish.
Download 'thought.png' (175 KB)
Preview of image 'thought.png'
Date: 12 Nov 2022 07:13:27
Message: <636f8de7$1@news.povray.org>
I'm not aware of a general solution. I don't generate or use uv maps
much, but some ideas.
- If you are not using interpolation when reading the image map, suspect
using it might lesson the seam artifact in your case. Interpolation may
also introduce seams in other cases I think.
- For simpler shapes using the matching camera type - ie spherical
camera - to create the map images and then the same image_map mapping
will be cleaner than mesh based texture baking and uv mapping.
- What happens if you generate your map image with a higher resolution
mesh than that to which you map in the actual render? It might be too,
higher resolution image maps (denser mesh camera), help.
- IIRC, there are some suggested ways to bake map images via meshes
while doing some AA via different meshes which might help. I've never
played with the technique outlined. I suspect POV-Ray's inbuilt camera
ray AA won't be of much help.
- Scaling your uv map image up say 2x/3x in an external program will
likely mitigate the seams.
- Have you tried rendering at different output resolutions to see how
any seams might change? (Rendering large and shrinking a help?)
I have for a long time wondered how seams in the map image are handled
in the non POV-Ray cgi game. There images are typically cookie cutter
sheets for different parts of the uv mapping onto the overall mesh. Maps
I've played with 'sometimes' have visible seams too which in my
experience often do create minor artifacts...
When we read an image map we can use (pixel) interpolation - but we
perhaps should not where image maps used for uv mapping (or for any
non-continuous mapping such as images for cubic warps). The reason is
the seams cut off sharply in many uv image maps and any interpolation
will be looking at adjacent (or wrapped) pixels and not pixel adjacency
as the image is used in uv mapping on the mesh. This, I think, forces us
to higher resolution maps than might otherwise be required for smooth
rendered results.
It is possible with cubic warp mapped images, for example, to create the
images in a way which looks for and includes the correct adjacent pixels
at the seams so that smaller, interpolated images can be used while uv
mapping. I think I posted about some of my experiments - using user
defined cameras to create such 'interpolate-able' images. Unsure how to
do this in general. Perhaps there are too some post initial image mesh
walking AA / smoothing techniques possible, but I'm not aware of
anything like a canned program though.
Anyhow... Interested.
Bill P.
Date: 12 Nov 2022 09:25:00
Message: <web.636fab54a8b89d338f2c9d9baa81652d@news.povray.org>
> rendered results.
> Bill P.
Thanks for your reply.
I have just tried interpolation, when using 'closest(no interpolation)', or
'linear', or any other option it introduce an artifact line. The seams is narrow
but sharp when using 'closest', a little wider when using interpolation(my
example image using 'linear').
When I generate a 2048x2048 (higher resolution texture image) then applied,
compared to the 1024x1024(first one of this thread), its artifact seams looks
smaller but still exist.
Download 'finish using 2048x2048 texture.png' (844 KB)
Preview of image 'finish using 2048x2048 texture.png'
Date: 13 Nov 2022 03:25:21
Message: <6370a9f1$1@news.povray.org>
Thanks for the info. On the 2x scale up; I'm wondering if we might not
get better results still with a non-integer multiple in size for the map
image - say 1.7x or 2.5x.
Are you always using AA for these test renders? If so/when, which
method? (In v3.7/v3.8 there is in method 1 some bias down and to the
right)
You're using a version of UberPOV. I remembered on rolling out of bed
this morning that at some point after v3.7, Christoph corrected a long
standing ~half pixel offset in how the AA ray sampling was getting done
(I think just for method 2, but my memory is fuzzy). There was initially
a bug in this fix causing issues with AA results in general which
persisted for 2-3 months of releases. I have no idea where your release
of UberPOV falls relative to this AA work and the later fix for the bug
introduced with the initial fix.
Aside: My povr branch supports method 2 AA with 'big jitter (>1.0)' and
jitter which is again random (v3.6 and prior like). With it one can
sample in a 'non-shrinking to grid way' with controllable bleed in
sampling into adjacent pixels. This 'big jitter' feature likely can help
hide the seam artifact (as with artifacts in general).
The existing v3.7/v3.8 fixed/repeatable jitter method has some
unfortunate bias issues making it different, but often no better, than
no jitter at all. Details exist in a post somewhere on the newsgroups.
Anyhow, if using AA, have you tried running with and without jitter on?
Bill P.
Date: 14 Nov 2022 11:15:00
Message: <web.637268cca8b89d339adc1f7aa81652d@news.povray.org>
I render a 4800x4800 map with the same setting this time.(attachment image)
> right)
I always use this setting:
Antialias=On
Antialias_Threshold=0.05
Sampling_Method=1
Antialias_Depth=4
Quality=11
+SP32
+EP32
> Bill P.
I never tried using jitter with these series. And I use it seldom...
I'm not aware this. I just want to produce mesh based texture baking. (for
general modeling shape produced with Blender)
Download 'finish using 4800x4800 texture.png' (853 KB)
Preview of image 'finish using 4800x4800 texture.png'
Date: 14 Nov 2022 11:30:00
Message: <web.63726bd1a8b89d339adc1f7aa81652d@news.povray.org>
I tried jitter just now. But I cannot distinguish the result.
(add this on povray.ini)
Jitter = true
1024x1024 output:(same size as the first blender image of this thread) -> uv-map
Download 'finish using 1024x1024 with jitter texture.png' (828 KB)
Preview of image 'finish using 1024x1024 with jitter texture.png'
Date: 17 Nov 2022 16:13:02
Message: <6376a3de$1@news.povray.org>
> Antialias=On
> Sampling_Method=1
> Antialias_Depth=4
Saw the other post. For AA, it'd be interesting to see if
Antialias_Threshold=0.015
Sampling_Method=2
gives a better / different result.
Aside: There is too method 3, but unsure where uberPOV is with respect
to that code. UberPOV's implementation of method 3 came first and did
not match exactly what made it into v3.8/v4.0 - IIRC. Further, I believe
it still the case, all the official implementations have the potential
run-away / run to max samples issue when one or more color channels goes
negative(a,b) due floating point rounding errors.
(a) - The runaway situation consumes a lot of time, but also is where I
suspect method 3 returns the best end result.
(b) - The fix, posted about somewhere in the newsgroups, was to add code
which clamps all negative color channel values to zero so that sqrt()
functions used by method 3 are happy.
Bill P.
Date: 19 Nov 2022 05:45:00
Message: <web.6378b2e7a8b89d33dd697a1baa81652d@news.povray.org>
Wow, you use Antialias_Threshold=0.015
such a small value.
At beginning, I think this value should take only one place next to decimal
point. 0.1 is its minimum, or zero, but zero will calculate every pixel, so not
very fine to me...
After one day, I found it can assign a more meticulous value, so I use 0.05.
I think it is good enough.
I don't know the habit of other people.
(I means when I render several types of pictures, not particularly to texture
map)
Sampling_Method=2
Oh, ... I seldom use it after my learning and investigate the anti-alias.
Recursive method take many time to render is my opinion. Maybe I don't need such
meticulous sampling yet.
Sampling_Method=3
?? I don't know it.
