POV-Ray : Newsgroups : povray.general : Media: rendering needs verry long for the last few percent Server Time
23 Feb 2025 01:46:07 EST (-0500)
  Media: rendering needs verry long for the last few percent (Message 1 to 10 of 14)
Subject: Media: rendering needs verry long for the last few percent
Date: 3 May 2022 18:15:00
Message: <web.6271a8dff250354f21faca8df9b2273@news.povray.org>
I've the following situation: a scene contains six objects with media (in the
center of the image). They are small, approx 10% of the final image.
When I render the scene (pov 3.7.0) the image is rendered to 97% in few minutes,
but the last 3% needs more than one hour! This final time seems to depend on the
amount of other objects in the scene, when I reduce them, the final part render
faster (but reducing objects is not an option).
What is povray doing at the end of the image?
How can I speed this up ?
Subject: Re: Media: rendering needs verry long for the last few percent
Date: 4 May 2022 14:03:19
Message: <6272bfe7$1@news.povray.org>
Le 2022-05-03 à 18:12, Juergen a écrit :
> Hi,
> Jürgen
It may be related to your media settings.
What is the sampling method ?
If using method 3, the default, did you increase the intervals value
above 1 ? Using method 3, intervals MUST remain at 1. Increasing it
greatly increase the rendering time for no effective improvement.
How many samples ? Try using less samples. Go as low as you can without
degrading the quality of your render. A solid, uniform, media may need
only 3 samples, while one using a busy pattern like granite or agate, or
a highly turbulent one, could demand over 100.
Any overlapping media containers ? (having common volumes)
If your media containers overlap, it can cause some performance issues
and cause artifacts. That's particularly true if one have a simple
pattern demanding few samples and the other have a pattern demanding a
high samples count.
Do those objects have an ior ?
A medium to high ior will cause total internal reflections.
Do you use dispersion ? Dispersion greatly increase the total number of
rays needed.
Any reflective surfaces ?
Date: 4 May 2022 14:45:00
Message: <web.6272c8b4dbd7fa052eadabda6e066e29@news.povray.org>
I have noticed some kind of similar media-rendering behavior, especially with
scattering media (but also with emission + absorption.)
I'm running V3.8.0 beta 1  (Windows), on a core I7 8-core/16-thread machine.
I currently use the default 'render block size' of 32X32 pixels and no 'mosaic
preview'. The last few 'render blocks' that get processed in my images (which
are in areas where there is media) seem to cause my machine to work *extremely*
hard. I have noticed this in two different ways: My machine's cooling-fan speed
greatly increases; and the Windows 'Task Manager' app shows that those last few
blocks cause the processor to suddenly jump to nearly 100% use.
On my machine, there does not seem to be an actual slowdown in the render-- just
some very hard processor work behind-the-scenes.
This is my *guess* as to what is going on (simply from a user's standpoint, and
not a programmer's):
Due to symmetric multi-processing, it would seem that each 'render block' in the
image is being processed by a particular core/thread(?)-- or, the blocks for
most of the render are being shared among those. But for the very last block--
or last few blocks-- the SMP process is reducing the number of threads(?) to
process those... in other words, maybe the last block is using only one core,
and trying to make it do *all* of the processing... resulting in a slowdown (or
overheating of the processor, in my case.)
Again, this is purely guesswork. I don't know the inner workings of processors
or POV-ray's SMP stuff ;-)
Date: 5 May 2022 03:35:46
Message: <62737e52@news.povray.org>
On 04.05.2022 00:12, Juergen wrote:
> Hi,
If you have a very simple scene with a single complex object in a very
small part of it, it my end up in one or a very few blocks, which take
very long to render.
If you want a better distribution of the computational load, you should
decrease the render block size such that your object gets distributed
between multiple render blocks.
Thorsten
Date: 5 May 2022 13:45:47
Message: <62740d4b$1@news.povray.org>
Each render block is rendered by a single core. So, your supposition is
correct.
In cases similar to this one, reducing the render blocks MAY improve the
performance by forcing those problematic blocks to get rendered by more
than a single core.
So, try using +rb16 or +rb12 and see if there is any improvement.
Also, changing the rendering pattern so that the rendering start near
the centre could help to at least hide some of the slowdown by having
the problem blocks starting to get rendered sooner.
Date: 5 May 2022 17:10:00
Message: <web.62743c28dbd7fa052eadabda6e066e29@news.povray.org>
> Thorsten
That works very well, thanks! From my own 'naive' analysis, I had been wondering
if a smaller block size would help, but I never tried it. (For my tests, I
forgot to mention that my media object occupies about 50% of the screen space--
unlike the OP's small object that is probably 'enclosed' by a single render
block.) Your suggestion works in both cases, of course.
A smaller render-block size has another great advantage: The scene renders
faster.
Here is my example (using scattering media):
block size of 64 pixels: 2 mins 16 sec
block size of 8 pixels:  1 min 10 sec
That's a definite improvement! And my machine's processor seems to run less hot,
based on the cooling-fan speed.
Date: 5 May 2022 17:35:00
Message: <web.627442a0dbd7fa052eadabda6e066e29@news.povray.org>
Thanks Alain.
The 'extra' benefit that never occurred to me was the faster rendering time when
using a smaller block size. I thought the result might be the
opposite...probably based on my old and fuzzy memories of running media on
single-core machines, before POV-ray's SMP implementation.
Date: 6 May 2022 02:00:56
Message: <6274b998$1@news.povray.org>
Op 05/05/2022 om 23:05 schreef Kenneth:
>> Thorsten
> faster.
Ha! Never thought about that 'trick'!
Date: 6 May 2022 02:55:41
Message: <6274c66d$1@news.povray.org>
Op 05/05/2022 om 19:45 schreef Alain Martel:
Just nitpicking: +rb should be +bs
Date: 6 May 2022 08:11:52
Message: <62751088$1@news.povray.org>
Op 5-5-2022 om 09:35 schreef Thorsten:
Is this also true when doing a stochastic render? Generally, I use:
+am3 +a0.03 +ac0.90 +r3
Is adding +bs12 (for instance) relevant in that case?
Thanks
