POV-Ray : Newsgroups : povray.general : Minimum Distance Function Server Time
27 May 2024 15:20:37 EDT (-0400)
  Minimum Distance Function (Message 21 to 30 of 39)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: Minimum Distance Function
Date: 11 Jul 2022 17:30:00
Message: <web.62cc95526fb4e448864166f75d51d79c@news.povray.org>
> What if instead of re-transforming the mesh data, you transform the reference
> point to measure the length?
> Then it's only ever one transform in either direction.
That is exactly what I tried, if I am understanding you.
I want to find the distance from point P to mesh M (which contains
vertex/triangle data as well as a transformation).
So I tried basically this:
P_inv = InverseTransformPoint(P, M->Trans)
N = NearestPoint(P_inv, M->Data)
V = N - P_inv  // get the vector from P_inv to N
V_trans = TransformDirection(V, M->Trans)
If(Inside(P, M))
  distance = -Length(V_trans)
Else
  distance = Length(V_trans)
....and the result was much worse than finding the distance from point P to mesh
M (which contains transformed vertex/triangle data), but doing this:
N = NearestPoint(P, TransformAllVertices(M->Data, M->Trans))
V = N - P
If(Inside(P, M))
  distance = -Length(V)
Else
  distance = Length(V)
I mean, obviously the second one looks cleaner, as well, but it hides all the
code required to make sure M->TransformedData is there to use.
Date: 12 Jul 2022 06:10:16
Message: <62cd4888$1@news.povray.org>
> If(Inside(P, M))
> Else
FYI. A chance the following inside_vector issue in play.
"Leaving mesh inside_vector untouched on transforms."
https://github.com/POV-Ray/povray/pull/361
IIRC this closed / not merged pull was last Christoph's version over my
original suggested fix on the developer mailing list. For reasons
unknown to me it never got merged into the official code base. I got
tired of re-basing branches on code updates and eventually closed it.
There is too - and also still - the issue that our documentation
suggests an axis aligned inside vector. This an unfortunate suggestion
given things like buildings are often axis aligned and any time the
inside vector is very close to perpendicular to a face's normal, the
mesh inside test becomes noisy.
Bill P.
Date: 12 Jul 2022 10:00:00
Message: <web.62cd7d6f6fb4e448864166f75d51d79c@news.povray.org>
That merge request changes the inside_vector test to use MInvTransPoint instead
of MInvTransRay followed by a Normalize, which makes sense to me.
In the version where I don't transform the mesh vertex data, I am doing
MInvTransPoint to tranform the test point, computing the minimum distance Vector
from the transformed test point to the original mesh data, then using
MInvTransDirection to transform that Vector using the mesh's Trans, then using
the length of the transformed vector as the distance.
The result obtained this way is a lot worse.
I wonder if there are cases where it would actually get a *wrong* answer, not
just loss of precision...such as the case where the object is scaled
non-uniformly. I think you can come up with an easy example where this is the
case where a "fat" ellipse that has a larger diameter in the x/y plane is scaled
such that it has a larger diameter in the x/z plane. Looking at the point at the
center of the ellipse, the minimum distance direction vector would switch from
<1, 0, 0> to <0, 1, 0> (for example).
Date: 12 Jul 2022 16:10:00
Message: <web.62cdd4626fb4e448864166f75d51d79c@news.povray.org>
Well, I think I have decided that doing nearest-vertex calculation using a
kd-tree is *not* the best way to implement this for meshes.
I've attached a file comparing my original simulated-annealing run (using a very
short simulated annealing period after a very short brute force), which does
simple ray sampling, to the version that does a nearest-neighbor vertex search
on the mesh data using a kd-tree, and then finds the nearest point on any
triangles using that vertex.
The upper image is the simulated annealing one, and the lower image is the
nearest-neighbor mesh one. You can see that the simulated annealing approach
results in better output.
*ALSO*, the simulated annealing approach runs more quickly...it completed in
less than 60% of the time of the other one.
I think I am going to put those code changes on the back-burner, after making
sure I store them away somewhere, and then go ahead with another option I was
thinking about: doing a simple gradient descent search from an initial candidate
guess.
Download 'test_compare.png' (252 KB)
Preview of image 'test_compare.png'
Date: 13 Jul 2022 08:55:00
Message: <web.62cebfce6fb4e448864166f75d51d79c@news.povray.org>
So after some more testing, I think the issue might actually be that the nearest
point algorithm using the kd-tree approach might be yielding suboptimal results,
which is requiring the isosurface code to do more samples, which is what is
actually slowing it down.
Basically, each sample is faster, but it's doing a lot more samples.
Either there is a bug in my kd-tree implementation, or there is something
fundamentally incorrect with the approach. Will have to do some more testing to
narrow down which it is.
It also occurs to me that I should be able to *somehow* use the mesh's bounding
box tree to implement a fast closest point query. Or maybe a parallel bounding
sphere tree?
Date: 13 Jul 2022 09:30:00
Message: <web.62cec87c6fb4e448864166f75d51d79c@news.povray.org>
Looks like the kd-tree is not always returning the nearest mesh vertex to the
test point. I create a test that compares the minimum distance found using
simulated annealing vs. the one found using the nearest-vertex test, and then
added some code to find the nearest vertex by using a brute-force check of *all*
the vertices in the mesh, which I run in the case the simulated-distance found a
better solution than the kd-tree nearest-vertex approach.
I fairly quickly ran into a case where kd-tree is not returning the correct
vertex, so now need to figure out why that is the case.
Date: 13 Jul 2022 09:50:00
Message: <web.62cecca56fb4e4481be3cd4b6cde94f1@news.povray.org>
hi,
"jceddy" <jce### [at] gmailcom> wrote:
> > Either there is a bug in my kd-tree implementation, ...
> ... using the nearest-vertex test, and then
thinking, re "nearest neighbour", perhaps the implementation that comes with the
GTS library "tools" may be of use?  written by Sunil Arya & David Mount, "ANN:
Approximate Nearest Neighbours" (though they spell it without the 'u' :-)), I
have a version from May 2005 installed; sorry, no ref link.
regards, jr.
Date: 13 Jul 2022 10:05:00
Message: <web.62ced0416fb4e448864166f75d51d79c@news.povray.org>
I can compare their kd-tree implementation to the one I have and try to figure
out if I'm dealing with a bug there.
Or rather if it helps me track down the but that is definitely there.
For example, I have a test point:
<-0.35977653631284895, 1.2000000000000000, -0.31591251373961082>
My kd-tree is returning this point as the nearest vertex:
<-0.22430989146232605, 0.65443259477615356, -0.19062881171703339>
The distance from the test point is 0.575926
*BUT*, when I brute force it, I find this is the actual nearest vertex:
<0.34019410610198975, 0.44190537929534912, 0.36512014269828796>
And the distance to that one is only 0.350649
That kind of error can definitely throw everything off.
Date: 13 Jul 2022 10:25:00
Message: <web.62ced4da6fb4e4481be3cd4b6cde94f1@news.povray.org>
hi,
faces/triangles in GTS are made from edges, so, an extra "layer".  agree re bug
hunt, running your points through both implementations should provide useful
info.
regards, jr.
Date: 13 Jul 2022 11:20:00
Message: <web.62cee1896fb4e448864166f75d51d79c@news.povray.org>
> info.
I found and fixed the kd-tree bug. So now it is correctly returning the nearest
vertex to the test point.
So my algorithm tests all triangles that use the nearest vertex, and then
calculates the minimum distance to each triangle, keeping the smallest of those.
It seems that this part is now not returning quite the correct minimum distance,
so I have to focus on that part next.
