POV-Ray : Newsgroups : povray.general : Shadows and lighting with HDR sky Server Time
22 Jul 2026 00:59:02 EDT (-0400)
  Shadows and lighting with HDR sky (Message 11 to 11 of 11)
Subject: Re: Shadows and lighting with HDR sky
Date: 1 Oct 2021 04:32:31
Message: <6156c79f$1@news.povray.org>
Op 30-9-2021 om 20:11 schreef Kenneth:
>> Op 29-9-2021 om 07:21 schreef Kenneth:
>>>         always_sample on // off by default. I prefer this ON
>> The Voodoo Master teaches about this (in 2008):
>> [quote]
>> always_sample:
>> When set to "off", this effectively sets "nearest_count" to 1 during the
>> final render, so that new radiosity samples are only taken if they are
>> absolutely needed.
>> For quick test renders, you may want to set this parameter to "on" to
>> get away with a faster pretrace (or none at all).
>> Otherwise, you will definitely want to set this parameter to "off", as
>> new samples taken during final trace may cause visible "jumps" in colour
>> or brightness between areas rendered before and after the new sample was
>> taken.
> Yes, I remember reading that. Several months ago, I did some lengthy and
> detailed tests with radiosity (which I *hope* to post about soon...), and my own
> eyes tell me that the final render looks 'better' with always_sample on.
> Specifically, it seems to eliminate some very subtle artifacts that I noticed;
> as a simple way of describing the effect, it produced a 'smoother' render
> IMO...but hard to describe, unfortunately. However, all of my tests used a
> single small rad emitting object in a scene (and no sky_sphere), as I wanted to
> try and zero-in on the basic behavior of radiosity and its various settings.
> I could be wrong, but it may be that this particular feature of rad has been
> improved since Clipka posted that info(?)
> Or it could be just my personal preference, ha. As the old saying goes,
> "One man's meat is another man's poison" (which may not translate well?)
You might well be right. While posting my Clipka comment, I realised
that he was writing at a time when version 3.7 was still in a
development mode. I would be curious to have his updated view on this,
in particular for version 3.8.
