POV-Ray : Newsgroups : povray.general : image_map memory use-- question Server Time
11 May 2025 17:38:17 EDT (-0400)
  image_map memory use-- question (Message 1 to 4 of 4)
Subject: image_map memory use-- question
Date: 11 Jul 2021 19:40:00
Message: <web.60eb801413d9db17d98418916e066e29@news.povray.org>
Is there a way to 'undefine' an image_map, once it has been loaded into memory
during the parsing of a scene? So that its memory is 'released'? AFAIU, using
#undef simply undefines the *identifier* for the image (not the image_map
itself), which is not what I'm talking about.
Here's a rather nutty example, to describe what I mean:
Let's say I want to use eval_pigment to pick out a single pixel's color at some
location in an image, in maybe 10,000 different image_maps(!)that are
consecutively numbered-- stepping through each image in a #for loop, for
example. Each image_map itself is no longer needed after that step, and could be
eliminated. Otherwise, those 10,000 images could take up a lot of memory.
Is the efficient way to do this simply a matter of re-#declaring each 'new'
image with the *same* identifier? (Assuming a proper-size array has already been
pre-#declared to hold the eval_pigment results):
#declare PIXEL_COLOR_ARRAY = array[9999];
#for(i,0,9999)
#local IMG = eval_pigment(...image_map and location...)
#declare PIXEL_COLOR_ARRAY[i] = IMG;
Does the IMG variable just substitute one image_map for another, so that there's
only one image in memory at any one time? Or does the eval_pigment() macro
itself cause all 10,000 images to start accumulating into memory, without
'flushing' each image_map before it sees a new one? My understanding is that a
#macro does 'undefine' its #local variables automatically when the #macro use
has ended-- but again, that's just its *identifiers*, AFAIK-- not(?) any memory
that the #macro used.
Subject: Re: image_map memory use-- question
Date: 12 Jul 2021 02:09:21
Message: <60ebdc91$1@news.povray.org>
Am 12.07.2021 um 01:34 schrieb Kenneth:
As a general rule of thumb, whenever you "discard" an identifier's value
(because you `#undef` it, assign a new value, re-define it as a macro,
or whatever), any associated memory will automatically be released IF
there doesn't exist another reference to that data.
Additional references will typically be created when you:
- assign the value to another variable, or
- "attach" the value to some other scene element, e.g. use an
image-based pigment in an object.
Simply evaluating an image-based pigment will not create an additional
reference.
There are a few exceptions to this:
- Some data will always be copied, rather than additional references
created; and
- Some data will be cached because it is expected to re-occur later, and
is sufficiently complicated to process that it would be a waste to do it
all over again.
An example for the latter would be font files, which aren't discarded
even when a `text` object is discarded, because POV-Ray anticipates that
you might use the same font (and possibly also some of the characters)
in other `text` objects.
POV-Ray doesn't cache image files, so you should be fine with what
you're trying to do, even without any extra precautions.
TL;DR:
Yup.
Date: 12 Jul 2021 12:00:00
Message: <web.60ec66687da66539d98418916e066e29@news.povray.org>
> reference.
That's all good news; thanks.
(Just to add a note: This particular usage...
#declare MY_IMAGE = pigment{image_map{...}}
does seem to cache the image_map for use later, without an apparent(?) increase
in memory when it is called multiple times in a scene...which is quite useful!
But it's a different construct from what we are talking about here.)
> all over again.
> An example for the latter would be font files...
Just as a matter of curiosity: Is there a method within the SDL of purging even
such 'persistent' things from memory? I suspect not.
Date: 12 Jul 2021 13:14:13
Message: <60ec7865$1@news.povray.org>
Am 12.07.2021 um 17:57 schrieb Kenneth:
>> all over again.
Nope, not at the moment. If I'm not completely mistaken, such caches are
discarded before the actual render starts though.
